Author Topic: What exactly is Dolch?  (Read 12936 times)
Re: What exactly is Dolch?
« Reply #50 on: Thu, 10 December 2015, 22:45:55 »
you like it shiny right?  :D
IMHO both are great, but in the long term...ABS shines, Cherry DS / GMK stuff shines and PBT, specially BSP and OG PBT Cherry sets (great smooth feeling) will keep their texture much much longer than Cherry DS / GMK ABS sets.
ABS that shines is the best
I feel like it adds a little personality to it. Like battle wounds, or something.
Offline ideus
  • Björkö.
« Reply #51 on: Thu, 10 December 2015, 22:57:14 »
The velvet touch of a worn off thick ABS OG Cherry set is one the reasons to use a discrete mechanical keyboard. There is nothing wrong with BS or ALPS but there is no key caps like that for them, which is unfortunately.
Offline zslane
« Reply #52 on: Fri, 11 December 2015, 14:41:46 »
Hack'd By Geeks is essentially sculpted SA Dolch with orange legends.
Okay, well, here are the reasons a brand new Dolch SA set would be preferable (to Hack'd):
1. It would be available (no scouring classifieds in futility).
2. White legends as per proper Dolch colorway.
3. Superior 1-1-2-3-4-3 row profile. (If I had anything to say about it anyway)
4. Proper R4 Shift keys with fixed legends.
5. Red ESC and RETURN keys.
