Author Topic: What's your favourite 87% or 60%, and why?  (Read 13565 times)
Offline ctm
  • Hello, world!
Re: What's your favourite 87% or 60%, and why?
« Reply #50 on: Tue, 08 December 2015, 22:31:21 »
My favorite 60 is TMK ALPS64 (typing on it right now). I use this PCB with plates and case from KBP V60. Reasons: full programmability (awesome TMK firmware), Matias quiet switches, 60% form factor.
Do you have some pictures you may share?
From outside it basically looks identical to a normal V60 because I used case, plate and keycaps from V60. The real magic is the PCB inside. I also plan to get Matias's PBT caps to replace current caps, when the PBT caps become available to buy.
Coming:
Ellipse Model F F62.
Offline ideus
  • Björkö.
« Reply #51 on: Tue, 08 December 2015, 22:35:17 »
Thank you for the pictures.
Offline E3E
« Reply #52 on: Wed, 09 December 2015, 00:09:21 »
Dude, I love sleeper boards. Boards that look like a stock OEM board but are packing a real punch under the caps. So nice! :D
Offline Ludovician
« Reply #53 on: Wed, 09 December 2015, 03:06:23 »
TKL: KBParadise V80MTS, as it's the only one available with standard TKL and Alps switch compatibility since the Filco Zero was discontinued. I put SKCM Blues in it and it's my favourite keyboard overall.
60%: Does the FC660C count as 60%? I like it because of the layout (I use the arrow keys and nav cluster constantly) and because it's a 60% with plate-mounted Topre, which I prefer over the HHKB.
Typing speed:
My collection:
HHKB Pro 2 (Blank, white) | HHKB Pro 2 Type-S (Blank, white) | Topre Realforce 87UB silent-modded (not currently functional) | Das Keyboard Model S Professional Silent (MX Brown) | IBM Model M 1391401 - 9th January 1991 (Bolt+Floss-modded) | Apple keyboard m0116 (Orange Alps) | Unidentified DIN Keyboard (White Alps) | ADDS 1010 (Green Alps) | AEK II (Linear-modded, USB-converted) | IBM PC-AT Model F | Noppoo Choc Mini (MX Black) | Amstrad PC2286 | BigKeys LX | IBM Model M 1391401 - 6th September 1990 | IBM Model M2 1395300 - 28th February 1991 | Leopold FC660C | Cherry G80-11802 (MX Brown) | Matias Tactile Pro (Simplfied grey Alps) | Razer Blackwidow (MX Blue) | Novatouch 55g | Focus FK-2001 (White alps) | DSE Multitech (Blue alps) | Dell AT101W (Matias quiet) | Pok3r (White w/Clears) | KBP V80 (Blue Alps)
Pending:
Infinity kit
Offline ctm
  • Hello, world!
« Reply #54 on: Wed, 09 December 2015, 08:23:40 »
Thanks ;D
Coming:
Offline jcoffin1981
« Reply #55 on: Sun, 13 December 2015, 01:18:33 »
If you are going to spare some keys, you may as well just go all the way and go 60%.  It is true that cutting only the number pad allows you access to dedicated home, end, and arrow keys.  However, once I have gotten used to the 60% layout I liked it better and when going back to the larger board it felt cramped.  The 87% cuts only 3 inches or so, but the 60% cuts 6 inches, which is pretty substantial.
Offline Steezus
  • Keeper of Facts
« Reply #56 on: Sun, 13 December 2015, 01:22:30 »
For 87 I have my Jane and Orion, enjoy both of them so much. I enjoy the functionality of Duck's board, the TX87 pcb in the Jane is very nice but the firmware is lacking.
For 60% I've only ever used the Pok3r, it was my first mech and I enjoyed it at first but quickly lost interest. I would love to build a Duck Eagle though, aluminum cases all the way.
Offline bocahgundul
  • a seal
« Reply #57 on: Sun, 13 December 2015, 01:25:24 »
HHKB with alternate hasu controller
