Author Topic: Permanently Disable LED from CM Quickfire Rapid-I?  (Read 1248 times)
Offline Dyaems
« on: Wed, 09 December 2015, 23:15:13 »
Is it possible?
I know I can just shut the LEDs off through the shortcuts but the problem is the bottom LED lightning  on the keyboard doesn't really completely shut off so I wondered if it is possible to disable them after opening the keyboard.
Any other suggestions would be appreciated, thanks!
   B.face X2
  65g Zealios
Offline stoic-lemon
Re: Permanently Disable LED from CM Quickfire Rapid-I?
« Reply #1 on: Wed, 09 December 2015, 23:29:50 »
Have you opened the keyboard? Maybe put some black tape or something over them? Desolder them?
