Author Topic: O rings for DSA Caps  (Read 6128 times)
Offline Harms
« on: Sat, 12 December 2015, 02:53:43 »
Hey guys, will the WASD blue o rings do anything to reduce travel on DSA caps? Or do I need larger o rings? Thank you for the input.
Re: O rings for DSA Caps
« Reply #1 on: Sat, 12 December 2015, 04:07:17 »
You need fatter ones, or you can use two :)
Offline Lpwl
  • lpwl.bigcartel.com
    • My O-ring Store
« Reply #2 on: Sat, 12 December 2015, 04:43:59 »
As suicidal_orange said, WASD blue O-rings are too thin - they are 1.8mm thick.
So you have two options available :
- Use 3.0mm thick O-rings - they'll fit DSA keycaps like a glove but won't be compatible with Cherry & OEM profile keycaps.
- Use two O-rings on top of each others (1.5mm + 2.5mm) like this :
That trick will almost do the same job and you'll be able to use the 1.5mm thick O-rings with "low-profile" keycaps (made by CherryCorp - JTK - GMK - IMSTO or BSP) and both (1.5mm or 2.5mm thick) with OEM profile keycaps.
EDIT : BTW I forgot to announce it over here at Geekhack but I'm now offering "soft" O-rings (in 40A durometer) directly from my store : lpwl.bigcartel.com
No moaaaar classifieds.
« Last Edit: Sat, 12 December 2015, 05:00:57 by Lpwl »
Offline Harms
« Reply #3 on: Sat, 12 December 2015, 11:28:55 »
Ic so 2.5 by its self wont work only 3 will... Thanks a lot :) Also if i use 3 by its self how much key travel does it reduce approximately?
Offline ideus
  • Björkö.
« Reply #4 on: Wed, 16 December 2015, 18:48:45 »
Or you can use the trampoline mode with either o-ring segments or silicon balls, it is very effective and more elegant than o-rings.
« Reply #5 on: Wed, 16 December 2015, 18:54:10 »
Nice, now I know where to send people searching for fat ones :)
Offline codywanks
« Reply #6 on: Tue, 22 December 2015, 15:30:38 »
Sorry for the dumb question... but Option #1 is 3mm and Option #2 adds up to 4mm. Is there something I'm missing?
P.s. I'm having this problem too. Recently acquired a used set of DSA Dolch and only have 1.8mm o-rings on hand. Needless to say, they don't work at all.
Offline Harms
« Reply #7 on: Tue, 22 December 2015, 20:39:04 »
get some o rings from here then http://lpwl.bigcartel.com/products. I got the thick and XXL o rings. Both should work just fine and the customer service is awesome.
Offline Lpwl
    • My O-ring Store
« Reply #8 on: Wed, 23 December 2015, 06:50:44 »
You missed one small detail !
Both options are placing O-rings at different heights on the keycap.
In other words, the 1.5mm thick O-rings (from Option #2) are just there to provide support to the 2.5mm thick ones.
Haha ... even with pictures, I don't know if I succeeded in explaining this well !  ;D
Thank you both Harms & suicidal_orange for your support !
 :thumb:
« Last Edit: Wed, 23 December 2015, 07:01:12 by Lpwl »
Offline codywanks
« Reply #9 on: Wed, 23 December 2015, 10:49:52 »
Wow... Thanks for taking the effort to prepare those pictures. I totally get it now.
Now I see why the GH community has a legendary reputation...
