Author Topic: PCB problem  (Read 2298 times)
Offline sitch
PCB problem
« on: Sat, 12 December 2015, 05:23:57 »
Hi guys, I have recently assembled a pcb but all the LED doesn't light up ( correct polarity ) but the key input is all working as normal. May I know what probably caused the problem?
Offline MAR82
  • Keyboard Addict
Re: PCB problem
« Reply #1 on: Sat, 12 December 2015, 05:29:28 »
What PCB are you using, can you upload pictures, are you sure the polarity is correct, are they just maybe turned off in the firmware?
I'm not sure I can help, but if anyone can you'll need to give us more information
Offline sitch
Re: PCB problem
« Reply #2 on: Sat, 12 December 2015, 07:02:05 »
Hi Im using china GH60 pcb replica, I think it's running on GH60 firmware too, yes Im sure of the polarity.
Is it possible to turn off in firmware? How do I check?
Offline MAR82
  • Keyboard Addict
Re: PCB problem
« Reply #3 on: Sat, 12 December 2015, 07:35:36 »
I don't have a GH60 (China or not), but I'm sure there are people here that do and help you more than I can. But I know on a lot of boards you can turn LEDs on and off and set it to a key combo to do so.
Do you have a tool to configure the board?
Offline stoic-lemon
Re: PCB problem
« Reply #4 on: Sat, 12 December 2015, 08:01:00 »
Even if you are sure, it's always better to show some close up pictures and screenshots of firmware settings. We all make mistakes.
Re: PCB problem
« Reply #5 on: Sat, 12 December 2015, 08:12:29 »
There are many dodgy unofficial Chinese "GH60"s out there, if you have a spare LED touch it to one of the soldered ones with the polarity reversed - it will either light up dimly and confirm the markings on the PCB are wrong or it won't which will prove nothing, but it's a quick check so worth doing.
