Author Topic: Your Favorite Keyset and Switch Combinations  (Read 3277 times)
Offline retrochick
  • goodbye my wallet
« on: Tue, 15 December 2015, 11:36:28 »
This is a thread to see what other people are loving in terms of switches and keycap combos. I'm currently LOVING lubed vintage 55g blacks with GMK Dolch on my QFR. Sooooo buttery smooth and that thock is unmistakable. The texture of the keycaps is also excellent. My spacebar is starting to shine, but I've come to embrace the shine.
Offline quasistellar
Re: Your Favorite Keyset and Switch Combinations
« Reply #1 on: Tue, 15 December 2015, 13:23:46 »
I'm currently loving Vortex PBT Cherry profiles on a Novatouch.
Offline Hypersphere
« Reply #2 on: Tue, 15 December 2015, 13:30:04 »
Are they Cherry profile or OEM profile? I've just put some dark gray side-print Vortex PBT caps on my Novatouch (NT), but the set that I have is OEM profile. I've tried Cherry profile on the NT, but this results in bottoming-out noise.
Offline Neo.X
« Reply #3 on: Tue, 15 December 2015, 14:12:50 »
thick pbt or pom on liner switch, thick abs on tactile switch, thin pbt on click switch.  All Cherry profile.
All those keyboards will be lost in time....
Offline keshley
    • Blog n stuff
« Reply #4 on: Tue, 15 December 2015, 16:50:40 »
If you put O-rings on the cherry profile caps, you won't get the bottoming out noise, as it lifts the caps just enough not to hit the Topre housing.
HHKB Pro 2       Pok3r
Offline Hypersphere
« Reply #5 on: Tue, 15 December 2015, 16:58:27 »
Best match (IMO) of switches and keycaps on stock keyboards:
IBM Model F and Model M switches with their own dye-sublimated PBT keycaps
Realforce 87UB Topre 45 or 55g switches with their own dye-sublimated PBT keycaps
PFU HHKB Pro 2 black or white Topre 45g switches with its own blank or dye-sublimated PBT keycaps
My favorite keycaps on the CM Novatouch:
Ducky dye-sublimated PBT OEM Profile Cream (alphanumeric keys); Originative Carbon Black (modifiers and spacebar)
Offline GenKaan
  • Mer caps, mindre käbbel
« Reply #6 on: Tue, 15 December 2015, 17:12:30 »
#1: Shine 3 TKL (Mx Red) with engraved thick Ducky PBT caps
#2: Black HHKB case with white printed caps
|| @Home:: Shine 3 TKL (Mx Red / Deep Space)  || @Work:: G2Pro (Mx Clear / Dye Sub PBT) ||
@Reserve:: HHKB (Topre 45g / Mixed PBT) // Das v3 (Mx Brown / Blank PBT)
Offline mashby
  • What Up Shoney? (ツ)_/¯
    • Mashby
« Reply #7 on: Tue, 15 December 2015, 17:22:50 »
Cherry MX-Black with Krytox lube and Signature Plastics SA keycaps.
« Reply #8 on: Tue, 15 December 2015, 17:23:41 »
stock hhkb keysets
Offline Jokrik
« Reply #9 on: Tue, 15 December 2015, 17:27:51 »
62g MX blues with GMK/Cherry :D
or 62g lubed vintage blacks with GMK/Cherry
basically there's only one keyset in my book, Cherry
« Reply #10 on: Wed, 16 December 2015, 09:01:00 »
They are cherry profile, but the bottoming out is very minor.  It's definitely more noticable on the stabbed keys.  I haven't tried o-rings yet, but I'm currently loving the profile and key feel.  The bottoming out noise actually sounds very "thocky".
Offline raymogi
« Reply #11 on: Wed, 16 December 2015, 09:04:04 »
Same with most people here, 59g lubed vintage blacks with GMK.
Please feed my addiction.
« Reply #12 on: Wed, 16 December 2015, 09:05:02 »
IBM 4704 62key with Unicomp Wildcats keycaps  :cool:
Offline keshley
    • Blog n stuff
« Reply #13 on: Wed, 16 December 2015, 09:08:03 »
I'm currently torn between SA on Topre, and Hi-Pro on Topre. I like them for differing reasons, and while they look similar, they don't feel the same.
HHKB Pro 2       Pok3r
Offline nmur
  • ಠ_ಠ
« Reply #14 on: Wed, 16 December 2015, 09:11:19 »
RF caps on a variable RF board (ie plate mounted topre) with silencing ring mod to reduce the initial stiff tactility from the dome
the softest, most pleasant typing experience I've ever had
Offline ideus
  • Björkö.
« Reply #15 on: Wed, 16 December 2015, 09:37:03 »
My own version of ergo clears and moded blacks under OG Cherry keys.
Offline DAVYtm
  • #dateless
« Reply #16 on: Wed, 16 December 2015, 12:13:55 »
I'm always between my B.Mini with MX-Blacks and my HHKB. But I think it'd have to be the HHKB.
Offline Burt Macklin
« Reply #17 on: Wed, 16 December 2015, 17:55:49 »
MX Brown with Filco stock + WASD keycaps combo (soon to be replaced with SA Filco set).
