Author Topic: How many of you are getting a White Fox?  (Read 35300 times)
Offline O(logn)
Re: How many of you are getting a White Fox?
« Reply #50 on: Thu, 17 December 2015, 14:06:51 »
I was reading the comments on massdrop and matt3o comments that if this drop is successful a blackfox maybe in the works. Does anyone know any details about this?
Offline Neo.X
« Reply #51 on: Thu, 17 December 2015, 14:09:48 »
Great, a black fox, maybe also a pink fox, blue fox, gold fox....
All those keyboards will be lost in time....
Offline Vittra
  • Airflow Optimizer
« Reply #52 on: Thu, 17 December 2015, 14:26:12 »
2016 -  if it happens at all - is all the information we've been told for now. They've got to get through this GB first. :)
Filco MJ Linear R LE TKL
Offline mashby
  • What Up Shoney? (ツ)_/Ż
    • Mashby
« Reply #53 on: Thu, 17 December 2015, 14:38:50 »
Matt3o has said that he might do this design as a limited edition version on the next drop. That will probably be after the first of the year.
Offline Zorox
  • Tactile FTW <3
« Reply #54 on: Thu, 17 December 2015, 15:26:55 »
I have also joined the GB buying a barebone. But will need to make custom plate after I get it. This is the layout I have in mind for the WhiteFox.
Matt3o has already confirmed that he will release CAD files, dimensions and tutorials right after the GB. And while it is fully programmable. I need to say it is undeniable :D
Offline ideus
  • Björkö.
« Reply #55 on: Thu, 17 December 2015, 16:18:12 »
It is an interesting layout, I have not had thought before in the possibility to build a custome plate to take advantage of the package, that is a very interesting idea.
Offline Altis
« Reply #56 on: Thu, 17 December 2015, 18:49:40 »
I'm tempted to get one for the girlfriend as her first mech board (and first non-built-in-laptop keyboard) because the layout is good and more importantly, she looooves foxes.
Offline tchevass
  • open wide
« Reply #57 on: Thu, 17 December 2015, 18:54:21 »
I ordered one with Purple Zealios ! WhiteFox layout
I want clacks
Offline Adriel
  • sample text
« Reply #58 on: Thu, 17 December 2015, 19:22:20 »
I don't know man I ordered 2 on the first day and then I realised it had wire based stabilizers and canceled my orders.
ES-87 Gateron Red | Pok3r Blue
Offline O(logn)
« Reply #59 on: Thu, 17 December 2015, 19:26:02 »
Cool. I just got my realforce 55g about a month ago and don't need to get a new keyboard yet as I really enjoy using it. However, I am fancying a keyboard with a smaller layout. I also want to try using a "true" mechanical  keyboard. If I order the barebones kit, what key cap set will fit the true fox layout? I have been wondering this since it seems that the whitefox has unique key sizes(maybe?).
Offline ander
  • I type, therefore I am
« Reply #60 on: Fri, 18 December 2015, 06:49:13 »
If you think that's cool, you may be interested in the 17-key number pad I've programmed to function as a full-size keyboard, using 3-, 4- and 5-key shortcuts. It's the ultimate in non-efficient simplification—and custom caps for it are real cheap, because you need only 17 of them. Yeah baby!
Offline mashby
    • Mashby
« Reply #61 on: Fri, 18 December 2015, 10:19:14 »
"wire based stabilizers" vs what?
Offline FLFisherman
  • I'd rather be fishing.
« Reply #62 on: Fri, 18 December 2015, 10:19:58 »
Cherry stabilizers?
Offline pandaaqq
« Reply #63 on: Fri, 18 December 2015, 10:22:27 »
Ordered one, ISO layout + cherry browns. I just can't imagine switching between different layouts 24/7, so I'll have to stick with ISO.
Offline OverKill
« Reply #64 on: Fri, 18 December 2015, 10:56:21 »
Cherry stabilizers?
They are wire based as well.
Offline FLFisherman
« Reply #65 on: Fri, 18 December 2015, 11:00:51 »
Cherry stabilizers?
I don't know what's what. This is the image I was going off on, but I'm sure I'm missing something.
« Reply #66 on: Fri, 18 December 2015, 11:03:41 »
Cherry stabilizers?
There's still a wire that goes with the Cherry stabilizers, they're just not in place in the pic. If you look, the difference is with the faux-stems (or mounts) that the Cherry has, whereas Costar does not.
Offline FLFisherman
« Reply #67 on: Fri, 18 December 2015, 11:06:56 »
Cherry stabilizers?
Ah, so all stabilizers have wires (or at least Cherry and Costar). I like those Cherry ones. Much easier to use.
Offline retrochick
  • goodbye my wallet
« Reply #68 on: Fri, 18 December 2015, 11:08:47 »
Cherry stabilizers?
If you clip them they're even better.
Offline DanielT
« Reply #69 on: Fri, 18 December 2015, 11:12:58 »
I love the keyboard form factor but... MD, I try to avoid them especialy with expensive items ... I have way too many boards... Costar stabs... and no stepped Caps Lock...and MD again
Offline pandaaqq
« Reply #70 on: Fri, 18 December 2015, 11:15:42 »
What's so bad about Costar stabilisers?
Offline DanielT
« Reply #71 on: Fri, 18 December 2015, 11:52:42 »
It's just a personal option, there is nothing wrong about them, I just don't like how they feel. In many aspects Costar stabs are better, easier to fix in case the stab insert gets pulled, but I don't like them. I'm not a big fan of plate mounted switches.
Offline ideus
  • Björkö.
« Reply #72 on: Fri, 18 December 2015, 12:27:52 »
Try to change a key-cap with them and you will find it; in particular, the space bar, and just don't bother if the stem gets stocked inside a key-cap's socket, if so, be prepared with your pliers to get it out and to fix the bent wire. I am sorry but they just suck.
Offline Phenix
« Reply #73 on: Tue, 16 February 2016, 15:16:28 »
would buy a whitefox in ISO or the TrueFox
Wants someone to sell? Prefer Zealio followed by Clears
Winter is coming.
Offline swimmingbird
  • keyset hoarder
« Reply #74 on: Tue, 16 February 2016, 21:00:34 »
plus one million
I'm really hoping that someone comes out with an aftermarket plate really soon so I don't have to use those goddamn stabs
Offline deduction
  • unix layout zealot
« Reply #75 on: Tue, 16 February 2016, 21:27:08 »
I am, but it's unlikely that I'll deviate from the truefox layout
+1, TrueFox layout all the way.  I would be interested in PCB mount stabs though!  Especially with a 7u spacebar :) (Actually I could just bend a 7u spacebar if I really need to...)
Offline KaminKevCrew
« Reply #76 on: Tue, 16 February 2016, 23:14:57 »
If you want one, you should post a WTB thread in the classifieds, or on MechMarket. Also, they haven't even shipped yet, so other than the manufacturer and matt3o, nobody has one.
Offline Giorgio
« Reply #77 on: Wed, 17 February 2016, 02:16:11 »
Costar instead of cherry? Until now I had a great opinion of that keyboard.;
Offline Harms
« Reply #78 on: Wed, 17 February 2016, 02:53:33 »
Its odd to see people dislike Costar stabs. Usually it is people disliking the cherry stabs for feeling "mushy".
Offline Diokhan
« Reply #79 on: Wed, 17 February 2016, 03:01:21 »
+1 true fox
  • keyset hoarder
« Reply #80 on: Wed, 17 February 2016, 06:01:15 »
Clipped cherry stabs feel as good as costar stabs with none of the keycap fitting issues
Offline xondat
  • i'm not a star
« Reply #81 on: Wed, 17 February 2016, 06:42:44 »
If it had function keys... I was pondering for ages on what to get but realized I wouldn't of used it much because I need my F keys.
  • keyset hoarder
« Reply #82 on: Wed, 17 February 2016, 06:51:46 »
Sounds like a 75% is the perfect board for you
« Reply #83 on: Wed, 17 February 2016, 07:35:59 »
And clipping is so easy there's really no reason not to do it.  :thumb:  Costar is great if you never plan to swap caps, but if you do...  :rolleyes:
  • keyset hoarder
« Reply #84 on: Wed, 17 February 2016, 07:44:11 »
Yeah I was actually taken back a bit when I did it - thought it would've been some lengthy process like lubing but nope 5 mins for whole mod
Offline vivalarevolución
« Reply #85 on: Wed, 17 February 2016, 08:11:48 »
I would join if Matias/Alps compatibility was offered.  I've moved beyond Cherry.
Offline ideus
  • Björkö.
« Reply #86 on: Wed, 17 February 2016, 08:28:50 »
I did not get any of these foxes; why?, well, Costar stabs sucks, there is no actual need for arrows in a small footprint keyboard, TKL are the best if you need them, the programming system offered on this and the former MD keyboard kits is not the best around, the layouts that can take standard size keys look awful; but, in all fairness, the pricing was good.
Offline quasistellar
« Reply #87 on: Wed, 17 February 2016, 09:22:59 »
This. After trying other switches, I just don't get excited about anything cherry-based. I don't DISlike them, it's just that I like everything else better: Topre, Matias, Romer-G all feel better to me. The only reason to stick with cherry is the keycaps (which is why I have a Novatouch at work).
I really wanted to get a white fox because I like the layout, but even Zealios (which I haven't tried, I'll admit) couldn't sway me.
« Reply #88 on: Wed, 17 February 2016, 10:09:07 »
My main beef is with Cherry is that they require modding, or, in the case of zealous, high cost to reach an ideal feel.  Various other switches are more ideal out of the box, so that's why I don't bother with Cherry or its clones anymore.
Offline Phenix
« Reply #89 on: Wed, 17 February 2016, 10:26:51 »
Cant post into Classifieds cause Im not registred for 2 month (only soon)
Winter is coming.
Offline DukeMugen
  • +1
« Reply #90 on: Wed, 17 February 2016, 10:58:45 »
If only whitefox had a housing like the LZ SQ, i would definitely buy it in a heart beat.
let me check my wallet.
« Reply #91 on: Wed, 17 February 2016, 12:17:11 »
That sort of housing would significantly increase the cost, nullifying one of the main appeals of the group buy, which is affordability.
Offline steve.v
« Reply #92 on: Wed, 17 February 2016, 12:49:51 »
Another slanted kb with a different name? nah, not me hehe.
Offline venyv
« Reply #93 on: Wed, 17 February 2016, 13:38:13 »
+1 for true fox
Offline xondat
  • i'm not a star
« Reply #94 on: Wed, 17 February 2016, 14:37:47 »
Indeed... Dunno what to get - kind of want to get a VE.A but monies
Offline MrRooks
  • Always be knolling
« Reply #95 on: Wed, 17 February 2016, 15:02:31 »
I went with the True Fox but I don't even think I will keep the kit, don't think I'll use it and I'm sure someone else will.
Offline Phenix
« Reply #96 on: Wed, 17 February 2016, 16:33:16 »
@Mr Rocks - I will :D
Just send me a pm.
Winter is coming.
Offline hkf
  • your #1 fan
« Reply #97 on: Wed, 17 February 2016, 16:58:34 »
Getting vanilla, don't think I'll get used to the backspace positioning for truefox :(
  • keyset hoarder
« Reply #98 on: Wed, 17 February 2016, 17:31:30 »
You'd be surprised how easy it is to get used to the backspace in the \ | position
Offline ideus
  • Björkö.
« Reply #99 on: Wed, 17 February 2016, 17:32:44 »
I had a really hard time the first time I tried it, I should try it again when I get the appropriate key caps, like when I get my Bluegaloo.
