Author Topic: Sun Type 5c  (Read 5742 times)
Offline Jason
Sun Type 5c
« on: Fri, 20 November 2009, 21:27:03 »
Hey all,
I've been curious about Topres recently, and wondered if my Sun Type 5c approximates the feel of a Topre. I'm not even sure what kind of switch is in this thing, as I'm not sure how to identify a dome+capacitive switch board.
Is the 5c a dome+capacitive switch board similar to the topre? Or is it just a decent-feeling rubber dome? Any thoughts on the Sun 5c in general?
Offline msiegel
Sun Type 5c
« Reply #1 on: Fri, 20 November 2009, 21:29:35 »
if it's this one, it looks like a standard rubber dome
Offline Jason
Sun Type 5c
« Reply #2 on: Fri, 20 November 2009, 21:43:36 »
Yeah, that's the keyboard, though mines is UK layout. Thanks!
Offline rdjack21
Sun Type 5c
« Reply #3 on: Sat, 21 November 2009, 00:30:19 »
The only sun Topre board that I'm aware of has this layout:
And here is the actual board and as you can see the actual boards layout is a little different than the picture above. This one is the closest I've come to finding that layout in an actual board.
If I remember correctly the layout is a 5e there was also a Japanese version of it as well. You can see it in this picture:
That one above is actually for sale right now on Yahoo Japan for 11,000 yen which is not a bad price considering it also comes with a KVM in a 1U rack mount package. That has been tempting me for awhile now but I already have the MD01B0 which is essentially the same board and I had other boards I wanted more.
Keyboards
Topre Capacitive: Realforce 87U, Realforce 86U, HHKB Pro 2, Topre MD01B0, Topre HE0100, Sun Short Type, OEM NEO CS (x2), NISSHO Electronics KB106DE
Buckling Spring: IBM Model M Space Saver (1291472), Unicomp Customizer x 2
Cherry Brown: Filco FKBN87M/EB, Compaq MX11800
Black Alps: ABS M1
Not so great boards Rare Spring over dome OKI, Sun rack keyboard
Trackballs - Trackman Wheel (3), Trackman marble (2)
Keyboards I still want to get - Happy Hacking Keyboard Pro 2 the White version, Realforce 23U number pad in black and maybe white, μTRON ergo board with Topre switches.
Previously owned - [size=0]SiiG MiniTouch (White Alps), Scorpius M10 (Blue Cherry), IBM Model M13[/size]
Offline ch_123
Sun Type 5c
« Reply #4 on: Sat, 21 November 2009, 05:03:18 »
What are those low profile Topre boards like? I hear they're like old Thinkpad boards, which would basically make them an overpriced M4-1. =P
Offline rdjack21
Sun Type 5c
« Reply #5 on: Sat, 21 November 2009, 10:23:07 »
Quote from: ch_123;134869
Take a look here http://geekhack.org/showwiki.php?title=Island:7344
But the key points are:
1) 3.5mm key travel so almost full keyboard key travel.
2) normal key spacing
3) uniform 55g key weight - really the only complaint I have of the board.
4) Fantastic Topre key feel to them.
I really like the MD01B0 I have but it could be better.
Keyboards
Black Alps: ABS M1
Offline ch_123
Sun Type 5c
« Reply #6 on: Sat, 21 November 2009, 16:49:20 »
Interesting. That said, I'd still take the M4-1. The key feel may be pretty average, but at it makes for it with the Trackpoint.
Offline microsoft windows
  • Blue Troll of Death
  • President of geekhack.org
    • Get Internet Explorer 6
Sun Type 5c
« Reply #7 on: Sat, 21 November 2009, 17:14:18 »
The trackpoints on an M4-1 take a little getting used to however. They are a little less sensitive to most other pointing sticks. But the sensitivity can be adjusted through Windows.
Offline rdjack21
Sun Type 5c
« Reply #8 on: Sat, 21 November 2009, 21:49:29 »
Quote from: ch_123;135045
Yea I keep thinking I need to pick up a M4 but I just haven't for some reason.
Keyboards
Black Alps: ABS M1
Offline paranonia
Sun Type 5c
« Reply #9 on: Sat, 05 December 2009, 01:58:06 »
I have both of them (Sun Type 5c and Topre Realforce 101).
The feeling on keyboards is similar, RF101 is a little bit better than Type 5c, but not much.
If you have Type 5c, just keep it, the keyboard is manufacttured in good manner.
KEYBOARDS:
⌨ Sun Type 5c Keyboard x 3 ( With Sun KVM-USBADP ) ⌨ Topre Realforce 101 ⌨ C.ITOH Short Type Keyboard(US) ⌨ CTCSP Short Type Keyboard(JP) ⌨ Fujisu 4700 ⌨ Fujisu 4725 x 2 ⌨ Fujisu 4726 ⌨ Fujisu 8725 ⌨ HHKB Lite2 ⌨ PowerSource 101(ALPS)
Offline ch_123
Sun Type 5c
« Reply #10 on: Sat, 05 December 2009, 06:02:32 »
We were firing up an old Sparcstation 5 we found in college yesterday, and I was cleaning it's Type 5 keyboard. I had opened it up and was surprised to see how very Model M-like the construction of the keyboard assembly was. One major difference (and  improvement) though - the Type 5 has screws instead of plastic rivets.
Sun Type 5c
« Reply #11 on: Sat, 05 December 2009, 06:59:24 »
Quote from: rdjack21;134833
I don't have much experience with Sun Microsystems computers (SunOS, Solaris) but these Topre sun keyboards work with an IBM-compatible system?
Offline ch_123
Sun Type 5c
« Reply #12 on: Sat, 05 December 2009, 11:36:10 »
Nope, they use a Sun-only connector. You can get an adaptor though, but it would just be better to get the PC equivalent.
Also, those things would be sell for over $100, a bit out of your price range =P
Offline rdjack21
Sun Type 5c
« Reply #13 on: Sat, 05 December 2009, 14:18:38 »
Quote from: ch_123;139105
I have yet to find a PC equivalent for the US layout one. Which is why I got it.
The keyboard is out of his price range much less the adapter.
EDIT: forgot to add yes you can make them work on PC equipment with an adapter
« Last Edit: Sat, 05 December 2009, 14:20:49 by rdjack21 »
Keyboards
Black Alps: ABS M1
Offline ch_123
Sun Type 5c
« Reply #14 on: Sun, 06 December 2009, 05:13:21 »
Which Sun system was that thing for?
Sun Type 5c
« Reply #15 on: Sun, 06 December 2009, 11:19:12 »
That's more like 7 bits out of my price range.
