Author Topic: Finished Painting My White/Blue Splatter TKL!  (Read 2122 times)
Offline x9Memoriez
« on: Sun, 20 December 2015, 03:04:18 »
GH!
Just finished my first attempt at spray-painting anything, and it turned out pretty well. Apart from a mark or two at the corners and the stripe not being completely sharp, it came out alright! Now the only question is.. What keycap set would even fit into this?
Matrix 1.2OG | Constellation | Rukia | TMO50 | HHKB
Re: Finished Painting My White/Blue Splatter TKL!
« Reply #1 on: Sun, 20 December 2015, 03:37:42 »
Not bad :)
How about Triumph Adler, or Raindrop?
Offline x9Memoriez
« Reply #2 on: Sun, 20 December 2015, 05:52:25 »
Not bad :)
Cheers for the read and suggestion c:
Wallet is kind of light at the moment so I settled with the darker blue of the NPKC PBT blanks, that should be coming in two weeks. I'll update this thread after those come. (Hopefully not too much of a necro)
The paint bleed on the straight line is killing me, so I'm going to go over it again. And this time seal the painters tape. Sigh.
