Author Topic: Landing pads for Cherry profile?  (Read 2177 times)
Offline Harms
« on: Mon, 21 December 2015, 03:07:57 »
Hi guys, got my varmilo in today and it came with cherry profile caps which are amazing. however, I usually use the 1.5mm (pink wasd o rings). I put them on the cherry profile switch and it reduces the travel way to much. This is also the smallest o ring variant on the market. Do you guys think soft landing pads by EK would help. I heard they dont reduce travel as much as these o rings. :O
Offline ceflame
Re: Landing pads for Cherry profile?
« Reply #1 on: Mon, 21 December 2015, 04:07:04 »
Just tested out some landing pads side by side with o-rings. The travel reduction is similar, if not the same.
Though, the landing pads have softer/springier bottom out compared to the more solid bottom out of the o-rings.
Offline Harms
« Reply #2 on: Mon, 21 December 2015, 11:31:27 »
Thanks for the input :)
Offline ideus
  • Björkö.
« Reply #3 on: Tue, 22 December 2015, 12:23:46 »
You may try the trampoline mod using silicone balls.
Offline asgeirtj
Leopold FC900 w/ 67g Purple Zealios - Silver Duck Octagon w/ 62 Purple Zealios
