Author Topic: TX87 PCB, instructions  (Read 6470 times)
Offline henz
  • What?
« on: Mon, 21 December 2015, 09:20:16 »
Yello, im having some issues getting the RGB leds to work on the TX87 PCB, creating this thread in order to document my findings because all current info is either in korean or non existent. might be so that my PCB is defect or smth but im starting this under the premise that it is not.
If you have the pcb up and running with RGB leds, please provide info.
Offline Steezus
  • Keeper of Facts
Re: TX87 PCB, instructions
« Reply #1 on: Tue, 22 December 2015, 00:41:47 »
I have the TX87 PCB but have not yet tried any of the RGB LEDs, what is the current issue that you're having? I'm assuming that you're using Leeku's JigOn firmware to program it as well?
Offline henz
  • What?
« Reply #2 on: Tue, 22 December 2015, 02:02:11 »
i got some time yesterday to test away, and got a tip from yuktsi, figures you need all the rgb leds connected for it to work properly, hence also adding leds on RGB 1 and 2 which are located above the arrow cluster on the top side of the pcb, so i had to attach wires to the bottomside holes of the rgb connections to test it, yesterday when i connected everything i got 4 leds to work, seems i have not attached nr5 properly or the led is broken or smth.
Offline Steezus
  • Keeper of Facts
« Reply #3 on: Tue, 22 December 2015, 11:24:04 »
Glad to see you're getting a few issues fixed. The TX87 is a good PCB but it does have its faults. I was having problems with my LEDs until I found out the one faulty one I had as well, and also misplaced a resistor on an unused pad. We should be getting the diffuser relatively soon as well so it won't be long before I dive into the trying the RGB LEDs as well. Sorry I'm not much help at the time being but if you're still having problems when I test mine out, I'll get back to you.
Offline henz
  • What?
« Reply #4 on: Fri, 01 January 2016, 05:28:53 »
thats ****ed up... so you cnat solder on resistors in unused places? i guess i have to open up my board again ;( How did you figure out what was wrong?
Offline Steezus
  • Keeper of Facts
« Reply #5 on: Fri, 01 January 2016, 12:36:51 »
Oh sorry I apologize, I wasn't too clear. I accidentally soldered on a resistor on a pad that was going to be unused compared to the one that I needed. You can you can solder them on the whole board if you like but obviously there are certain ones that aren't necessarily depending on your layout.
Offline yuktsi
  • Colour my life with the chaos of trouble
« Reply #6 on: Sat, 02 January 2016, 11:12:36 »
Hello Henz, you will need to solder a bridge at rgb1 and rgb2. This issue is fixed for the CE pcb.
« Last Edit: Sat, 02 January 2016, 11:15:24 by yuktsi »
email: yuktsi@ttggrr.cc
My collection
Poker 2 | LZ CE | Leopold FC700R | KMAC 1.2 | EXE | GON NS87 | GON Nerd TKL | Duck Poker | Duck Orion | Realforce 87u 55g | OTD 456GT | LZ B7 | OTD 360C | Ducky G2 Pro | Apple Extended | Apple M0116 | Apple M0116 | Cherry G80-1220HAD | Duck Octagon | HHKB Pro 2 | Duck Unicorn | LZ B8 | LZ RE | ENVKX | OTD 456GT | LZ FE | HHKB Type S | TX1800| Duck Orion V2 | LZ FE | KPad | KMAC Happy | ENVKX | LZ RV | KMAC 2 | Whale | Dolphin | EM7 | TGR Jane | VE.A | DK Saver | Matrix 10xv1.0 | Whale | HHKB BT | Dolphin v2 | EM7 v2 | SSK | SSK (Blue Label) | LZ SQ | Duck Octagon v2 | TX84 | GON Mobik | TX-CP | LZ Ergo2 | KMAC Happy HHKB | TGR 910 | TGR Tris | Matrix 8xv1.2 | KMAC Mini | Mira | Fjell | 356mini | Dolphin GH | EM7 GH | TARO EXENT | Masterkey Pro L Crysta l OTD Koala | Duck Viper | Keycult no.1 | 356mini | 356pad | Matrix 8xv2.0 | 420cl | Matrix 8xv1.0 | Whale Special | Poly Dolphin | Keycult No.2 | FMJ80 | Singa R2 | Whale Poly | 356cl | HBCP | Dolinger | Linger | FMJ80 | KFE
Offline henz
  • What?
« Reply #7 on: Sat, 02 January 2016, 13:26:12 »
Saw your post in the GB thread, ill update op with things when i get the time. Been som hectic days.
Btw another issue i have encountered, I can't seem to change the LEDs away from WASD+ arrow cluster . not sure what I'm doing wrong :(
Offline leeku
« Reply #8 on: Fri, 08 April 2016, 06:32:25 »
Hi all, maybe I should follow here.!
It is not only for TX87 but comonly for all PCBs prefixed L3,
SK, Compact, MX1800(L3 version).....
Offline yuktsi
« Reply #9 on: Fri, 08 April 2016, 06:36:20 »
thank you boss  :D
My collection
