Author Topic: Fixing an SP c(r)ap  (Read 2572 times)
Offline KaminKevCrew
Fixing an SP c(r)ap
« on: Mon, 21 December 2015, 20:29:25 »
So, I recently bought an SP crap bag from one of the other users on this forum.
Never had a crap bag, so I figured I would get it when I could! Anyway, after having it for a few days, I was going through it today and found a very cool cap (note: I had already fixed the cap when I took this picture.): 121142-0
Unfortunately, it had this issue:121144-1
As you can see, the stem was too big!!! Anyway, I attempted to put it on a switch, but that wasn't working at all, since the stem was simply way too thick. As such, I got out my jeweler's (a.k.a small) filing kit: 121146-2
So, once I had those out, I proceeded to file the stem down (starting is the worst part, once you get the muscle memory down, it's not so bad):121148-3 The file is not in the position that I was filing in that photo, that's just how it ended up on my hand :)
One side done:121150-4
Second side done: 121152-5
Bonus shot of the amount of dust that filing one side creates(!):121154-6
And here it is once I cleaned the inside of the cap: 121156-7
It almost looks like the ABS powder dissolved into the alcohol on the cotton swab - does anyone know if that's a thing?
So the first picture is the finished product, but here it is again! 121158-8
Hopefully all of those turned out the right way around. Geekhack has been in the habit of rotating my photos lately. If they are upside down, I also have the photos hosted on imgur, so I'll link that if necessary!
This cap will eventually end up on a Planck with a unicorn puke, single row profile SA set :) (aka all of the caps will be at the same 0 degree incline, but they are of the SA profile, I believe, unless I've seriously missed something!)
Offline ideus
  • Björkö.
Re: Fixing an SP c(r)ap
« Reply #1 on: Tue, 22 December 2015, 10:52:53 »
That is too much work for a single cap. I have never understood the idea of paying for SP's scrap, and see it as an curious case when a company can profiting on its own bad parts and obsolete stock.
« Reply #2 on: Tue, 22 December 2015, 11:08:25 »
I mainly just wanted to have some spare keys that I can use without needing to take special care of them. Also, for a single key, I think it's fine. I wouldn't do that with an entire board, but for the one key, I thought it was pretty fun! Also, a lot of the caps in the basement are actually in pretty much perfect condition and I don't really understand why they're in the crap bag.
