Author Topic: New Build Atreus62 (60%)  (Read 8094 times)
Offline profet
« on: Mon, 21 December 2015, 22:02:54 »
Decided to start my first hand wired build over my upcoming vacation.
Build parts arrived today.
Sneak preview:
Building this larger Atreus for my wife. She wanted something smallish but took a look at the Atreus images online and decided she couldn't get used to a 40% board. So this is the compromise.
I'm excited to see how it'll turn out.
Using a Pro Micro as the controller.
Bringing custom Ergodoxes to the masses.
My heatware: http://www.heatware.com/u/102649
Offline Rhedone
Re: New Build Atreus62 (60%)
« Reply #1 on: Tue, 22 December 2015, 04:59:00 »
Looks cool, the casing is gonna be completely wood? and what switches are you planning on using?
looking forward to the build logs ^^
Offline profet
« Reply #2 on: Tue, 22 December 2015, 08:51:21 »
The case is 5 layers of Cherry veneer MDF that are 3.5mm thick.
Top layer
Plate
2 Spacers
Bottom
For a total of 17.5mm thickness.
I'm going to be using Cherry MX Clears.
Offline MrRooks
  • Always be knolling
« Reply #3 on: Tue, 22 December 2015, 09:14:43 »
Cool! What is the overall width on this?
Offline profet
« Reply #4 on: Wed, 23 December 2015, 16:14:18 »
Integrating the diodes into the switches, thinking (hoping?) that it'll give me a cleaner matrix in the end.
Offline profet
« Reply #5 on: Wed, 23 December 2015, 16:16:35 »
293mm at its widest point
Offline profet
« Reply #6 on: Thu, 24 December 2015, 12:10:37 »
Switches hot glued in place. Rows wired up.
Offline profet
« Reply #7 on: Fri, 25 December 2015, 12:11:23 »
Columns done. Integrating the diodes came out nice and clean.
Offline neverused
« Reply #8 on: Fri, 25 December 2015, 13:55:21 »
It really does keep things cleaner, I've done it myself and was pleased with how it simplified the look of the final matrix.
Nice job so far.
Offline Steezus
  • Keeper of Facts
« Reply #9 on: Fri, 25 December 2015, 15:11:08 »
Very clean looking wiring you have there! :thumb:
In-switch diodes do clean things up a bit, however I have seen some clean builds as well where people have opted to keep the diodes outside of the switch. Either way nice job!
Offline profet
« Reply #10 on: Sat, 26 December 2015, 16:11:30 »
Decided to get a little messy for the sake of maintenance and added right angle headers to the microcontroller and then used female jumper wire to connect the matrix.
Offline profet
« Reply #11 on: Sat, 26 December 2015, 16:12:38 »
All closed up and working perfectly... just need to add some keycaps:
Offline TalkingTree
    • My projects
« Reply #12 on: Sun, 27 December 2015, 03:32:38 »
Nice work. Did you use TMK with the Pro Micro?
Offline profet
« Reply #13 on: Sun, 27 December 2015, 08:58:57 »
Yeah... Still deciding on layout.
Offline profet
« Reply #14 on: Sun, 27 December 2015, 16:49:19 »
These are the keycaps my wife chose... waiting on some blanks to show up so I can get rid of some of the odd keys... (that "6" key for "Tab" really irks me)
Offline f1xedgear
« Reply #15 on: Sun, 27 December 2015, 17:25:39 »
I like it! I just got that set for Christmas (also chosen by my wife :) )
Offline cribbit
« Reply #16 on: Wed, 01 February 2017, 20:14:10 »
Apologies for the necro.
Can you detail how you integrated the diodes into the switches? I've seen rumors of it around but only seen it on switches specifically designed for it. My google-fu is weak, so I can't seem to find more info on how to do it with run of the mill cherry switches. Tried examining your pictures closely but can't quite see what to look for.
I typed this post on my Slanck. I also developed a stronger, cleaner, easier handwiring method.
Offline profet
« Reply #17 on: Wed, 01 February 2017, 20:27:08 »
All MX style switches support in switch diodes. Open the switches put the diodes inside. The legs should stick out the outer most holes in the switch housing.
Offline cribbit
« Reply #18 on: Wed, 01 February 2017, 21:52:10 »
Ah, that's what I thought from the pictures but wasn't quite sure. Thanks!
