Author Topic: Pok3r right-shift returns?  (Read 3628 times)
Offline krbuck
« on: Tue, 22 December 2015, 10:01:15 »
I have a relatively new Pok3 (about 3 months or so) and have just loved it. However, just the last few days, the right-shift key seems to map to return (not line-feed or enter but return to beginning of line).
I've tried resetting to factory defaults, but it still does it. I'm not sure if it is something in the OS (Windows 10) or if it is the keyboard. All the dip switches are off (default) btw.
I get the feeling this is a dumb question, but pretty frustrated.
Thoughts?
POK3R - Brown Cherry MX
Offline MeltingTeeth
Re: Pok3r right-shift returns?
« Reply #1 on: Tue, 22 December 2015, 10:41:14 »
Try another keyboard.
Offline ideus
  • Björkö.
« Reply #2 on: Tue, 22 December 2015, 11:27:21 »
You may meant home not return. Have you checked the soldering of that switch?
Offline Rayoui
« Reply #3 on: Fri, 25 December 2015, 09:04:49 »
Thoughts?
You may have accidentally reprogrammed the Right Shift key as a Home key. Select whichever FN layer is having the issue and hold FN + R. The LED under the spacebar will flash for five seconds and then that FN layer will be restored to the factory keybindings.
Mira SE  |  Clueboard  |   B.face  |  HHKB Type-S
Offline jcoffin1981
« Reply #4 on: Fri, 25 December 2015, 21:27:30 »
He did say he already restored to factory defaults.
Offline krbuck
« Reply #5 on: Mon, 28 December 2015, 13:45:30 »
Yes, I may have a problem with it. I wonder if there is a way to reprogram my way out of it though. Got to mess with it. Real hassle using just the left shift key.  :rolleyes:
Offline krbuck
« Reply #6 on: Tue, 29 December 2015, 09:40:07 »
Ok, it looks like a flash of the new firmware helped! I know because I used the right shift key to create that exclamation point and the cursor didn't return to the beginning of the line.
Odd, but I'm happy. Thanks to you guys that gave it some thought.
