Author Topic: Carbon Fiber skin for CM Storm keyboards  (Read 23181 times)
Offline codywanks
« on: Tue, 22 December 2015, 15:39:20 »
Hey guys,
I recall seeing Imgur photos of some dude who DIY skinned his QFR-i with this material. Unfortunately I'm no longer able to find the original link.
Is there anybody here who can make this in the form of a pre-cut sticker kit, so noobs like me can use it on my CM Storm keyboard?
Cheers!
Offline Auxo
  • Formerly CJD_Anthony
Re: Carbon Fiber skin for CM Storm keyboards
« Reply #1 on: Sat, 23 January 2016, 17:05:14 »
You're just looking for Carbon Fiber vinyl.
The highest quality vinyl you can get will be DI-NOC by 3M
cheers
Offline codywanks
« Reply #2 on: Sun, 24 January 2016, 07:07:27 »
cheers
Yes, that looks correct, but I'm looking for something pre-cut (just peel & apply) and would be willing to pay for it
Offline ander
  • I type, therefore I am
« Reply #3 on: Tue, 16 February 2016, 21:27:41 »
Doesn't it kind of defeat the purpose, though, using something that just looks like CF rather than actually being it? And how are you going to handle the corners convincingly?
Offline codywanks
« Reply #4 on: Thu, 18 February 2016, 23:11:47 »
Dunno, maybe it is actually CF?
I suppose the seams will be visible on the corners.
Here's an example of somebody who did the mod, though not on a Novatouch
Offline tomrhawk
« Reply #5 on: Thu, 03 March 2016, 05:33:52 »
You could always try hydro dipping it like in this video
