Author Topic: [IC] Golbat 40% keyboard - Mini HHKB style available!  (Read 74616 times)
Offline FoC_Tow
  • Brokehlicious
Re: [IC] Golbat 40% keyboard - Mini HHKB style available!
« Reply #50 on: Tue, 29 December 2015, 05:32:53 »
Looks great, definitely in for one too!
Really have to join the 40% club at some point and this seems like the perfect time to! :)
Offline heedpantsnow
  • Old enough to know better
« Reply #51 on: Tue, 29 December 2015, 06:38:02 »
Is it possible to order only a pcb?
If you only want a PCB then you might just want to order it from Taobao directly. Would be faster and maybe cheaper.
I'm back.
Offline GL1TCH3D
« Reply #52 on: Tue, 29 December 2015, 09:38:59 »
There are over 100 responses to the IC form now so I'm going to see with GFW if it will be possible to extend the number of units for this. (Or do multiple rounds to avoid having $10000 caught up in one order and being at high risk)
As for the programming, I have to build it first before I can tell you how easy it is. Waiting on the stabilizers!
Yea. The regular layout board is available on taobao but shipping and proxying can be expensive. There's really not much of a deal on the kit itself but GFW said that the HHKB-style plate would only be available when buying in 5+ so that, along with the diluted proxy and shipping costs, is what makes this buy more interesting than just buying directly. If you just want the PCB it would be definitely faster to just order it yourself.
Definitely in for one. Can't have too many 40% boards.
I do have a question about the bottom row, though. I assume the bottom fits 1.25u keys for the three switches on either side of the spacebars. What size would the spacebars need to be? 2.25u each?
Bottom row is 1.25, 1, 1.25, 6.25, 1, 1.25
Or 1.25, 1, 1.25, 2.25, 2.75, 1.25, 1, 1.25
The HHKB layout drops the 1.25 at both ends.
« Last Edit: Tue, 29 December 2015, 09:55:22 by GL1TCH3D »
Offline livingspeedbump
    • KeyChatter
« Reply #53 on: Tue, 29 December 2015, 11:52:36 »
Glad to hear there is so much interest in this! If you need any help anytime just let me know!  :thumb:
<- My Collection (so far)
Offline thecolorblind1
« Reply #54 on: Tue, 29 December 2015, 14:38:52 »
Thanks for doing this. I've been wanting to build a 40% for a while and this just looks so cool!
Offline sircheddar
« Reply #55 on: Wed, 30 December 2015, 00:26:26 »
Woah, in for one, keep me updated!
" I hope that when the world comes to an end, I can breathe a sigh of relief, because there will be so much to look forward to. "
Offline OTD
« Reply #56 on: Wed, 30 December 2015, 00:49:43 »
Looking forward to this and the software it will have. With luck, it will be the same as gon's
Offline KRKS
  • Your friendly neighbourhood umbrella
« Reply #57 on: Wed, 30 December 2015, 04:37:06 »
I'm hoping for multiple rounds because I'm broke right now but would like to buy it in the future.
The increasing power of Massdrop WILL kill the community group buys - don't come crying to me after it happens when you're too stupid to see it now. Join me in saving the community!
MD = NO $, NO EXCEPTIONS
Offline Skuloth
« Reply #58 on: Wed, 30 December 2015, 13:09:01 »
This is really cool. May have to consider getting in on the buy.
Planck w/ Zealios
Offline KoalaKaiser
  • I make onions cry.
« Reply #59 on: Wed, 30 December 2015, 13:50:52 »
This is adorably awesome.
Offline GL1TCH3D
« Reply #60 on: Wed, 30 December 2015, 16:19:42 »
I'll be able to do 50 in the first order and then maybe another 50 in a second order
There are 108 entries right now.
Offline Vadurr
  • Valar Morghulis
« Reply #61 on: Wed, 30 December 2015, 16:47:37 »
MMmmmmmm tempting...  :rolleyes:
Offline Waateva
« Reply #62 on: Wed, 30 December 2015, 21:09:23 »
Love the HHKB design
Offline SlamnFunc
  • Change is inevitable
« Reply #63 on: Thu, 31 December 2015, 08:51:10 »
I'm in for purple with both plates styles and acrylic middles  :cool:
Offline AlexFromPanc
  • Competence
« Reply #64 on: Thu, 31 December 2015, 12:31:16 »
I'm in! Looks super-tight and I'm looking forward to a KB I can fit in the cargo jorts.
Offline cheddarbek
« Reply #65 on: Thu, 31 December 2015, 15:46:16 »
I don't think I noticed the Google form earlier. Filling it out now.
The Alps cover 65% of Switzerland's surface area (41,285 kmē), making it one of the most alpine countries. Despite the fact that Switzerland covers only 14% of the Alps total area (192,753 kmē),[2][3] many alpine four-thousanders (48 of 82) are located in the Swiss Alps and practically all of the remaining few are within 20 km of the country's border.
Offline GL1TCH3D
« Reply #66 on: Thu, 31 December 2015, 15:52:42 »
You came to the right place :P
Offline Skuloth
« Reply #67 on: Thu, 31 December 2015, 16:01:54 »
There are way too many acrylic color options.
I want all of them.
Planck w/ Zealios
Offline wilarseny
« Reply #68 on: Thu, 31 December 2015, 17:13:02 »
Just to confirm, the PCB probably doesn't support SMD LEDs, does it? So if we wanted underlighting we'd have to just use regular 2-pin flipped downward?
Offline nathanrosspowell
    • nathanrosspowell.com
« Reply #69 on: Thu, 31 December 2015, 17:38:59 »
No it doesn't, there are only holes for in-switch LEDs.
Now with that said, I hung out with GL1TCH3D and we semi-tested out this theory. I heard the guys on the Boardmakers podcast say they soldered SMD LEDs onto the bottom of the PCB on the in-switch holes. Seems that the comonents do line up nicely but it is a less than ideal solder job.
We put in 1.8mm leds upside down in the in-swith hole up there is not enough space to close up the case with them in place - the case really is that tight of a fit! Laying some 3mm x 2mm x 1mm down sideways (so the 1mm is the height) seemed to work, but it would leave some exposed wiring inside the bottom of the case. You can see this post in the "post your 40%" thread where some work has been done to actually achieve this. Remember, if you go for in-switch AND this method it is going to draw more current so the LEDs will be dimmer.
just add some more lights.
update
 change the internal leds to 1206 smd leds. Side light looks to be much better.
Offline rpeterclark
  • RPTR ❌
« Reply #70 on: Thu, 31 December 2015, 18:49:42 »
On a SPRiT PCB anyway, I have soldered both 1206 SMD LEDs to the bottom pads and also had 1.8mm in short SIPs within the switch at the same time. Worked out fine, but you have to be a bit choosey with the LED colors used so that you have enough voltage.
Offline chesho
« Reply #71 on: Fri, 01 January 2016, 18:09:46 »
shipping to europe?
Offline GL1TCH3D
« Reply #72 on: Sat, 02 January 2016, 15:39:57 »
Offline SlamnFunc
« Reply #73 on: Sun, 03 January 2016, 01:01:55 »
I should ask too, shipping to Australia?
Offline GL1TCH3D
« Reply #74 on: Sun, 03 January 2016, 01:05:53 »
The same or more compared to europe. $60 tracked but I could probably pass it as $20ish untracked
Offline Waateva
« Reply #75 on: Sun, 03 January 2016, 07:33:28 »
Damn, you were right.  Expensive   :(
Offline sircheddar
« Reply #76 on: Sun, 03 January 2016, 21:20:08 »
hey glitched, had a question. can you post the colors of the alu plates? i can see the acrylic but i am wondering specifically what the pink would look like!
« Reply #77 on: Mon, 04 January 2016, 05:15:59 »
The pink is pictured already in the OP.
It would be good to get some idea of the other colors though
Offline sircheddar
« Reply #78 on: Mon, 04 January 2016, 08:04:13 »
oh ok, thanks. i was thinking that but wanted to make sure. i 2nd what you said tho!
Offline sypl
« Reply #79 on: Mon, 04 January 2016, 08:55:26 »
Quick Q, what do you call those screws that fit flush to the case? I'm sure they have a name but I dunno what it is. Thanks.
« Reply #80 on: Mon, 04 January 2016, 08:56:10 »
Countersink
Offline mun2912
« Reply #81 on: Mon, 04 January 2016, 09:29:40 »
can you make this with bluetooth? i'm really interested in kb with bluetooth build in :D
Offline sircheddar
« Reply #82 on: Mon, 04 January 2016, 09:44:59 »
I think it could be modded to Bluetooth if you are skilled. But for this, I think he is shooting for a lower price point which makes me think he wouldn't try.
Offline mun2912
« Reply #83 on: Mon, 04 January 2016, 09:58:06 »
yeah i don't expect too :D i just wanna ask if there is a chance for it
« Reply #84 on: Mon, 04 January 2016, 10:14:32 »
This Golbat seems to use a different controller board, but someone could probably figure out how to connect it to a BT module.
40% keyboard with BT add-on: https://geekhack.org/index.php?topic=62641.msg1921653#msg1921653
« Reply #85 on: Mon, 04 January 2016, 11:14:01 »
You'd probably need a different case if you wanted to add a BT module. There is very little spare room in this one  :)
Offline GL1TCH3D
« Reply #86 on: Tue, 05 January 2016, 18:48:56 »
Should be going back to Nathan's place this week to finish soldering it and I'll flash it to make sure I can help with doing so when the time comes.
Here are the aluminium color samples
« Reply #87 on: Tue, 05 January 2016, 18:53:50 »
Is the pic broken for anyone else?
Offline GL1TCH3D
« Reply #88 on: Tue, 05 January 2016, 18:56:49 »
Updated all information that I have right now to the original post. I see it fine on my end but if you're having trouble try this link:
http://tieba.baidu.com/p/3846116074
Offline rpeterclark
  • RPTR ❌
« Reply #89 on: Tue, 05 January 2016, 19:53:10 »
I am so ready for this! The JD45 looks great too, but I'm really into this this case design.
« Reply #90 on: Tue, 05 January 2016, 20:02:37 »
That works!
Is that yellow/gold color a choice as well?
Offline GL1TCH3D
« Reply #91 on: Tue, 05 January 2016, 20:06:06 »
That works!
I was told any of the colors in the first picture should be fine
« Reply #92 on: Tue, 05 January 2016, 20:07:38 »
That works!
They're all so pretty...and so much acrylic. Really should build two! Haha
There's a sparkling gold looking acrylic I think I'll sandwich in between green.
Offline GL1TCH3D
« Reply #93 on: Tue, 05 January 2016, 20:11:05 »
That works!
Lots of options so choose carefully!
I'll be receiving some spare parts in the GB in the case of damaged parts or I'll add in specific parts that were damaged in R2, if any do get damaged.
I'm wondering if I have to limit how many units people can order to make sure as many people can join as possible...
« Reply #94 on: Tue, 05 January 2016, 20:56:59 »
Picture is working fine for me.
I was set on getting mo' purple in my life... but... maybe I need to upgrade my BALLIN' status with some of that gold   :eek: :eek:
    • KeyChatter
« Reply #95 on: Tue, 05 January 2016, 21:20:28 »
Im going to have to mull over colors from now until ordering  :confused:
Offline cheddarbek
« Reply #96 on: Tue, 05 January 2016, 21:28:24 »
So...no red aluminum like in the OP? ️
    • KeyChatter
« Reply #97 on: Tue, 05 January 2016, 21:30:18 »
or black?
Offline GL1TCH3D
« Reply #98 on: Tue, 05 January 2016, 21:45:54 »
The "red" in my pictures is actually just crappy lighting on the pink alu
http://i.imgur.com/ZzwWk53.jpg
Offline cheddarbek
« Reply #99 on: Tue, 05 January 2016, 22:54:56 »
No black though?
