Author Topic: IKBC NEW TKL WITH PBT KEYCAP AND CHERRY MX SWITCH  (Read 9740 times)
Offline xuanwumen
  • * Commercial Vendor
    • EZKB
« on: Fri, 25 December 2015, 01:47:57 »
AS TITLE.
NIZ KEYBOARDS VENDOR
Offline Harms
Re: IKBC NEW TKL WITH PBT KEYCAP AND CHERRY MX SWITCH
« Reply #1 on: Fri, 25 December 2015, 03:19:23 »
Looks nice but it doesn't seem to stand out from all the other TKL options out there.
Offline x9Memoriez
« Reply #2 on: Fri, 25 December 2015, 03:45:01 »
If I recall correctly, the IKBC F-104 , a full size board, had thick double shot PBT caps and came in at 105 Aud, which is about 70-75 USD off the top of my head. If this board comes in at 10$ less, it would be a fantastic deal.
Matrix 1.2OG | Constellation | Rukia | TMO50 | HHKB
Offline Harms
« Reply #3 on: Fri, 25 December 2015, 04:06:27 »
That seems cool, what switches does it use :O
Offline x9Memoriez
« Reply #4 on: Fri, 25 December 2015, 05:33:05 »
The IKBC F-104 definitely uses the cherry variety. I don't think clears, greys or greens were available however, just the usual blues, reds, browns and blacks.
Offline asgeirtj
« Reply #5 on: Fri, 25 December 2015, 07:22:16 »
This probably uses cherry stabs, which aren't available in any any nonled board except for kul afaik, so it would be a great cheap option for a cherry stab tkl, and for some it might be more aesthatically pleasing than a kul since it seems to be more simpler case design.
Leopold FC900 w/ 67g Purple Zealios - Silver Duck Octagon w/ 62 Purple Zealios
Offline Lepidus
« Reply #6 on: Fri, 25 December 2015, 07:34:40 »
Looks just like ikbc g87: http://ikbc.com.cn/G87.html#3rd
The good thing about G87 is that it has PCB holes for leds, although im not really sure if they sell factory backlit ones. Maybe this one has too.
Offline TalkingTree
    • My projects
« Reply #7 on: Fri, 25 December 2015, 07:34:54 »
It can be bought here.
Offline derb2k2
  • Something of a Topre ****..
« Reply #8 on: Fri, 25 December 2015, 07:39:58 »
those PBT caps look decent but it would be nice to see the thickness  :)
HHKB | RF 45UB | Novatouch | Poker II Blue | QFR Browns | Rosewill RK-9000RE
Offline xuanwumen
    • EZKB
« Reply #9 on: Fri, 25 December 2015, 07:41:22 »
Cherry mx brown, blue, black. Red and clear to be expected..
Offline xuanwumen
    • EZKB
« Reply #10 on: Fri, 25 December 2015, 07:42:55 »
This one is also available for LED DIY...
Offline nocturalowl
« Reply #11 on: Fri, 25 December 2015, 15:59:35 »
The white one looks nice. Is that cap laser marked or dye sub?
Offline xuanwumen
    • EZKB
« Reply #12 on: Sat, 26 December 2015, 08:35:35 »
Laser~~
