Author Topic: Does anybody know the mini size flash drive that is working on HHKB usb hub?  (Read 2971 times)
Offline Jaaaaaaaaaaaaaaaaaaaaaaay
I just want to buy one for saving my documents.
But, any of mine doesn't work because it doesn't has enough supply of electricity.
Ibm model M(Grey lable 1992)
GTune MKF20(kailh Blue)
Happy Hacking Professional 2(Black)
Realforce 87UB(Black)
Realforce 87UW45(White)
RC930 - 104 RGB(55g)
Filco Majestouch2 Tenkeyless(MX Brown)
Offline fanpeople
I had an old 1 gb usb that worked. That was just a generic one branded with an electonic stores details i think its anything under 200 miliamps?
I haven't managed to get anything working through my HHKB USB ports.
I've just managed to find a drive that works - it's an old 2gb "Corsair Readout" so far from mini but does prove it's possible.
If you want a low powered drive I'd suggest getting an OTG one designed for phones, they should be nice and small too.
really? i've had my cst trackball plugged in no problems same with other mice
I tried a couple of Microsoft mouses and half a dozen USB memory sticks and nothing worked.  I just use a powered USB hub now.
Offline fanpeople
Oh wow, i just plugged mine in and works like a charm. Mouse didnt though from recolection.
Offline Cicada88
My Zowie mouse works alike a charm--never tried a memory stick though
Offline Roibhilin
  • Saver of Humens
my Kingston Datatraveler works fine
QFR | Poker II | Quickfire TK
Could you show me which one that is?
Amazon link or whatever. plz!
 wanna buy one right now
Offline x9Memoriez
Re: Does anybody know the mini size flash drive that is working on HHKB usb hub?
« Reply #10 on: Tue, 29 December 2015, 05:17:19 »
Since some USB's wont even be detected, am i right to safely assume a xbox controller wont detect at all?
Matrix 1.2OG | Constellation | Rukia | TMO50 | HHKB
Offline Roibhilin
  • Saver of Humens
« Reply #11 on: Tue, 29 December 2015, 11:22:25 »
i think it's legacy because i can't find that many places to buy it but here's the newegg link http://www.newegg.com/Product/Product.aspx?Item=N82E16820134043 i hope u find one that isn't out of stock
edit: http://www.overstock.com/Electronics/Kingston-DTI-2GB-DataTraveler-USB-Drive-Case-of-2/3398915/product.html found it
Offline JimByr
  • ...old guy...
« Reply #12 on: Tue, 29 December 2015, 13:48:34 »
I have several different 2Gb flash drives and a 4Gb flash drive that work. Anything 8Gb or larger fails.
« Last Edit: Tue, 29 December 2015, 13:50:49 by JimByr »
« Reply #13 on: Wed, 30 December 2015, 04:50:56 »
I've tried few 2.0  2, 4gb, and 3.0 4gb but everything failed
