Author Topic: Wired USB Cable wrong and fried my Leopold Numpad  (Read 3301 times)
Offline breitling
« on: Thu, 31 December 2015, 14:13:23 »
Hey guys, wondering if anyone can provide some insight here.. I was too tired when I wired my new USB cable and got the V- and V+ mixed up and fried my Leopold Numpad when I plugged it in (I also did a detachable cable mod to it a while back). I looked at the PCB and it looks like the Capacitor(?) at C10 is the one that smoked out and turned black. Not sure if the controller is still ok. I have fried some IC's before on other non-keyboard projects and I knew right away I fried this when I smelled the burnt out parts. If I replace the C10 cap is it likely to fix the problem do any of you know? Would like to salvage this if possible. I found a pic of the original C10 and it looks orange, and I can't see the writing on it and don't know the value of the Cap. Can anyone help?
Here are some pics.
Offline nathanrosspowell
    • nathanrosspowell.com
Re: Wired USB Cable wrong and fried my Leopold Numpad
« Reply #1 on: Fri, 01 January 2016, 16:32:23 »
I believe the code on the part to be:
Code: [Select]
106C
10J34
It was too hard to capture with my cell phone :)
Offline breitling
« Reply #2 on: Fri, 01 January 2016, 17:42:08 »
Thanks so much! This means it should be a 10uF 5% cap. I will report back and let everyone know how to goes for posterity.
Offline breitling
« Reply #3 on: Tue, 02 February 2016, 23:22:00 »
My capacitors finally arrived and I soldered one in and bam! Works like a charm! In case anyone else wires one of these backwards on the USB you know you can fix it :)
Offline 0100010
  • Not Sure
« Reply #4 on: Wed, 03 February 2016, 17:37:03 »
Always refreshing when one posts a followup!
« Reply #5 on: Wed, 03 February 2016, 20:23:46 »
Thanks for verifying and glad it worked out for you  :thumb:
Offline breitling
« Reply #6 on: Wed, 03 February 2016, 21:29:33 »
Thanks for your help! Couldn't have done it without you taking the time to check it out for me.
