Author Topic: Metal Case interfering with PCB?  (Read 2193 times)
Offline dohbot
« on: Fri, 01 January 2016, 17:46:00 »
Hey friends! I just changed my case with my FC660M to a metal one and it is now interfering with the letters it spews out. for example R make R3 sometimes pressing space hard makes R3 and pressing 4 or 5 makes 45y. I guess that I need to put something between the PCB and case but what should that be?
Re: Metal Case interfering with PCB?
« Reply #1 on: Fri, 01 January 2016, 17:52:17 »
If the switches are shorting on the case you don't have much thickness to play with, maybe try some electrical tape?
Offline dohbot
« Reply #2 on: Fri, 01 January 2016, 17:57:00 »
I just cut some notebook paper and trying to fit the keyboard in now. If that doesn't work I will try some electrical tape in a moment
Offline dohbot
« Reply #3 on: Fri, 01 January 2016, 18:14:28 »
Fixed it!
« Reply #4 on: Fri, 01 January 2016, 19:10:27 »
Fixed it!
Great!
For the benefit of people searching this problem in the future was the paper a success or did you need tape?
Offline dohbot
« Reply #5 on: Fri, 01 January 2016, 19:14:36 »
Fixed it!
Great!
Right, the paper did work but it took some careful cutting and a lot of reseating.
