Author Topic: What switches are these and what should I do with them?  (Read 2273 times)
Offline c12rlpac
« on: Fri, 01 January 2016, 23:44:05 »
« Last Edit: Fri, 01 January 2016, 23:47:45 by c12rlpac »
Re: What switches are these and what should I do with them?
« Reply #1 on: Fri, 01 January 2016, 23:51:30 »
Looks like Futaba linear.
Offline chyros
  • a.k.a. Thomas
  • Hello and welcome.
« Reply #2 on: Sat, 02 January 2016, 06:22:08 »
That's what I thought so on first sight, but I don't think so. The rectangular slider bar doesn't look like it's there and the upper retaining clips are nowhere near straight enough.
Offline SamirD
« Reply #3 on: Sat, 02 January 2016, 08:58:33 »
I have to lean towards this as well, although the housing shape is a bit different and it is difficult to tell if the rectangular slider bar is there or not.
Offline chyros
  • a.k.a. Thomas
« Reply #4 on: Sat, 02 January 2016, 09:12:21 »
I'm convinced it's not them. They don't look like them, and the keyboard seems to modern for vintage Futabas.
I'm pretty sure they're Mitsumi standard mechanical switches.
As for what you should do with them; give them to me! 8)
Offline SamirD
« Reply #5 on: Sat, 02 January 2016, 09:37:36 »
Ah yes, I think you nailed it:
