Author Topic: How to Unlube topre board?  (Read 2061 times)
Offline bocahgundul
  • a seal
« on: Sat, 02 January 2016, 17:27:15 »
Hello guys. I wan't to ask you how do I unlube topre? I use the wrong lube on my board. Can I just wipe it with cloth? I don't want to make the full wash for this board because I just lube this side:
courtesy of brocaps
Offline bocahgundul
  • a seal
Re: How to Unlube topre board?
« Reply #1 on: Sat, 02 January 2016, 18:16:24 »
Someone?
« Reply #2 on: Sat, 02 January 2016, 18:33:17 »
99% Alcohol and a qtip?
Edit: see below, lurch says it's a bad idea
« Last Edit: Sat, 02 January 2016, 20:01:58 by SpAmRaY »
Offline Lurch
« Reply #3 on: Sat, 02 January 2016, 18:49:34 »
i'm pretty sure the slider rails are made out of abs. if that is true, you do not want to use 99% alcohol; it will damage the plastic. you can use rubbing alcohol, but you would have to water it down a bunch.
Quote from: Flyersfan1
Offline appleonama
  • Trollo en USA
« Reply #4 on: Sat, 02 January 2016, 18:53:10 »
courtesy of brocaps
on man thats going to be a pain in the ass lube stays on like a plague and you can't use alcohol on that abs case. I'd just recommend to leave it in a tub of soapy water the lubed will eventually lift off.
Offline Lurch
« Reply #5 on: Sat, 02 January 2016, 18:55:07 »
courtesy of brocaps
i had this thought as well. this method would probably be the 'safer' bet..
