Author Topic: 75% Cherry/OEM profile sets?  (Read 2332 times)
Offline DAVYtm
  • #dateless
« on: Sat, 02 January 2016, 20:52:37 »
I've got a B Mini and will probably pick up the next round of Granite for it, but was wondering if there are any sets in Cherry/OEM profile that will fit the board. Preferring something where all of the rows are the correct profile, not sure if there are any but hoping some 75% users can point me in the right direction
Offline asgeirtj
Re: 75% Cherry/OEM profile sets?
« Reply #1 on: Mon, 11 January 2016, 13:34:11 »
GMK hyperfuse has adapters
also mind that you can use numpad's keycaps like 3, 6 and 9 for use with rightmost column.
maybe jtk 1 also has ones i don't remember, at least jtk2 has the adapters.
the projected gmk classic beige also was supposed to have adapters.
also mind that doing this config: pgup,pgdn,end,delete looks pretty ok.  You could also switch delete out for a fn key for better alignment.
Leopold FC900 w/ 67g Purple Zealios - Silver Duck Octagon w/ 62 Purple Zealios
