Author Topic: HHKB: Windows 7 Shortcut not working?  (Read 2663 times)
Offline GenEric35
« on: Sun, 22 November 2009, 17:21:19 »
Hi, I was thinking of buying an HHKB Pro 2, but would like to know in advance what to expect if indeed the new Windows 7 shortcuts don't work. If someone had win 7 and could test this, would be great.
Here is the link i found with the list of broken shortcuts(this bug could be for the HHKB Lite 2 version only).
http://translate.googleusercontent.com/translate_c?hl=en&ie=UTF-8&sl=ja&tl=en&u=http://www.pfu.fujitsu.com/hhkeyboard/hhkb_support/faq_win7.html&prev=_t&rurl=translate.google.com&twu=1&usg=ALkJrhgRG-GPv1FHpzEATzLSBW3Xo4UNdg
Thanks
« Last Edit: Sun, 22 November 2009, 17:25:05 by GenEric35 »
:target: HHKB Pro 2
IBM Model M 1390131
Unicomp Customizer
Offline AndrewZorn
« Reply #1 on: Sun, 22 November 2009, 18:22:34 »
they dont know what they are talking about, mine works fine (didnt even bother testing them all, sorry)
Offline GenEric35
shortcuts envolving arrow keys
« Reply #2 on: Sun, 22 November 2009, 19:40:20 »
For example, those should work:
【Win】+【↑】
Maximize window
【Win】+【→】
 Maximize the window to the right of the screen
【Win】+【←】
Maximize the window to the left of the screen
【Win】+【↓】
Minimize window
[Win] + [Shift] + [↑]
 Expand the window to the bottom of the screen
【Win】+【Shift】+【→】
 Go to the right monitor
【Win】+【Shift】+【←】
Go to the left monitor
[Win] + [1] -
To start the Quick Launch shortcut that corresponds to the number
« Last Edit: Sun, 22 November 2009, 19:44:10 by GenEric35 »
:target: HHKB Pro 2
IBM Model M 1390131
Unicomp Customizer
Offline AndrewZorn
« Reply #3 on: Sun, 22 November 2009, 19:47:47 »
fn key +
Offline Rajagra
« Reply #4 on: Sun, 22 November 2009, 20:01:51 »
I think this is where lack of n-key rollover is going to bite a lot of people in the ass. Looking at that list of problem key combos, I bet a lot of matrix designs are simply not capable of doing some of them.
The HHKB lite is a 'normal' rubber dome, not capacitive. It doesn't have NKRO. The fact that it needs the Fn key held down just to make what are normally single key presses makes it especially susceptible to this limitation.
The HHKB Pro has NKRO (within USB limits) and should be fine.
Offline AndrewZorn
« Reply #5 on: Sun, 22 November 2009, 20:05:23 »
i thought that for a minute... but win+L?? he has to be doing something wrong
Offline Rajagra
« Reply #6 on: Sun, 22 November 2009, 20:17:23 »
Seems to be the Japanese version that is affected by those simpler combos. Maybe that layout is (more) nonstandard. I didn't even know there was a Japanese version of the Lite.
