Author Topic: Keyboard search: Brown Cherry USB ~$70  (Read 3014 times)
Offline Viett
« on: Sun, 22 November 2009, 18:12:30 »
Does such a board exist? I tried looking for a Cherry G80-3000 but couldn't find a US reseller. Filco is a little pricey, and used boards are not USB. I'm looking for a standard ANSI board.
Keyboards: FKBN87MC/NPEK, Dell AT101W (Black), IBM Model M 1391401 (91) x 2, Deck 82 Fire, Cherry MX8100 (Clears), Siig Minitouch
Layouts: Colemak (100WPM), QWERTY (100WPM) -- Alternative Layouts Review
Offline AndrewZorn
« Reply #1 on: Sun, 22 November 2009, 18:30:52 »
how is a used filco not USB
Offline ch_123
« Reply #2 on: Sun, 22 November 2009, 18:46:03 »
To the best of my knowledge, there are no US layout G80s with brown switches. I've seen German ones, but that's it. I'd recommend a Compaq MX11800 and a USB converter... Probably cheaper than $70.
EDIT: Oh wait, what about that iRocks keyboard? Does anyone know if they are still around?
Offline microsoft windows
  • Blue Troll of Death
  • President of geekhack.org
    • Get Internet Explorer 6
« Reply #3 on: Sun, 22 November 2009, 19:20:01 »
You can get a used PS/2 one and a USB adapter. I've heard some good things about one called the "Blue Cube".
Offline Viett
« Reply #4 on: Sun, 22 November 2009, 19:35:44 »
The board is not for me, and my friend does not exactly was an enormous dirty used PS/2 board with a converter (although I probably would not mind). Used FILCOs are neither cheap nor available, so they're out. I-Rocks boards have terrible layouts and cost $100.
Offline AndrewZorn
« Reply #5 on: Sun, 22 November 2009, 19:36:50 »
so you are basically asking for a filco for $70
EDIT came out more sarcastic than it was meant to
but no its not impossible
i got my filco NEW with the wrist rest for under that
just keep checking ebay
Offline spremino
« Reply #6 on: Mon, 23 November 2009, 03:16:34 »
Get a Compaq MX11800 (Cherry browns), then buy an active adapter for a few bucks.
A long space bar... what a waste of space!
Offline Xero
    • http://www.xeron.cc
« Reply #7 on: Mon, 23 November 2009, 07:11:47 »
afaik the one they sell at datacal.com is the only way you can get a g80-3000 with browns. I think it's considered a custom-order
keyboards: cherry g80-3000 w/browns, das III, compaq mx11800, 2xblack dell at101w, nec apc-h412, black unicomp 101, ibm soft touch (greased buckling spring), model F AT, ibm model M industrial
mice: logitech g9, kensington expert mouse, logitech mx300
Offline kw71
« Reply #8 on: Mon, 23 November 2009, 20:05:48 »
Quote from: ch_123;135388
Datacal sells them, $97
« Reply #9 on: Mon, 23 November 2009, 20:12:01 »
Quote from: Viett;135376
If you want to go cheap, you can get an old Compaq rackmount keyboard with brown Cherry's and a trackball for much lower than 70USD. Take a look on Ebay and I bet you'll find some.
Here's one. It's a little pricey at $50 but looks to be in good shape:
http://cgi.ebay.com/Compaq-Server-Trackball-Keyboard-MX-11800-185152-PS-2_W0QQitemZ230401768065QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item35a503fa81
Or, if you're into keyboard trays, you can't miss this one!
http://cgi.ebay.com/Compaq-Rackmount-KeyboardW-Trackball-185152-406-11800_W0QQitemZ160364736951QQcmdZViewItemQQptZPCA_Mice_Trackballs?hash=item25567bb1b7
« Last Edit: Mon, 23 November 2009, 20:14:08 by microsoft windows »
