Author Topic: Omnikey Ultra USB  (Read 6478 times)
Offline alternety
Omnikey Ultra USB
« on: Sun, 22 November 2009, 19:37:14 »
I have an Omnikey Ultra from Northgate. I am the original owner but have no idea where the manual is. It has three cable connections on the back (with the dip switches and a push button). I have seen references to this keyboard being USB compatible. I would like to stop using the IBM keyboard interface connector because the weight of the cable and adapter to PS/2 makes the connection a bit intermittant.
Can someone tell me what the extra two connectors on the back are for and how to use the keyboard on a USB port?
Offline microsoft windows
  • Blue Troll of Death
  • President of geekhack.org
    • Get Internet Explorer 6
Omnikey Ultra USB
« Reply #1 on: Sun, 22 November 2009, 19:40:37 »
Does the AT cable plug into an SDL port in the keyboard?
Offline alternety
Omnikey Ultra USB
« Reply #2 on: Sun, 22 November 2009, 19:55:00 »
Sorry, I do not know what SDL means. It is a small round connector with a key post in the pin area. It is the middle connector on the keyboard.
Offline ricercar
  • mostly abides
Omnikey Ultra USB
« Reply #3 on: Mon, 23 November 2009, 15:00:17 »
Northgate never released any USB keyboards. Even cvtinc.com--the company that bought Northgate--has no USB keyboards.
I'm skeptical your Omnikey has a USB port.
Offline alternety
Omnikey Ultra USB
« Reply #4 on: Mon, 23 November 2009, 15:54:14 »
OK.  Than makes sense. The keyboards were probably around before USB was popular/in existence.
Do you know what the other two sockets on the back of the board are for?
Offline ricercar
  • mostly abides
Omnikey Ultra USB
« Reply #5 on: Mon, 23 November 2009, 18:06:10 »
Can you get us a picture? My Northgate has only one port on the back, for a PS/2 socket.
Offline bitflipper
Omnikey Ultra USB
« Reply #6 on: Mon, 23 November 2009, 18:20:04 »
Mine has one port on the back as well. And the trap door on the top which flips up to expose the dip switches. I believe there's a different revision of the Ultra which has the dip switches on the front and no trap door.
Offline ricercar
  • mostly abides
Omnikey Ultra USB
« Reply #7 on: Mon, 23 November 2009, 21:07:59 »
Quote from: alternety;135413
Omnikey Ultra from Northgate ... extra two connectors on the back are for and how to use the keyboard on a USB port?
OK, my Northgate/Ultra manual has a figure displaying three PS/2 style ports plus DIP switches on the back of the OmniKey/Ultra. The figure says the middle of the three is "KEYBOARD CONNECTOR SOCKET" without any text labels for the outer two.
The caption says "Figure 1. Rear view of the OmniKey/Ultra. Plug the cable into the second connector from the left.
The controller schematic shows only one PS/2 port. The two other ports are wired in parallel, and seem to share wiring with the red momentary switch. They are both labelled the same, with type too small for these 5-decade eyes, even wth a magnifying glass:
4PIN HINOIN
4PIN HINDIN
4PIN MINOIN
4PIN MINDIN
4PIN WINOIN
4PIN WINDIN
I just can't make it out. Note that the PS/2 port is labelled 6PIN HINOIN (whatever).
The Northgate cable has a PS/2 on one end and an AT/XT (the big one) on the other end? Would it solve the problem to buy a PS/2 KVM cable with a male PS/2 on both ends, so you need only one adapter, a PS/2 to USB? This worked for my OmniKey/102.
« Last Edit: Mon, 23 November 2009, 21:52:39 by ricercar »
Offline InSanCen
Omnikey Ultra USB
« Reply #8 on: Tue, 24 November 2009, 07:18:52 »
Quote from: ricercar;135754
4PIN HINOIN
4PIN HINDIN
4PIN MINOIN
4PIN MINDIN
4PIN WINOIN
4PIN WINDIN
I have money on that being 4 PIN MINIDIN. PS/2 as you have said, is 6 pin MiniDIN. Should look pretty much the same as an S-Video port.
Currently Using :- IBM M13 1996, Black :
Currently Own :- 1391406 1989 & 1990 : AT Model F 1985 : Boscom 122 (Black) : G80-3000 : G80-1800 (x2) : Wang 724 : G81-8000LPBGB (Card Reader, MY) : Unitek : AT102W : TVS Gold :
Project's :- 122 key 1389620 Wireless ESP32 :
'Pooter :- Xeon E5-2680v4 : Machinist MR9A : 2x16GB DDR4 : Radeon RX6600 : NVME & Spinning rust :
Offline sandy55
Omnikey Ultra USB
« Reply #9 on: Tue, 24 November 2009, 08:54:14 »
Those ports are wriitten as 4PIN MINDIN, and actually are ADB ports.
One of my mates told me, believe or not, that Northgate once sold OmniMac around 1990. He assumed Northgate were just lazy and reused surplus OmniMac parts for AT models.
As risercar wrote, there's no mention about dip switch setting for Mac system in the manual. Funny enough, those 2 additional ports drawn in the cable connection section of a manual are PS/2 with 6pins though schematic shows 4 pin connectors.
Here's a pic of those ports for those who can't believe.
 http://sandy55.fc2web.com/keyboard/temp/omni-ultra06.jpg
will be deleted tommow 'cause it's not mine.
Offline ricercar
  • mostly abides
Omnikey Ultra USB
« Reply #10 on: Tue, 24 November 2009, 16:47:10 »
I remember Northgate ads in MacUser magazine. That makes sense.
What confuses me about this conclusion is the lack of an ADB controller in the Northgate Ultra schematic. I wonder if Northgate reverse-engineered the protocol and refused to license ADB from Apple.
Offline chimera15
Omnikey Ultra USB
« Reply #11 on: Tue, 24 November 2009, 17:48:45 »
Wow, northgates were at least intended to be adb compatible??  Amazing. lol
Alps boards:
white real complicated: 1x modified siiig minitouch kb1903,  hhkb light2 english steampunk hack, wireless siig minitouch hack
white with rubber damper(cream)+clicky springs: 2x modified siig minitouch kb1903 1x modified siig minitouch kb1948
white fake simplified:   1x white smk-85, 1x Steampunk compact board hack
white real simplified: 1x unitek k-258
low profile: 1x mint m1242 in box
black: ultra mini wrist keyboard hack
blue: Japanese hhk2 lite hack, 1x siig minitouch pcb/doubleshot dc-2014 caps. kb1903, 1x modified kb1948 Siig minitouch
rainbow test boards:  mck-84sx
Omnikey Ultra USB
« Reply #12 on: Tue, 24 November 2009, 18:57:41 »
I want to get a Northgate someday. I'll have to look for cheap ones on ebay when they turn up every once in a while. Now, do Northgates have double-shot keys?
Offline sixty
    • http://deskthority.net
Omnikey Ultra USB
« Reply #13 on: Tue, 24 November 2009, 19:43:22 »
Quote from: microsoft windows;136065
You have a Focus. They are most likely from the very same factory. I think Sandy might have some more info on that.
Offline bitflipper
Omnikey Ultra USB
« Reply #14 on: Tue, 24 November 2009, 20:39:01 »
Yes, they have double-shot keys. Here is one relatively cheap.
