Author Topic: Using QWERTY shortcuts with a Dvorak layout. need some help  (Read 11791 times)
Offline Fiery
  • Click Clack Clock and a nice Thock
« on: Tue, 05 January 2016, 05:35:49 »
So recently I have been learning to type with the Dvorak layout. (specifically the norwegian version). And the biggest drawback for me are the keyboard shortcuts, which I have grown accustomed to and I think are better layed out on QWERTY. the are mostly on the left hand which leaves the right hand available for the mouse. So to the reason I am making this post, I need some help finding a way to allow me to use my Dvorak layout but having Qwerty shortcuts. I have googled and found that someone had used autohotkey to do this. I have never used autohotkey before, is this the best way of doing this? or are there better ways?
here is how the norwegian dvorak layout looks
any help is appreciated :)
~Fiery
TP4 fanboy
Offline pyro
Re: Using QWERTY shortcuts with a Dvorak layout. need some help
« Reply #1 on: Tue, 05 January 2016, 07:04:47 »
I'd do it in Autohotkey. It's not too hard.
This "script" should work:
Code: [Select]
^j::^c
^k::^v
Syntax is
Code: [Select]
<what you press>::<what you want to happen instead>^ is the sign for ctrl. See https://autohotkey.com/docs/Hotkeys.htm for more.
Note, that you're going to lose ctrl+j and ctrl+k shortcuts (in case some of your programs use them). You can choose any other keys instead of j/k, of course.
« Last Edit: Tue, 05 January 2016, 08:36:13 by pyro »
Offline Fiery
« Reply #2 on: Tue, 05 January 2016, 13:58:03 »
Code: [Select]
^j::^c
^k::^v
Syntax is
Code: [Select]
Thanks! It seems like autohotkey isn't too hard, thanks for your help! :)
TP4 fanboy
Offline __red__
« Reply #3 on: Tue, 05 January 2016, 14:01:23 »
Also, if you jist started down this road Colemack is a layout with the same advantages plus keeps the more common keyboard shortcuts in the same place.
Offline davkol
  •  Post Editing Timeout
« Reply #4 on: Tue, 05 January 2016, 17:27:43 »
Nope, nope, nope. It's based on different principles (hand alternation versus adjacent fingers) and it's not an ANSI standard.
There's also Dvorak-QWERTY in OS X, and DQ for the other common systems, or a similar thing for just Windows.
I've also found some folks using AHK like this
Code: [Select]
^;::Send {Blind}z   ;Undo
^q::Send {Blind}x   ;Cut
^j::Send {Blind}c   ;Copy
^k::Send {Blind}v   ;Paste
^o::Send {Blind}s   ;Save
^r::Send {Blind}o   ;Open
^f::Send {Blind}y   ;Redo
Offline bocahgundul
  • a seal
« Reply #5 on: Tue, 05 January 2016, 18:24:12 »
Good luck on this bro :thumb:. 1 question for you because you use ISO dvorak, where can I find the international ISO dvorak thank you
Offline Fiery
« Reply #6 on: Wed, 06 January 2016, 01:02:53 »
Code: [Select]
I found the Github one before, but couldnt get it to work as it seemed like it was missing a .EXE file
And the other one is an american layout, so it seems like AHK is the best option still. I really wish windows had the same option as on OSX... (didnt think id ever say something like that)
And regarding finding the international dvorak layout I can't really help, but Google should be your friend :)
*Edit* I tried the script and it seems to work, i just need to add a couple shortcuts
« Last Edit: Wed, 06 January 2016, 01:21:55 by Fiery »
TP4 fanboy
Offline davkol
« Reply #7 on: Wed, 06 January 2016, 04:04:22 »
The latter is apparently made in Keyboard Layout Creator, thus you might be actually able to make a native layout of your choice.
Offline Fiery
« Reply #8 on: Wed, 06 January 2016, 05:51:21 »
Oh? I have never heard of Layout Creator, are there any advantages to using it?
TP4 fanboy
Offline davkol
« Reply #9 on: Wed, 06 January 2016, 06:16:19 »
AFAIK it's the official native method to make new layouts, although severely limited compared to something like AHK or XKB.
Offline Fiery
« Reply #10 on: Wed, 06 January 2016, 06:24:30 »
Then I think i'll just stick with AHK, but thanks for your input and help  :thumb:
TP4 fanboy
Offline hoggy
  • * Moderator
« Reply #11 on: Wed, 06 January 2016, 07:42:55 »
Fiery, I used pretty much the same thing a few years, sadly I don't have the ahk script anymore.
...but, personally, I think it made my transition from qwerty to Dvorak harder not easier.
Offline Fiery
« Reply #12 on: Wed, 06 January 2016, 10:26:43 »
Could you elaborate as to why?
TP4 fanboy
Offline hoggy
  • * Moderator
« Reply #13 on: Wed, 06 January 2016, 15:47:21 »
It made the transition longer and bumpier. I had gained some muscle memory with crtl c etc, but not much.  When I swapped to the Ctrl+qwerty+c mod, I got confused and would sometimes hit the qwerty key, but i would sometimes hit the Dvorak key.
Hitting Ctrl q without realising can really add to your workload...
It took me a long time to adapt. Before swapping, I could only type about 2500-3000 characters a day before the pain made thinking optional.  Losing half of my productivity at that point actually didn't matter as much as you might think, either way, I wasn't getting much done each day. I was pretty stressed out, and the only thing that stopped me from quitting working with computers was the various encounters with shop staff who would start at a shop one day with a wrist brace, and you'd still see them trapped in that situation a year later.
If I was in a hurry, I would develop 'key panic', and would guess the correct key by trial and error instead of thinking it through first. That didn't help either.
It was totally worth it.
Offline Fiery
« Reply #14 on: Thu, 07 January 2016, 10:37:32 »
So I should just stick with it? Also do you have any general tips to improving? im learning quite slowly, and im kinda considering giving up. I dont want to but its hard to adapt.
TP4 fanboy
Offline hoggy
  • * Moderator
« Reply #15 on: Thu, 07 January 2016, 11:28:22 »
You could try remapping caps lock to backspace so you don't have to move your hands from the home row to correct a mistake.
I found thinking through before typing really helped. That way I wasn't revising work anyway near as much as before.
Macros and text expansion really helped me out.  These currently supply roughly the same amount of input that I actually type, without any mistakes.  The beauty of text expansion is that it doesn't take much to recover the time you put into the initial set up,and it's pretty easy to add more as you think of them. You can also get more value from introducing your coworkers to the idea.
Find any excuse to not type for a few minutes, phone rather than email. If you have a ton of typing to do, try to call in a favour and ask someone else to help you.  It's best practice that makes perfect, and it's hard to keep that up all day.  Disappear at lunchtime.
If you ditch Dvorak, you'll only need to reinforce qwerty anyway, probably best to continue. Once you've adapted, Dvorak is much more comfortable than qwerty.
Hang in there! There are plenty of people here who managed to adapt far quicker than I did. Good luck!
Offline Fiery
« Reply #16 on: Thu, 07 January 2016, 13:42:16 »
thanks!I'll do my best to keep it up! I really do wanna learn it! but a hurdle for me can be games, but ill get over it, thanks for your help I appreciate it alot  :D
TP4 fanboy
Offline Vozella
« Reply #17 on: Wed, 13 January 2016, 17:55:26 »
I saw a code on the AutoHotkey forums about using Dvorak but when you hit Ctrl, all the letters toggle back to QWERTY so you can use the shortcuts.
I can't find it though.
Offline Vozella
« Reply #18 on: Wed, 13 January 2016, 17:57:56 »
I don't know if this is the one I saw before, but I found something. https://autohotkey.com/board/topic/25093-mac-style-dvorak-qwerty-command-layout-switcher-for-windows/ Here you go.
Offline Fiery
« Reply #19 on: Sat, 16 January 2016, 03:41:46 »
I have decided to abandon using QWERTY shortcuts. but someone else might find it useful though.
TP4 fanboy
Offline wockytocky
« Reply #20 on: Tue, 19 January 2016, 16:50:16 »
Good move, they're really not that bad in dvorak. At least Z,X,C,V,W, and even N are all on the same hand, which is pretty nice
Offline Fiery
« Reply #21 on: Wed, 20 January 2016, 00:51:09 »
true, but one of the original reasons I wanted qwerty shortcuts was that they are all available to my left hand allowing me to use my mouse more easily. but I'll get used to it.
TP4 fanboy
