Author Topic: Enter Key: Replace ANSI Enter+Pipe(above that) to ISO-like Enter!?  (Read 7169 times)
Offline Phenix
Hello.
Just thinking about replacing the Enter Key+Pipe(the key above) to a ISO-like Enter key (in ISO ist inverted L-shaped).
Would that be possible? To remap the key I would use AutoHotkey, so no problems there.
Where can I get such a Key??
Winter is coming.
Re: Enter Key: Replace ANSI Enter+Pipe(above that) to ISO-like Enter!?
« Reply #1 on: Tue, 05 January 2016, 10:35:58 »
With ancient IBM iron it can be done because they allowed for it. What keyboard and switches do you have?
There need to be switches in the proper places and you may have to rig up "custom" stabilizers.
"you've got to cheat like hell"
- D Trump - 2026-09-10 Dallas, Texas
"The pure products of America go crazy"
- William Carlos Williams - "For Elsie" 1942
Offline TalkingTree
    • My projects
« Reply #2 on: Tue, 05 January 2016, 10:40:25 »
Meaning the so called "big ass enter"?
As stated, depends on switches and keyboard.
Also that key usually needs two stabilizers. Might be not worth the effort.
Offline Phenix
« Reply #3 on: Tue, 05 January 2016, 13:57:18 »
would be for standard cherry mx
Winter is coming.
Offline Ludovician
« Reply #4 on: Tue, 05 January 2016, 15:05:40 »
I would assume Phenix means the ISO enter, not the BAE.
Phenix, the switches are in different locations so this won't work. Some PCBs and plates support multiple layouts, so in those you would be able to rearrange the switches to an ISO layout, but in stock keyboards, this feature isn't generally included.
Typing speed:
My collection:
HHKB Pro 2 (Blank, white) | HHKB Pro 2 Type-S (Blank, white) | Topre Realforce 87UB silent-modded (not currently functional) | Das Keyboard Model S Professional Silent (MX Brown) | IBM Model M 1391401 - 9th January 1991 (Bolt+Floss-modded) | Apple keyboard m0116 (Orange Alps) | Unidentified DIN Keyboard (White Alps) | ADDS 1010 (Green Alps) | AEK II (Linear-modded, USB-converted) | IBM PC-AT Model F | Noppoo Choc Mini (MX Black) | Amstrad PC2286 | BigKeys LX | IBM Model M 1391401 - 6th September 1990 | IBM Model M2 1395300 - 28th February 1991 | Leopold FC660C | Cherry G80-11802 (MX Brown) | Matias Tactile Pro (Simplfied grey Alps) | Razer Blackwidow (MX Blue) | Novatouch 55g | Focus FK-2001 (White alps) | DSE Multitech (Blue alps) | Dell AT101W (Matias quiet) | Pok3r (White w/Clears) | KBP V80 (Blue Alps)
Pending:
Infinity kit
Offline Phenix
« Reply #5 on: Tue, 05 January 2016, 18:27:40 »
im meaning following:
remove pipe and ANSI Enter.
Get a key which fits on both mx stems (formed like big ass enter)
Is there any shop e.g. for that?
Winter is coming.
« Reply #6 on: Tue, 05 January 2016, 21:58:29 »
Keys are readily available. The question is whether the switches are in the correct locations to accommodate them.
Offline Phenix
« Reply #7 on: Wed, 06 January 2016, 07:01:43 »
please sent me a link, couldnt find some myself
Winter is coming.
« Reply #8 on: Wed, 06 January 2016, 09:30:24 »
I don't really know anything about Cherry gear, or where to buy it.
This was in my junk box, and looks like strange placement and configuration to me.
Offline Phenix
« Reply #9 on: Thu, 04 February 2016, 15:20:27 »
so I think I would get an Steelseries 6gv3 for that big ass enter.
How could I add the stabs to the board?
Winter is coming.
