Author Topic: IBM Model F 122 Space bar not working  (Read 3321 times)
Offline paecific.jr
« on: Tue, 05 January 2016, 16:38:56 »
Hey guys I need some help fast.
I ordered an IBM Model F 122 Terminal keyboard from ebay and one of Soarer's nice adapters for it. When I plug the keyboard in I can type on every key except my space bar. The seller has verified that they test all model f's and I trust him. He has offered me a full refund though believing that it was damaged in shipping. I'm wondering if there is something wrong with how I have my converter setup or something like that. Using HID_listen I noticed that the space bar doesn't even send a scan code. When I plug my keyboard it says BFBF Code Set 3. Do you guys think that it is broken? Should I send it back? Or am I wrong with something?
First Mechanical Keyboard: IBM Model F 122
Offline Melvang
  • Exquisite Lord of Bumfluff
  • Melvang's Desktop Customs
Re: IBM Model F 122 Space bar not working
« Reply #1 on: Tue, 05 January 2016, 17:08:51 »
Does the space bar click when pressed?  If not, the cap probably needs to be reset.  If it has the stabilizer wire above the plate, just remove it and put it back on.  You may have to do this a few times for it to work right.  F caps can be a bit fussy at times.  Just remember to take the alpha keys off directly above the space bar first.  If the wire is NOT above the plate, you would need to actually take the plates apart.  Yes it is a very finicky process.  Though once you do it a couple times it isn't that bad.
If the space bar does click, it is probably a piece of the foam that is essentially falling apart that has gotten under the flipper for that key.  I would not try and blow compressed air into it, because if that is the problem, chances are very good that it will exacerbate the problem.
« Reply #2 on: Tue, 05 January 2016, 17:13:31 »
Being careful not to damage any of the parts, pull the spacebar off and substitute a single standard stem in its place. If it clicks, registers, and operates normally, then the problem is with the spacebar and/or its accessories.
If it is not clicking or registering, then problem is probably internal.
- D Trump 2026-10-24
Offline chyros
  • a.k.a. Thomas
  • Hello and welcome.
« Reply #3 on: Tue, 05 January 2016, 18:45:48 »
If it DOES click but not register, chances are the capacitive pads have somehow deteriorated. Gently try actuating it with something metallic through the barrel, if you can't get it to register (but you can another switch using the same method) it might be the capacitive pads.
Offline Melvang
« Reply #4 on: Tue, 05 January 2016, 19:24:27 »
Granted I haven't been inside that many boards, I very much doubt it would be defective pads, unless it has been opened before, and pads were very seriously scratched.  By the nature of how they work, it would be almost impossible for them to go bad without outside forces.  Now a piece of the foam, if dislodged, can and will cause keys to not work properly.
Offline chyros
  • a.k.a. Thomas
« Reply #5 on: Tue, 05 January 2016, 19:45:30 »
It might be something on top of the pads blocking it.
Anyway I wasn't trying to say it's the most common cause for failure, just putting in my 2 cents for if it proves to be something else :) .
« Reply #6 on: Tue, 05 January 2016, 22:37:16 »
Welcome to Geekhack!
Lots of informative suggestions above - please let us know how you go :)
Offline paecific.jr
« Reply #7 on: Thu, 07 January 2016, 15:54:14 »
I fixed it by taking it off and putting it back on. Sorry I haven't been able to check since then because I have been so busy with school. I now have a problem where I can't get my remapping instructions to write to the teensy. Any ideas?
« Reply #8 on: Thu, 07 January 2016, 16:02:22 »
wcass gave great instructions in reply #560
https://geekhack.org/index.php?topic=17458.msg708153#msg708153
Soarer's documentation provides a spreadsheet identifying the key names and codes.
