Author Topic: keyboard with (nearly) silent keys ???  (Read 11206 times)
Offline keyfriend
« on: Mon, 23 November 2009, 03:21:21 »
Hi,
which keybord is extremely silent?
I am interested in a keyboard with nearly no noise during keying. Unfortunately manufacturers do not specify the keying noise. However, I cannot afford to buy all kinds of standard keyboards in order to test their sound emission. I need standard low force with about 0,16 key travel. Do you know such a product
Offline Arc'xer
« Reply #1 on: Mon, 23 November 2009, 04:23:37 »
The cherry mx brown is a good option around 45 grams of force and non-clicky, light tactility for the most part. Does make slightly more noise than standard membrane keyboards because it's a mechanical switch.
At elitekeyboards they go for 109, 134 and 121 depending on whether you want a tenkeyless(without alphanumerical keypad) or full-sized and with or without NKRO.
http://www.youtube.com/watch?v=0qU1iW_qmUI&fmt=18 Good comparison with the fan noise behind.
Your best bet but also the more expensive option is the topre keyboards. They use a high-quality rubber dome with a housing and a spring. It emulates the quietness of your cheapo membrane, while still providing a tactile feedback along with half way travel due to the spring. Topre varies in force some Topres are variable force per finger and some are for the most part single force.
http://www.youtube.com/results?search_type=videos&search_query=topre+realforce&search_sort=video_date_uploaded Topre sounds, if you here a machine-gun like sound it's the spring collapsing.
Although these options might be a bit pricey. There are many alternatives such as ebay or buying it off someone on here selling it. A good option is the Compaq MX-11800 usually go for 30-80 dollars. Of course there are more options if you check out the wiki.
« Last Edit: Mon, 23 November 2009, 04:27:19 by Arc'xer »
Offline spremino
« Reply #2 on: Mon, 23 November 2009, 05:17:40 »
Maybe a Fingerworks Touchstream? Look for a video about it. However they seem to be gone out of business.
A quick search shows this (the picture shows a Japanese layout): http://www.coolest-gadgets.com/20070608/thanko-drops-silent-keyboard/
« Last Edit: Mon, 23 November 2009, 05:21:20 by spremino »
A long space bar... what a waste of space!
Offline savage
« Reply #3 on: Mon, 23 November 2009, 06:15:16 »
Quote from: Arc'xer;135505
Neither of these are anywhere near silent...
Offline ch_123
« Reply #4 on: Mon, 23 November 2009, 06:54:45 »
There's no such thing as a completely silent keyboard, just relative levels of acceptability. Topres and Browns are as good as it gets with mechanical boards, but they're still louder than the average rubber dome board.
Offline hyperlinked
« Reply #5 on: Mon, 23 November 2009, 07:46:03 »
Quote from: savage;135513
Yeah Cherry Browns are anything but quiet... at least not in the Filco Majestouch. I have one and I would not be able to use this keyboard if I worked in a cube farm. It would drive everyone nuts.
Topre: Realforce 103U Cherry: Filco Majestouch 104 (Brown), Ione Scorpius M10 (Blue)
Buckling Spring: IBM Model M1391401 ALPS: Apple Extended Keyboard II (Cream), ABS M1 (Fukka/Black), MicroConnectors Flavored USB (Black)
Domes: Matias Optimizer, Kensington ComfortType, Microsoft Internet Keyboard
Scissors: Apple Full Sized Aluminum
Pointy Stuff: Razer Imperator, Razer Copperhead, DT225 Trackball, Apple Magic Mouse, Logitech MX1000, Apple Mighty Mouse
Systems: MacPro, MacBook Pro, ASUS eeePC netbook, Dell D600 laptop, a small cluster of Linux Web servers
Displays: Apple Cinema Display 30", Apple Cinema Display 23"
Ergo Devices: Zody Chair, Nightingale CXO, Somaform, Theraball, 3M AKT180LE Keyboard Tray
Offline spremino
« Reply #6 on: Mon, 23 November 2009, 08:27:36 »
Quote from: hyperlinked;135530
Cube farm drone here ;-)
I type on a Filco with browns, and it's a little quieter than my colleagues' rubber domes. Maybe, it could be made even quieter by opening it and sticking some sound absorbing material on the lower panel.
Offline wordfool
« Reply #7 on: Mon, 23 November 2009, 09:41:21 »
I chose a topre over a cherry brown because according to every sound clip I heard it's about a close to silent as you can get -- as quiet or quieter than the membrane keyboards I have. Not totally silent, but the noise it does make it very subdued.
« Last Edit: Mon, 23 November 2009, 09:44:39 by wordfool »
Filco TKL and Minila Air (browns) the daily drivers. Black M13 gathering dust. Former Realforce 103U afficionado
Offline hyperlinked
« Reply #8 on: Mon, 23 November 2009, 10:26:52 »
Quote from: spremino;135536
I type over 100wpm. Browns cause a racket at high speeds. If I slow down to 50-75wpm, it's not so bad. I work late at night a lot and I have to type slower so I don't wake other people up at night.
Offline spremino
« Reply #9 on: Mon, 23 November 2009, 10:36:10 »
Quote from: hyperlinked;135557
Well, then that's the reason browns seem quiet to me: I'm a slow typist.
Offline sixty
    • http://deskthority.net
« Reply #10 on: Mon, 23 November 2009, 11:38:17 »
Quote from: bestcanyonlakehomes;135504
me too..i am looking for this kind of keyboard for a while now.. anyone got an idea??
Are you looking for a quiet keyboard to type your fake-content-spam-posts in silence? Do you think no one will notice if you just type quiet enough?
Honestly though, I'm getting quite sick of this human spam we get here recently. Seems someone discovered us recently. I hope this stops soon, especially since some members seem unable to tell apart a real user from a spam user and actually waste their time :/
Offline AndrewZorn
« Reply #11 on: Mon, 23 November 2009, 11:59:55 »
but manual spamming is so... PURE...
Offline lmnop
« Reply #12 on: Mon, 23 November 2009, 13:15:00 »
did everybody forget about scissor switches? :)
Offline msiegel
« Reply #13 on: Mon, 23 November 2009, 13:34:23 »
Quote from: lmnop;135611
has anyone tried a logitech board with the "PerfectStroke" scissors?
Offline ricercar
  • mostly abides
« Reply #14 on: Mon, 23 November 2009, 13:55:59 »
Dammit, I was hoping to post for a few more months before any one knew I was a human spammer.
Offline ricercar
  • mostly abides
« Reply #15 on: Mon, 23 November 2009, 13:57:31 »
That laser projection keyboard would be 100% silent, the one that projects keys onto a tabletop. Last time I heard, light doesn't make noise. Of course your fingers might make noise as they tap the table top. YMMV.
Offline texteur
« Reply #16 on: Mon, 23 November 2009, 13:59:35 »
The most silent keyboard I know is the current standard Apple keyboard sold with iMacs. It's well designed, but it's truely not a keyboard (unless you want to ruin your phalanges).
Quote from: ripster;135573
Manual spamming.  Boy, those guys must be real losers.
What worries me: it seems we've reached the point where using humans is cheaper than using machines.
IBM Model M Space Saver, 1391472, PS/2, US layout, year 1987 | Apple Standard Keyboard, M0118, ADB, Swiss French layout, year 1987 | IBM Model M, 1391401, PS/2, US layout, year 1988 | IBM Model M Space Saver, 1392934, PS/2, US layout, year 1988 | IBM Model M, 1391403, PS/2, German layout, year 1988 | IBM Model M, 1391403, PS/2, German layout, year 1991 | Apple Extended Keyboard II, M3501, ADB, ANSI layout, year 1995 | DSI Switch Mac Keyboard, SMK-88SMK88-EM/JM, Black Cherry Switches, USB 1.1 & 2.0, ANSI layout, year 2006 | Happy Hacking Keyboard Professional 2, white with blank keycaps, PD-KB400WN, Topre 45g switches, USB, UNIX key layout, year 2007 | Das Keyboard Ultimate, DASK3, USB, European layout, year 2008 | Topre Realforce 86U, SE0500, USB, ANSI layout, ergonomically weighted switches, year 2009 | Topre Realforce 87UB, SE1700, USB, ANSI layout, ergonomically weighted switches, year 2009 | Filco Majestouch "Otaku", FKBN104MC/NPEK, Blue Cherry MX switches, USB, ANSI layout, year 2009 | Filco Majestouch Tenkeyless Tactile Touch, FKBN87M/EB, Brown Cherry MX Switches, USB, 87 Key ANSI layout, year 2009 | Filco Majestouch Ten Key Extended Keypad, FKB22MB, Brown Cherry MX Switches, USB, year 2009
[/SIZE][/FONT][/COLOR]
Offline AndrewZorn
« Reply #17 on: Mon, 23 November 2009, 14:04:57 »
Quote from: ricercar;135624
even my model M is completely silent when im not actually typing on it
Offline lmnop
« Reply #18 on: Mon, 23 November 2009, 14:18:13 »
Quote from: msiegel;135617
I thought Logitech uses plastic scissors. now they are using metal scissors? I have only seen 3 brands under the hood Kensington, Enermax and Logitech and they're all plastic scissors.
« Last Edit: Mon, 23 November 2009, 14:33:14 by lmnop »
Offline lmnop
« Reply #19 on: Mon, 23 November 2009, 14:34:27 »
a roll out keyboard is another option?
Offline clickclack
  • Board Chow EXTRAORDINAIRE
« Reply #20 on: Mon, 23 November 2009, 14:35:53 »
Well as far as mehcanical boards go (without getting too pricey or exotic) I would go with the AEKII for tactile and less loud and I would go for a linear switch keyboard (with cherry blacks).
These are the only two (minus funky capacitive designs) that my coworkers and family have not complained about me typing on.  haahaa!
If you go for rubber dome keyboards they are much more common and much less likely to cause significant noise. And some can be insanely quiet! It's worth going to a store that has them on display and just typing on them and see which you could live with. I have come across many darn near silent boards but usually they are less enjoyable to type on in my opinion, and that of my family, friends, and cowokers.
Sorry that I was not more specific, good luck. And if this was spam then... well... heck ,I don't care somebody will get something out of it right?
=P
862+ keyboards and counting!   R.I.P.ster          Vendor link ->Clack Factory
Offline microsoft windows
  • Blue Troll of Death
  • President of geekhack.org
    • Get Internet Explorer 6
« Reply #21 on: Mon, 23 November 2009, 14:55:15 »
If you like a good feeling keyboard, seriously try an original Dell Quietkey with white sliders. It has a very good feel to it even though it is a rubber dome.
Offline quadibloc
  • Layout Fanatic
    • John Savard's Home Page
« Reply #22 on: Mon, 23 November 2009, 15:39:33 »
Quote from: lmnop;135635
Only a few Logitech keyboards, three using the "diNovo" brand, and one an illuminated keyboard, seem to use the Perfect Touch mechanism. They're apparently fairly expensive, depending on how much the New Zealand dollar is worth...
Offline hyperlinked
« Reply #23 on: Mon, 23 November 2009, 16:06:06 »
Quote from: clickclack;135636
Yeah, AEK II's are definitely on the low audio output end of things.
Offline lmnop
« Reply #24 on: Mon, 23 November 2009, 16:14:35 »
Quote from: quadibloc;135658
oh you are right Logitech does use metal scissors. I thought the Illuminated used plastic.
Enermax and Kensington use plastic.
« Last Edit: Mon, 23 November 2009, 16:16:54 by lmnop »
