Author Topic: Netgear FVS318G VPN Router $47.99 in CDW Outlet  (Read 1755 times)
Offline SamirD
« on: Thu, 07 January 2016, 13:41:36 »
Found this one one while looking for something else:
https://www.cdw.com/shop/products/NETGEAR-PROSAVE-VPN-FIREWALL-8GB-LAN/3893881.aspx?pfm=srh
I have the version of this with wireless built-in (FVS318N) and it's almost bulletproof.  Even with contant site-to-site VPNs and all sorts of other business connections going on, I reboot it maybe every 6 months if even that often.  WAN speed is limited to about 60Mbps, but it's a solid router for small business and overkill for home.  It also supports jumbo frames on 4 of the ports as well as vlans and a bunch of advanced networking stuff.  Killer for the price as you can't find these for less than $100 anywhere.
