Author Topic: Neo 2 Splitted Matrix Keyboard MB46-Neo  (Read 5706 times)
Offline burli
    • My Neo 2 Blog
« on: Fri, 08 January 2016, 05:59:18 »
My next keyboard will be a JD40 clone with QWERTZ layout and staggered rows, but I prefere splitted matrix keyboards with Neo 2 layout and I have a prototype of this. I tryed out to find the absolute minimum making use of the Neo 2 features. This is the result
123232-0123234-1
It is absolutly possible to work with this layout and it's pretty handy to use Layer 4 for Enter, Backspace, Cursor … But sometimes it's also impractical. You always need two hands to delete something or just hit enter, if you are not in "touch typing mode". Also the most desktop shortcuts doesn't work like Alt+Tab
So I desided to expand the layout to it's final size
123238-2123236-3
I extensively use layer 3 and 4 from Neo 2, but I add the movement keys to the Fn layer for two reasons. Some people prefer the right hand and desktop shortcuts like Ctrl+Alt+left/right doesn't work with layer 4
I think, this will be the final layout. Now it's time for the PCB design, but I still think about the controller. Should I use AVR or should I switch to ARM? I need tools for Linux
« Last Edit: Fri, 08 January 2016, 06:02:10 by burli »
I love the Neo 2 Layout and splitted matrix keyboards. Never want to go back
Offline joey
Re: Neo 2 Splitted Matrix Keyboard MB46-Neo
« Reply #1 on: Fri, 08 January 2016, 06:34:23 »
Is each side a separate USB device? (you mentioned Alt+Tab not working)
If so look at how the Infinity Ergodox or standard Ergodox work (how they communicate between halves and appear as one device)
I strongly suggest ARM, we should move away from AVR :)
Offline burli
    • My Neo 2 Blog
« Reply #2 on: Fri, 08 January 2016, 08:18:08 »
No, it's just one Teensy. It doesn't work only in the old version without native Tab key. In the extended version with Tab key everything is fine. The problem is, that the Neo 2 layer 4 doesn't send a tab scancode. If you press Mod4+ö (Neo ö) for Tab the scancode for AltR and v will be send. The Neo driver converts this to Tab. Same problem with the cursor keys
Well, true. But ARM much more complicated I think
Offline joey
« Reply #3 on: Fri, 08 January 2016, 08:41:22 »
ARM is not much more complicated at all.
What kind of controller package would you use? QFP, QFN?
Offline burli
    • My Neo 2 Blog
« Reply #4 on: Fri, 08 January 2016, 08:48:03 »
Would prefer QFP, but I can solder QFN if I have to
Offline joey
« Reply #5 on: Fri, 08 January 2016, 08:52:06 »
I used the MKL27Z256VLH4 from Freescale. Comes in a 64QFP 0.5 mm pitch package.
It's a great MCU in my opinion!
Offline burli
    • My Neo 2 Blog
« Reply #6 on: Fri, 08 January 2016, 08:58:52 »
Built in Bootloader. Hmm, does it work on Linux?
Offline joey
« Reply #7 on: Fri, 08 January 2016, 09:01:14 »
Yes, works fine.
My current code is here: https://github.com/jgouly/keyboard-firmware
Hoping to find some time this weekend to upload the USB parts (which I have working locally).
Offline burli
    • My Neo 2 Blog
« Reply #8 on: Fri, 08 January 2016, 09:07:42 »
I'll give it a try
Offline joey
« Reply #9 on: Fri, 08 January 2016, 09:12:41 »
Feel free to ask any questions. I've had two successful PCB designs with it.
Offline burli
    • My Neo 2 Blog
« Reply #10 on: Fri, 08 January 2016, 09:56:14 »
Ordered some Teensy LC to play. It's a Freescale KL26
Offline Brammm87
« Reply #11 on: Fri, 08 January 2016, 09:58:31 »
Damn, this is impressive. I wonder, how does the US International layout do when typing German?
pls gief bbv2
Offline joey
« Reply #12 on: Fri, 08 January 2016, 10:09:49 »
I have a FRDM-KL26Z, that's what I originally wrote my code for. There should only be minor changes to the USB and clock code, but I guess using the teensy code will be easier to start with
Offline burli
    • My Neo 2 Blog
« Reply #13 on: Wed, 13 January 2016, 15:22:09 »
Today I received sample keycaps for Cherry ML switches.
124168-0
I decided to use Cherry ML swiches because this keyboard should be small and slim. The keycaps are a little bit smaller than MX and the distance between the switches is 18mm.
based on the availible keycaps I changed the design to this
124170-1
I want to have a third thumb key. The first prototypes will be without a controller but with a socket for a Teensy or a ribbon cable connector
