Author Topic: Rotwitt's hopeless endeavour into keyboard design  (Read 5749 times)
Offline Rotwitt
  • I'm trying to have fun designing keyboards
« on: Fri, 08 January 2016, 16:09:36 »
Welcome! I'm going to show you some of the work I've been doing on a keyboard I've been designing.
This is my very first time designing anything keyboard related, so naturally I chose to make it as hard for myself as possible, without knowing it.
I decided it would be nice with a custom layout, with a custom PCB to fit my needs. Seeing it in retrospect, that might not have been the best idea.
My best guess as to what my thought process was, is something along these lines:
"A custom PCB? How hard can that be. I'm the very best at everything and no one is going to tell me otherwise"
Let's just say I've become a little bit smarter. I'm still trying to do it though.
So let's get to business, shall we?
First a little information about the board:
  • Size factor: 75%
  • Switches: Red Gateron MX
  • Frame material: Aluminium
  • Energy source: My blood, sweat and tears. Mainly tears.
  • Input/Output: Micro USB or USB C
So what does it look like? In it's current CAD model state, a little something like this:
I've also been experimenting with colour schemes, for the frame. They are however all grayscale:
The layout is supposed to look a little something like this:
This is the second version, using Vinny's suggestion regarding cap size
I'm aware that I'll have to reorganize the layout, as R1, R2 and R3 are directly above and below eachother.
I'm now aware that it won't matter for me as it is the F keys and and number keys.
Whew, that was a whole lot of pictures, now wasn't it?
The frame is supposed to be CNC machined, and then anodized and dyed the desired colour. The PCB design will have to wait, I'm not even close to being done with that yet. It's a bit of a nightmare to navigate the software.
I hope to be starting on a cheap prototype made out of plywood when I get the time to do so.
Things to do:
  • Angling the keyboard. Having it flat on the table might become uncomfortable
  • Design a PCB so nightmarish that it'll make electrical engineers cry
  • Order some switches, to ensure right fit into plate
  • Start prototyping.
I guess that's what I have for now. Criticism and feedback is very welcome.
« Last Edit: Sun, 10 January 2016, 18:31:53 by Rotwitt »
Offline VinnyCordeiro
Re: Rotwitt's hopeless endeavour into keyboard design
« Reply #1 on: Fri, 08 January 2016, 19:08:08 »
Nice project! I can help with the PCB, if you want. ;)
Suggestion: Increase the Win key at the left side of the bottom row to 1.25u, that will make you use a 6.25u spacebar, which is much more easily found than the 6.5u spacebar currently showing.
« Last Edit: Fri, 08 January 2016, 19:19:17 by VinnyCordeiro »
Offline FLFisherman
  • I'd rather be fishing.
« Reply #2 on: Fri, 08 January 2016, 19:12:29 »
This is a very unique layout. I can't wait to see you make the engineers cry.  >:D
Offline Rotwitt
« Reply #3 on: Sun, 10 January 2016, 06:22:40 »
That would be very much appreciated! I have already arranged the switches in a matrix pattern, using a piece of CAD software I always seem to forget the name of. I'll update the layout with your suggestion, always nice with some input!
Thank you! I'll do my best!  :))
« Last Edit: Sun, 10 January 2016, 06:31:42 by Rotwitt »
Offline mrbishop
  • Evil Genius
    • Bishop Computer Design web
« Reply #4 on: Sun, 10 January 2016, 11:53:48 »
design looks real solid. i like where this is going :)
Projects
Offline Rotwitt
« Reply #5 on: Mon, 11 January 2016, 11:49:30 »
Thank you! I'll try to keep the direction, maybe try out some different colour schemes and so on! If there's anything you'd like to see, let me know!
Offline mrbishop
  • Evil Genius
« Reply #6 on: Mon, 11 January 2016, 11:50:41 »
Do a high polished mid frame. That would be sexy
Projects
Offline Rotwitt
« Reply #7 on: Mon, 11 January 2016, 12:02:18 »
Coming up!
Offline mrbishop
  • Evil Genius
« Reply #8 on: Mon, 11 January 2016, 12:04:00 »
Coming up!
win
what are you doing for design software? i'm a fusion 360 guy
Projects
Offline Rotwitt
« Reply #9 on: Mon, 11 January 2016, 13:17:36 »
Coming up!
win
For modelling I use Inventor, which I'm quite liking. For the renderings i showing here I use Keyshot 4, which is easy to use, but darn expensive. I might start learning to use Autodesk's own rendering software instead
I tried 360, and it looks promising, but I'll have to learn it
Offline mrbishop
  • Evil Genius
« Reply #10 on: Mon, 11 January 2016, 13:18:54 »
Coming up!
win
I have a hobby cnc and u use fusion for cad/cam stuffs. I like it.
Projects
Offline Rotwitt
« Reply #11 on: Mon, 11 January 2016, 14:23:22 »
Coming up!
win
How well does it work? Would be nice to have everything in the same software!
Offline mrbishop
  • Evil Genius
« Reply #12 on: Mon, 11 January 2016, 14:24:30 »
Coming up!
win
Fusion has a CAM path generator. It's very much one stop shopping once you figure out how to use it.
Projects
Offline mrbishop
  • Evil Genius
« Reply #13 on: Mon, 11 January 2016, 14:25:47 »
Coming up!
win
Also has a render section
Projects
Offline Rotwitt
« Reply #14 on: Mon, 11 January 2016, 15:05:48 »
Here is a glossy version:
I should probably  make another render showcasing it better, but I don't have the time right now.
Offline mrbishop
  • Evil Genius
« Reply #15 on: Mon, 11 January 2016, 15:06:41 »
So shiny
Projects
Offline Rotwitt
« Reply #16 on: Mon, 11 January 2016, 15:08:38 »
So shiny
The all-in-one idea behind Fusion is quite nice. I'll have to give a go
Offline mrbishop
  • Evil Genius
« Reply #17 on: Mon, 11 January 2016, 15:18:54 »
So shiny
Inbox me we can screen share
Projects
Offline Rotwitt
« Reply #18 on: Sun, 17 January 2016, 17:42:58 »
'Ello!
I made some progress! Kinda. Not really though.
I did however make an animation of the keyboard spinning, so I guess that's something.
Here it is:
I'm a bit busy with exams at the moment, so I'm not really as active as I would like to be. Also I'm a bit low on money, so I doubt there'll be any prototype before next month.
Offline Rotwitt
« Reply #19 on: Mon, 18 January 2016, 04:46:15 »
So shiny
Up for it! Could be nice with some collaborative work!
