Author Topic: Cleaning Model M spiral cable?  (Read 2648 times)
Offline spremino
« on: Mon, 23 November 2009, 16:34:44 »
Hello,
how would you advice cleaning the spiral cable of a Model M? Do you think denture tabs would work for it too?
Thanks
A long space bar... what a waste of space!
Offline sixty
    • http://deskthority.net
« Reply #1 on: Mon, 23 November 2009, 16:43:42 »
Yes denture tabs work, I have cleaned one cable using the same technique before (obviously keep both connecting ends out of the water)
Offline microsoft windows
  • Blue Troll of Death
  • President of geekhack.org
    • Get Internet Explorer 6
« Reply #2 on: Mon, 23 November 2009, 20:24:40 »
No matter what you do, those old springy keyboard cables will be dirty. I have never EVER seen a clean one in my life.
I remember having to pass a keyboard around when multiple people were using a computer, and when you let go of it, it would spring back with quite a lot of force.
Offline Shawn Stanford
« Reply #3 on: Tue, 24 November 2009, 07:48:51 »
I'd wrap the ends in plastic bags with rubber bands on them and run it through the dishwasher...
The Brat Prince of COBOL
Offline timw4mail
    • https://timshomepage.net
« Reply #4 on: Tue, 24 November 2009, 07:56:24 »
If you have the patience to do so, rubbing alcohol seems to get rid of the dirt with a minimal amount of elbow grease.
Buckling Springs IBM Model F AT, New Model F 77, Unicomp New Model M
Clicky iOne Scorpius M10, OCN-branded Ducky DK-9008-C, Blackmore Nocturna, Redragon Kumara K552-1, Qtronix Scorpius Keypad, Chicony KB-5181(Monterey)
Tactile Apple AEKII (Cream damped ALPS), Filco FKBN91M/JB (Japanese Tenkeyless), Cherry G84-5200, Cherry G84-4100LPAUS, Datalux Spacesaver(Cherry ML), Redragon Devarajas K556 RGB, Newmen GM711, Poker II (Cherry MX Clear), Logitech G910 Orion Spark, Logitech K840
Linear Lenovo Y (Gateron Red), Aluminum kiosk keyboard (Cherry MX Black)
Offline lowpoly
« Reply #5 on: Tue, 24 November 2009, 08:04:45 »
Quote from: Shawn Stanford;135860
Tried it (without the plastic bags), with limited success.
Offline TWX
« Reply #6 on: Tue, 24 November 2009, 08:13:56 »
An oversized pipe cleaner saturated with WD-40, run back and forth a few times, then another one that's just wet with water.  IF WD-40 isn't adequate, mineral spirits.
TWX
C:\>echo y|format C: /q
Offline ocdonkb
« Reply #7 on: Tue, 24 November 2009, 12:46:10 »
have cleaned a bunch of these now... usually just a towel with some 409. Worked for me.
| Filco Brown 87 key | Realforce 87U | Unicomp Spacesaver | IBM Model M | Cherry ML4100 | Dell AT101W | Focus 2001 |
« Reply #8 on: Tue, 24 November 2009, 18:51:11 »
Maybe I'll make a documentary on all my filthy old springy computer cables someday.
