Author Topic: :~$ynth  (Read 621163 times)
Offline thefebruaryman
  • turn it off and turn it on again
Re: :~$ynth
« Reply #400 on: Mon, 07 March 2016, 13:40:28 »
Do you have pics for a topre stem maker as well? Have you got an eta for this yet? Are you going to do a set of video tutorials for us less initiated?
loving it
Offline iamtootallforthis
  • Something a lot Funnier
  • I like green stuffs.
    • WTB/WTTF Thread
Re: :~$ynth
« Reply #401 on: Mon, 07 March 2016, 13:46:18 »
Pre Production Vs. Production
Pre Production model had a dark anodized teflon coating.  For Production we opted for clear to show off the beautiful machining.  These cellphone shots do not do it justice.
Left -PreProd Right -Production
The 'resin reservoir' from PreProd was not kept in the final revision.  It simply does not work as well as it would in a flexible mold.
Stem inserts are far superior to the PreProd models and should provide better fitment results.
No dimple!
When comparing the two the Production model has much tighter tolerances.  There is far less wobble.
I will be doing two test casts tonight with the production model for testing using molds made with the pre-production synth.  Nothing about the preproduction synth should make a difference in how this works with my existing flexible molds as the dimensions of the key platform are exactly the same.
Looking forward to seeing the test casts!
Offline MrRooks
  • Always be knolling
Re: :~$ynth
« Reply #402 on: Tue, 08 March 2016, 18:35:12 »
Awesome, I dig the clear on the production version.
  • * Moderator
Re: :~$ynth
« Reply #403 on: Wed, 09 March 2016, 07:29:16 »
Tip #82 - Always use mold release
Offline FLFisherman
  • I'd rather be fishing.
Re: :~$ynth
« Reply #404 on: Wed, 09 March 2016, 08:07:32 »
If one doesn't use it, what happens? Your mold gets stuck on the synth?
  • * Moderator
Re: :~$ynth
« Reply #405 on: Wed, 09 March 2016, 08:29:47 »
The stem insert will not come out.  I'm going to have to melt the key off using heat/chemicals.
Offline FLFisherman
Re: :~$ynth
« Reply #406 on: Wed, 09 March 2016, 08:33:06 »
Oh wow, so that's something that can potentially damage your equipment in addition to ruining the mold
  • * Moderator
Re: :~$ynth
« Reply #407 on: Wed, 09 March 2016, 08:35:24 »
Silicone molds aren't such an issue.  That came off easily.
The problem is that metal is rigid, and if you form a strong enough bond these plastics are durable as hell.  They'll just become fused together via friction.
The amount of force I'd have to exert on the metal mold pieces to separate them would easily be enough to damage them both as well.
Offline FLFisherman
Re: :~$ynth
« Reply #408 on: Wed, 09 March 2016, 08:37:15 »
This seems like a very helpful hint to those just starting out. Maybe a short "dos and don'ts" guide should be sent with the synth?
Re: :~$ynth
« Reply #409 on: Wed, 09 March 2016, 08:39:27 »
If Instagram foreshadows anything, I'm assuming that he's doing that. Saw a little teaser of a video of some kind there.
Also, I wonder if I could use this to make just the tops for caps to fit onto a two piece BS cap kinda like how Clack's BMX or how some of HipsterPunk's BS caps worked.
  • * Moderator
Re: :~$ynth
« Reply #410 on: Wed, 09 March 2016, 09:25:30 »
Synth release will be delayed due to complications with the coating until further notice.
Offline Bromono
  • Wanabe Cicerone
  • HHKB > Your Opinion
Re: :~$ynth
« Reply #411 on: Wed, 09 March 2016, 09:26:53 »
Offline Zanduby
Re: :~$ynth
« Reply #412 on: Wed, 09 March 2016, 09:57:00 »
better delayed release than ****ty product.
Offline theoriginal123123
Re: :~$ynth
« Reply #413 on: Wed, 09 March 2016, 10:02:23 »
Agreed! Thanks for the heads up, at least we know what's going on  :thumb:
Offline heedpantsnow
  • Old enough to know better
Re: :~$ynth
« Reply #414 on: Wed, 09 March 2016, 10:39:32 »
Oh no!  Can I still have one if I promise to use mold release?  I use the spray stuff from US Composites.
I'm back.
  • * Moderator
Re: :~$ynth
« Reply #415 on: Wed, 09 March 2016, 10:47:04 »
You should be able to get them after they are recoated with the proper treatment
Offline Dongulator
Re: :~$ynth
« Reply #416 on: Mon, 14 March 2016, 18:31:04 »
I'm sure it's been discussed, but where are the sale of these going to be held??
  • * Moderator
Re: :~$ynth
« Reply #417 on: Tue, 15 March 2016, 07:03:41 »
..is..
A new opportunity for artisans and resin casting enthusiasts.  After months of collaboration between Techkeys.us and Binge from HungerWorkStudio, crucially assisted by Joey Quinn, and finally engineered by NudeCNC I would like to first showcase by photo the alpha and beta of :~$ynth.
Offline FoC_Tow
  • Brokehlicious
Re: :~$ynth
« Reply #418 on: Tue, 15 March 2016, 09:19:39 »
Awesome project Binge!
Absolutely need some $ynth in my live!
Any estimate if these will be available as a one time deal or permanently?
  • * Moderator
Re: :~$ynth
« Reply #419 on: Tue, 15 March 2016, 09:45:22 »
We were going to have a release this week, but a complication occurred and we are seeking assistance from the manufacturer to reconcile the issue.  No ETC.
Offline FoC_Tow
  • Brokehlicious
Re: :~$ynth
« Reply #420 on: Tue, 15 March 2016, 12:18:34 »
I'm confused, sorry... D=
My question was about the intended buy format.
Is it planned to be on Techkeys permanently or more like a gb format?
  • * Moderator
Re: :~$ynth
« Reply #421 on: Tue, 15 March 2016, 13:26:01 »
I don't want to talk for the other parties involved, but I could ask everyone what we intend to do with this after release.  I have some next steps I want to pursue, but this venture is not entirely my own except by design.
You may not hear a concrete answer until after we've managed a successful sale and had customers to criticise the project.  By our best efforts this is still new ground for a forum which is more suited toward manufacturing peripherals than plastic parts.
« Last Edit: Tue, 15 March 2016, 13:43:59 by Binge »
Offline Sneaky Potato
  • Gunslinger
Re: :~$ynth
« Reply #422 on: Tue, 15 March 2016, 16:14:16 »
Would love to buy one as soon as they're available. Is there any kind of ETA for the coating to be completed?
Re: :~$ynth
« Reply #423 on: Tue, 15 March 2016, 16:24:27 »
He said before
  • Gunslinger
Re: :~$ynth
« Reply #424 on: Tue, 15 March 2016, 16:33:50 »
He said before
My mistake. I misread the post. Thank you!
Offline Oxid
  • resin rash and glitter
Re: :~$ynth
« Reply #425 on: Fri, 18 March 2016, 13:22:17 »
Awesome to know you're on top of those problems, Binge. I'm still incredibly excited for this! Can't wait for the incredibly easy MX->Topre conversions with the synth.
Offline shhbbyisok
Re: :~$ynth
« Reply #426 on: Mon, 25 April 2016, 23:43:42 »
Any more updates on this amazing project, cant wait to get my hand on it!
https://www.instagram.com/el_soupo/
Steam - Long-pig Jerky
k70 - MX browns - RGB led - clear caps
poseidon zx - Kahil blues - Blue led - stock caps
  • * Moderator
Re: :~$ynth
« Reply #427 on: Mon, 25 April 2016, 23:46:23 »
Nope-  keep your eyes peeled here and on instagram/hungerworkstudio for more updates :)
Offline i3oilermaker
  • techkeys.us
    • TechKeys
Re: :~$ynth
« Reply #428 on: Tue, 26 April 2016, 15:47:32 »
Progress is being made - this is not just sitting...should have some updates in the near future.
Offline MrRooks
Re: :~$ynth
« Reply #429 on: Tue, 26 April 2016, 15:48:22 »
Awesome!  :thumb:
  • Gunslinger
Re: :~$ynth
« Reply #430 on: Tue, 26 April 2016, 15:55:53 »
Made my day. This has me on the edge of my seat, checking for updates daily. I want one so bad.
Offline Zambumon
  • discord.zambumon.com
    • Keyset projects
Re: :~$ynth
« Reply #431 on: Wed, 25 May 2016, 03:32:23 »
Will be definitely getting one of this for sure  :thumb:
Offline TheVengeance
Re: :~$ynth
« Reply #432 on: Wed, 01 June 2016, 13:56:02 »
shiiiiit, another keyboard related item I NEED.
Man I want this so bad it hurts.
Offline bananaplum
Re: :~$ynth
« Reply #433 on: Sun, 12 June 2016, 01:43:20 »
Wow this seems like a must have for aspiring artisan capmakers. Wanttttttttt
My first mechanical keyboard - KUL ES-87 :)
Offline SBJ
  • Tactile pls
Re: :~$ynth
« Reply #434 on: Mon, 13 June 2016, 08:10:13 »
\o/ I'm starting to do a happy little dance here.
  • techkeys.us
    • TechKeys
Re: :~$ynth
« Reply #435 on: Mon, 13 June 2016, 22:35:49 »
Offline robotmaxtron
Re: :~$ynth
« Reply #436 on: Mon, 13 June 2016, 22:39:07 »
Wow. Absolutely incredible.
  • Gunslinger
Re: :~$ynth
« Reply #437 on: Mon, 13 June 2016, 23:02:15 »
« Last Edit: Mon, 13 June 2016, 23:10:52 by Sneaky Potato »
Offline piemancoder
Re: :~$ynth
« Reply #438 on: Mon, 13 June 2016, 23:05:38 »
Yoda grammar best has
  • techkeys.us
    • TechKeys
Re: :~$ynth
« Reply #439 on: Mon, 13 June 2016, 23:25:29 »
It will sell out and there will be a restock.
Offline piemancoder
Re: :~$ynth
« Reply #440 on: Mon, 13 June 2016, 23:26:51 »
Thank you  :D
Offline ntw
Re: :~$ynth
« Reply #441 on: Mon, 13 June 2016, 23:41:41 »
congratulations on the release bunge!! you crossed off another milestone off HWS's list :thumb:
  • techkeys.us
    • TechKeys
Re: :~$ynth
« Reply #442 on: Tue, 14 June 2016, 22:24:38 »
All orders have shipped there are a few units remaining that are now listed.
Offline WolfTickets
Re: :~$ynth
« Reply #443 on: Wed, 15 June 2016, 05:09:55 »
What was the price?  It was sold out before I made it to techkeys.
Offline xondat
  • i'm not a star
Re: :~$ynth
« Reply #444 on: Wed, 15 June 2016, 05:24:15 »
$85.
  • Gunslinger
Re: :~$ynth
« Reply #445 on: Wed, 15 June 2016, 09:56:39 »
Can't believe how quickly they sold out!
Offline Blek
Re: :~$ynth
« Reply #446 on: Wed, 15 June 2016, 14:49:20 »
Of course they sold out as soon as my paycheck came in  :'(
Any idea when they will be restocked?
  • techkeys.us
    • TechKeys
Re: :~$ynth
« Reply #447 on: Wed, 15 June 2016, 14:50:42 »
Estimate 3-4 weeks
Offline Marshal
  • Formerly dranzer889
  • Kō Caps
Re: :~$ynth
« Reply #448 on: Wed, 15 June 2016, 17:11:27 »
Estimate 3-4 weeks
Decided not to buy since I'm a Topre user. Wanted some other fellow to get a chance to use this product but once there's a Topre stem I'm not hesitating!
Offline Kudos
  • Godspeed
  • GAF
Re: :~$ynth
« Reply #449 on: Wed, 15 June 2016, 17:52:53 »
For anyone interested, you can read our hands-on review here:
https://keykollectiv.com/2016/06/15/keykollectiv-workshop-hands-on-with-ynth/
 :thumb: :thumb: :thumb:
