Author Topic: Need help finding the right tools  (Read 5140 times)
Offline berserkfan
« on: Mon, 11 January 2016, 02:19:06 »
OK, this is a plumbing question rather than an electronics one. But the combined brainpower of geeks is quite something to see, so I'm sure I can get good answers here.
What happened is that my mixer tap broke. I'm a few months away from moving house, so I don't feel like calling in a plumber. I also have no good experiences with these people, so might as well learn to do my own repairs using tools I can buy from Qo1 00.sg, rakuten, or whatever online source.
I have a tool (I think) is called a plumbing wrench. This is good for regular taps. It is too small for the mixer tap.
The mixer tap is stuck in the underside of the sink cabinet. It can't be reached except by specialized tools. Note how narrow the hole is. A standard basin wrench/ sink wrench head cannot fit inside eg http://plumbing.about.com/od/basics/ss/How-To-Use-A-Basin-Wrench.htm
I need to find out what is the tool that unscrews the mixer tap so that I can put in a new mixer tap. I also need to know how to measure that needed size so I know what to specify when buying online.
Please give whatever ideas you have! Names are VERY important, because without the right names I can't search for the correct tools. Thanks all!
« Last Edit: Mon, 11 January 2016, 02:22:50 by berserkfan »
Re: Need help finding the right tools
« Reply #1 on: Mon, 11 January 2016, 07:00:17 »
How did they get it in there?
It looks like it is shifted to the side of the hole. Is there some way to force it back to the center of the hole so that you have more space all around? Perhaps break the caulking/sealant loose and use a pry bar and brute force to move it 1-2 cm?
« Last Edit: Mon, 11 January 2016, 07:07:07 by fohat.digs »
- D Trump 2026-10-24
Offline TalkingTree
    • My projects
« Reply #2 on: Mon, 11 January 2016, 07:43:57 »
Taps are screwed beneath the basin, so you have to remove that wooden panel to physically reach the nuts.
A plumbing wrench could do the work, but it's generally used for tubes rather that taps. It might be easier with a tap spanner (also commonly called parrot wrench).
Offline berserkfan
« Reply #3 on: Mon, 11 January 2016, 09:23:37 »
No, i'm pretty sure there was no shifting. The carpenter probably made a mistake and did some ad hoc remaking, thinking that no one would ever see this.
Talking tree, there are plumbing tools (such as the metal tube you see in one of my photos) that you can thread through the water tubes to reach the nut. Problem is I don't know the name, no one in this country seems to know the name, and everyone in the hardware shops is just selling the metal tubes for a few bucks but not the correct size I need. Without the correct name and size I can't order online.
« Reply #4 on: Mon, 11 January 2016, 09:35:25 »
That sort of thing is used to install heater elements that are submerged in water. Something like this?
http://www.homedepot.com/p/Everbilt-5-in-Element-Wrench-15016/205680998?cm_mmc=Shopping|THD|G|0|G-BASE-PLA-D26P-WaterHeaters|&gclid=CjwKEAiAws20BRCs-P-ssLbSlg4SJABbVcDps1fvvMsywreqEeDIKZH_CjfaoBOSLPVhh5tCnccnpBoCa3zw_wcB&gclsrc=aw.ds
Offline TalkingTree
    • My projects
« Reply #5 on: Mon, 11 January 2016, 10:48:24 »
there are plumbing tools that you can thread through the water tubes to reach the nut.
Do you mean this?
It is called Jaw Dropper Wrench. I believe only Armeg Ltd. makes this wrench and it's pricey.
Offline berserkfan
« Reply #6 on: Mon, 11 January 2016, 11:08:08 »
Do you mean this?
Thanks a lot for the suggestion. Yeah, I've never seen it online before. A bit too specialized - take too much time and money to get it into my hands.
Fohat has hit upon something that probably is what I'm looking for. A box spanner/ tubular nut. Or else a sink/ pipe wrench. The problem is that sources in English are split between US and UK English and I'm using the UK English names. This being Singapore, we use a mix of either. And then most workers are Chinese and pretty unprofessional since we don't have a professional culture for most manual work. It's quite a mess trying to find the correct tool.
Offline TalkingTree
    • My projects
« Reply #7 on: Mon, 11 January 2016, 14:07:08 »
Alternatively, you can try your luck with a ratcheting wrench and a pipe socket with some sort of extender.
