Author Topic: Shadovved's Group Buy Directory  (Read 1093055 times)
Offline tominabox1
I'd totally be in for a spare beige and light grey set.
Offline roostrc0gburn
  • its just plastic
I will have extras.
@all I will be following up with a windowed keycap GB for these sets while doing the replacement keys later. So stay tuned!
this is perfect! windows + 1800 kits for all my sets. completionist confirmed
Offline MrRooks
  • Always be knolling
I'm definitely interested in getting 1800 addons for my sets though. Had I known about them I would have got them for all the sets I ordered. Just didn't know. :'(
Offline Maxusy
Has anyone tried these with 2x3x4mm leds? Thought it'd work but now I read that they might interfere with cherry profile caps.
Maybe I should place them inside the zealio's I ordered  :-X
b.face x2
Offline KaminKevCrew
2x3x4mm leds will fit nicely inside of zealios. Non-rgb switch tops require a bit of modification to fit properly, but it's doable. Also, the leds will interfere ever so slightly if you place the leds outside of the switch. (they rub just a bit on bottom out) you can easily file the led so that it will fit well though, so there are multiple ways to get it to work properly!
Offline Maxusy
Do you have pictures of how much I have to file off the leds. I thought about that already but I assumed it's too dangerous. Great to hear it's actually possible, thanks for telling me.
Guess it's just a matter of trial and error, but pictures would be cool if you have them.
b.face x2
Unfortunatley, I don't have any photos. I only did it to one led, then decided I liked having the leds inside of the switches, so I tossed it. Sorry!
I think it's been done before though, so I'm site someone has posted about it before.
Offline Atredl
{GB} EnjoyPBT Dyesub/Blank Keysets & CMYRGB Mods! GB CLOSED & IN PRODUCTION
« Reply #857 on: Wed, 23 March 2016, 17:51:15 »
I hate that I passed on these  :'(
Same. Could have grabbed this set if I had known that Ivan was going to fall though with BoB. Hopefully I can snatch up one of the extras. :blank:
Offline calavera
Massdrop had a group buy on these as well. You could join theirs if they do another run.
Offline Atredl
« Reply #859 on: Thu, 24 March 2016, 00:55:10 »
True, but I prefer cherry profile. The Massdrop set was OEM.
I'm not entirely certain on this since I've never seen either in person but the pictures seem to suggest that the Massdrop set was a lighter shade of grey than what is used on these.
Offline popkorn62
  • No keyboards for old men
    • Mekibo
I hate that I missed out on the 1800 set and now TX1800 may come around after all!
https://mekibo.com/
Offline Shadovved
  • King of Stickers (and GBs)
I have many extras available. I could fill a bathtub. :thumb:
EVERYONE WILL GET A SET!
Offline dgneo
  • Supervillain
Will there be single keys available? I need 1x Green on Beige Right Shift, this would be perfect if so.
Offline Shadovved
I'll deal with those via the key replacement exercise.
Offline dgneo
  • Supervillain
Excellent, many thanks again!
Offline redskull
i believe the guys at enjoypbt are cooking up newer stuff  ;D
Offline HPE1000
  • Keycap Paparazzo
need this
Offline Atredl
You the man Shadovved!
Offline tigersharkdude
YEEEEEE
can't wait until I can my hands on some 1 25u caps in various colors
Offline Waateva
If there are a lot of extras would it be at all possible to change which set I receive?  I don't know why I did it at the time but the set I ordered matches exactly zero of the stuff that I have :(
Offline Sempre
Damn I love dyesubs, so many possibilties
Offline Shadovved
:( Y U like dis
Offline y2bd
  • I'm just here for the caps
    • Twitter
You are a beautiful person, even more beautiful than some of these sets.
Offline thelectronicnub
  • drowning in keyboards
i'd be down for an 1800 fix kit :)
KUL ES-87 w/MX Greens
B/S/T Thread
Offline Waateva
:( Y U like dis
No big deal I can always trade it if I need to, just was wondering if it would easy to do.
Besides, maybe that will give me reason to look for stuff in another colorway ;)
Offline appleonama
  • Trollo en USA
this is what blue Cyrillic looks like.
edit: the one in this group buy is cyan!  my mistake
« Last Edit: Mon, 28 March 2016, 20:50:24 by appleonama »
Offline bocahgundul
  • a seal
I'm goin to transfer my order which is :
Ru blacks
Ru red
With the total of 158$
Anyone that wants to buy my order pm me
« Last Edit: Tue, 29 March 2016, 06:33:38 by bocahgundul »
Offline the big aristotle
Ayyy. Count me in for a cyan & pink set. But if anyone has an order that they're trying to get rid of, I'd like to help you out first.
Offline bocahgundul
  • a seal
Ru blacks
Ru red
anybody want to buy my order?
Ru blacks
Ru red
Yes.
But not me.
Offline bocahgundul
  • a seal
Ru blacks
Ru red
Yes.
But not me.
romevipls
Offline yinzer
  • I'm new around here ... please don't notice.
Is there any combination of keys from your bathtub of sets that would come close to covering an ergodox? I've been wondering how difficult it would be to source a cherry-like profile keyset for my next ergodox.
Offline gadzkun
what about 1800 kit?
will 1800 kit had any extras? i forgot to add 1800 kit on my order :(
Offline LuX
I bought two sets to hopefully cover an Ergodox. If you look at the included caps: , you'll see that... well alphas are covered definitely, 1.5u keys are covered in one set per hand (4 bottom modifiers on outer side, tab+|\ for the inner keys). As the 2u thumb keys I intend to use the numpad 0 and enter for each hand, or any other combination that feels good.
Offline yinzer
That does work to an extent.
I think the problem isn't getting enough keys, just getting enough keys that are in the right profiles. Specifically 1.5u keys in R1 and R3 profile. I think I could probably live with an R4 key in R3, but putting an R2 where an R1 should be might be a little too far off from my tastes.
Offline reggalicious
I didn't think I needed one, and then the ZZ96 round 2 buy happened.  I'm in the same boat, my friend.
Offline dgneo
  • Supervillain
The sets support 1800 by default, aka the shift keys. But for the correct profile of Ins/Del/Home keys you need the 1800 kit.
At least you'll have all the keys from the get go, a few will just be in the wrong profile. I'd imagine he'll have extra kits for sale.
Offline Dernubenfrieken
I have a green 1800 set if anyone needs, bought it but I most likely wont need it.
Offline gadzkun
we should set sail together mate ^-^
Offline Noon
When will that bathtub of extras be available to order?
Offline Shadovved
When I receive the ****ton of caps from China.
EnjoyPBT has shipped 50% of the caps to my warehouse in China, pending the remainder next Monday.
Will be updating status soonish....
Offline Krytone
  • ᕦ(ò_óˇ)ᕤ
    • Krap Shop
nice! thanks for the update  :-*
TGR Jane CE | TX-CP | ZZ96 | HHKB | Ducky Shine 3 | Atreus | Infinity Ergodox | IBM Model M | Smart Pad | Taobao Acrylic 96 | TGR910 SE | RGB96 | M4-A | Moon
Pending: Exent | EM7 | M-60 | Kira EXS | 910 Poly | Kn210 | Alice
Dibs on 2x 1.25u blanks in Cyan, Magenta, and Purple
Offline Waateva
Yay :)
Offline andysun
Yay :)
extra kits hype!
Offline Bigpock
Quote from: andysun
extra kits hype!
Going to watch this closely for that 1800 support.
I got a US black set that I'm going to try and get rid of as soon as it comes, if anyone is interested.
Offline bocahgundul
  • a seal
Ru blacks
Ru red
anyone?
Oh wait a minute, there's going to be a GB for windowed keys?  details! I need details!
