Author Topic: keyset recommendations for upcoming build  (Read 3800 times)
Offline zeltner
« on: Thu, 14 January 2016, 07:30:25 »
So I am fairly new to this. I am getting ready to build my first board with this DIY kit https://www.massdrop.com/buy/sentraq-60-diy-keyboard-kit/talk
I also ordered this case in walnut for it: https://www.massdrop.com/buy/pok3r-wood-case
The only piece missing is I need some keycaps for this. It comes with black on grey caps, but I want something that looks more "natural" to match the wood look of the case. Also I think I read that the top case will not fit correctly with SA profile so anything SA will not work. Does anyone have any suggestions on keysets that might look good with this, and where I could buy them?
One set I found on the internet that I thought might work well was a DSA retro set. But I couldn't find it for sale anywhere.
Offline FLFisherman
  • I'd rather be fishing.
Re: keyset recommendations for upcoming build
« Reply #1 on: Thu, 14 January 2016, 07:33:10 »
I wouldn't know which keyset to recommend to you, but if you are interested in a set that's no longer in production you could try the Classifieds here on Geekhack or looking at /r/mechmarket on reddit.
Offline bocahgundul
  • a seal
« Reply #2 on: Thu, 14 January 2016, 07:38:37 »
You could join the GB for enjoypbt caps cherry profile is the best profile in my opinion and the quality of the caps are really good too bro
Offline zeltner
« Reply #3 on: Thu, 14 January 2016, 07:44:46 »
Thanks I'll check out the classifieds and see if I can't find that retro set.
I did look at the enjoypbt but I wasn't really feeling any of the colors for this build.
Offline bocahgundul
  • a seal
« Reply #4 on: Thu, 14 January 2016, 07:46:55 »
Hope you got what you want bro   :thumb: best of luck for you and don't venture too much in GH or you will be homeless real quick  :p
Offline zeltner
« Reply #5 on: Thu, 14 January 2016, 07:50:20 »
Haha yeah I see what you mean. I've already spent ~270 on the kit and case... and still looking for keycpas this will easily be over 300.
Offline Dernubenfrieken
« Reply #6 on: Thu, 14 January 2016, 07:59:29 »
You might be interested in this. Would work well with a wood case (That's my plan)
Offline dgneo
  • Supervillain
« Reply #7 on: Thu, 14 January 2016, 08:12:39 »
GeekKeys also has a pretty good selection of thick PBT sets, you may want to check them out: http://www.geekkeys.com/104-keysets/
Offline zeltner
« Reply #8 on: Thu, 14 January 2016, 08:18:41 »
Aren't those SA profile though? I think I read somewhere that SA profile will not fit in the this case.
Offline FLFisherman
« Reply #9 on: Thu, 14 January 2016, 08:21:06 »
It will fit, but the SA profile caps will look a little strange if the keyboard doesn't have a bezel (the caps will stand out a lot). You don't have to worry about caps fitting with the case, but with the switches you're using.
Offline zeltner
« Reply #10 on: Thu, 14 January 2016, 08:26:15 »
This case has a lid that sits over the caps though for when it's not in use. I believe the SA profiles are too tall for the lid to fit over them.
« Reply #11 on: Thu, 14 January 2016, 08:26:23 »
I have one of these cases didn't know about the SA issue. :(
My case is in the box waiting on a GH60 if it ever comes.
« Last Edit: Thu, 14 January 2016, 08:27:57 by SpAmRaY »
Offline zeltner
« Reply #12 on: Thu, 14 January 2016, 08:28:52 »
I don't know this to be true for sure. I don't have the case yet and I also do not have any SA caps to test with. But I believe someone stated this in the Massdrop comments section for the buy.
« Reply #13 on: Thu, 14 January 2016, 08:50:10 »
I'll try and test it out tonight. :thumb:
