Author Topic: MS Office Excel wizard?  (Read 3912 times)
Offline Michael
  • Formerly Bro Caps
« on: Thu, 14 January 2016, 13:07:04 »
Anyone know how to insert multiple rows into a single cell? I swear to Jeebus I know this has been done before, but I can't figure it out -_-
halp
Offline FLFisherman
  • I'd rather be fishing.
Re: MS Office Excel wizard?
« Reply #1 on: Thu, 14 January 2016, 13:08:33 »
Alt + enter? Multiple lines in same cell.
« Reply #2 on: Thu, 14 January 2016, 13:16:46 »
nevermind derp
« Reply #3 on: Thu, 14 January 2016, 13:18:07 »
Yeah, this. Are you talking about inserting another line of text in a single cell? 'Cause a row is...well, a row.
Offline Michael
  • Formerly Bro Caps
« Reply #4 on: Thu, 14 January 2016, 13:59:53 »
No. Not multiple lines. Multiple rows, like individual cells within a cell, like html tables, essentially.
Like this:
Offline intelli78
« Reply #5 on: Thu, 14 January 2016, 14:01:56 »
Merge cells.
« Reply #6 on: Thu, 14 January 2016, 14:02:28 »
To do like in your picture you need to merge the cells that you don't want to be separate rows. But be warned that merging a ton of cells creates a headache for anyone downstream that needs to heavily modify the spreadsheet.  :P
Offline baldgye
  • Will Smith Disciple
« Reply #7 on: Thu, 14 January 2016, 14:05:03 »
Merge cells.
+1
that screenshot just looks like they have merged the cells at the top and bottom...
Offline Zorberema
  • IG: @ZorbCaps
« Reply #8 on: Thu, 14 January 2016, 14:05:46 »
As both hoffman and intelli said; you need to merge cells to make the first big ones. The ones that are multiple rows in one cell is just many cells! :P The first "big cell" (1. in the picture) is just many cells merged together.
Offline bcredbottle
« Reply #9 on: Thu, 14 January 2016, 14:07:41 »
Like this:
I think in that pic, it looks like the larger cells are merged while the cells with multiple rows are just regular cells that look split or fractured because of all the merged cells nearby. F15-F22, for example, all have their own row numbers but C15-C22 don't because they're merged.
Offline dgneo
  • Supervillain
« Reply #10 on: Thu, 14 January 2016, 14:08:52 »
I think you're making it more complicated than it needs to be.
1. Select all the cells you want, Right Click > Format Cells
2. Go to the Fill tab, select the color. You'll see all your cells look like one block now.
3. Select smaller selection of cells inside. Right Click > Format Cells
4. Go to the Border tab, select the 'Outline' Preset.
That should do it for you. It'll look like so:
Offline Michael
  • Formerly Bro Caps
« Reply #11 on: Thu, 14 January 2016, 14:09:02 »
Awesome, appreciate the help guys! Let me try this
Offline baldgye
« Reply #12 on: Thu, 14 January 2016, 14:24:51 »
Offline dgneo
  • Supervillain
« Reply #13 on: Thu, 14 January 2016, 14:26:46 »
Sure you can add it after the fact, but it looks like ****  :thumb:
Offline baldgye
« Reply #14 on: Thu, 14 January 2016, 14:28:33 »
its an excell spread sheet what the **** do you want it to look like?
Offline dgneo
  • Supervillain
« Reply #15 on: Thu, 14 January 2016, 14:29:33 »
STEP YA EXCEL GAME UP BRUH
Offline Zorberema
  • IG: @ZorbCaps
« Reply #16 on: Thu, 14 January 2016, 14:33:18 »
What is that ****, she doesn't even have eyebrows
Offline baldgye
« Reply #17 on: Thu, 14 January 2016, 14:34:14 »
merged cells
« Reply #18 on: Thu, 14 January 2016, 14:35:56 »
Can't tell if Joshing or cereal.
Offline dgneo
  • Supervillain
« Reply #19 on: Thu, 14 January 2016, 14:36:41 »
merged cells
Thank god I've got my good buddy Clippy here.
Offline digi
  • elite af tbh
  • keyboard game on fleek
« Reply #20 on: Thu, 14 January 2016, 14:37:23 »
I almost forgot about Mr. Clippy!!! Thanks Clippy!!
Offline Zorberema
  • IG: @ZorbCaps
« Reply #21 on: Thu, 14 January 2016, 14:49:15 »
