Author Topic: AT keyboard to USB  (Read 37049 times)
Offline ocdonkb
AT keyboard to USB
« on: Tue, 24 November 2009, 13:10:16 »
Amazingly, out of the 4 computers at home, not one has a PS/2 port.
So how do you guys convert from AT to USB?? I've got a Focus 2001 here, with 5-DIN AT connector, I'd love to use.
I've tried the AT-to-PS/2, PS/2-to-USB, but it's not seeing the keyboard.
The AT-to-PS/2 adapter I'm using is:
The PS/2-to-USB adapter I'm using is:
| Filco Brown 87 key | Realforce 87U | Unicomp Spacesaver | IBM Model M | Cherry ML4100 | Dell AT101W | Focus 2001 |
Offline spremino
AT keyboard to USB
« Reply #1 on: Tue, 24 November 2009, 13:17:57 »
Could it be that they need too much energy?
I've tried connecting my IBM PS/2 by means of an adapter similar to that of yours on top, without any success.
However, with another adapter the keyboard did work perfectly on Windows, whilst the Screen Lock led didn't work on Linux.
A long space bar... what a waste of space!
Offline ocdonkb
AT keyboard to USB
« Reply #2 on: Tue, 24 November 2009, 13:29:11 »
On my work computer that has a PS/2 port, the AT-to-PS/2 converter works fine.
I've also tried the PS/2-to-USB by itself(plugging PS/2 kb into USB), that also work fine.
However, converting from AT, all the way to USB, doesn't work. :( I'm guessing it takes a magic combination of adapters for this to work.
« Last Edit: Tue, 24 November 2009, 13:32:55 by ocdonkb »
Offline ch_123
AT keyboard to USB
« Reply #3 on: Tue, 24 November 2009, 13:30:56 »
Keyboard -> Passive AT-PS/2 adapter -> Good PS/2-USB adapter -> Computer
Works fine with my Model F using either a Belkin or Bytecc BT-2000 adapter with any computer I've used it with.
Offline ocdonkb
AT keyboard to USB
« Reply #4 on: Tue, 24 November 2009, 13:50:16 »
cool, guess it's time to shop for another PS/2-USB adapter.
Offline chimera15
AT keyboard to USB
« Reply #5 on: Tue, 24 November 2009, 15:32:18 »
I think it's true.  Some usb/ps2 adapters don't like certain keyboards.   Sometimes it's subtle, with some of my siigs for instance, some adapters result in the keyboard powering on and off occasionally.  Other times, the adapters don't recognize certain keys, for instance, they won't accept a Japanese layout/driver.  I guess it's possible that this one just doesn't like the focus board.  It might be power requirements.  There was a thread that dealt with different adapters.  Not sure if they ever pinpointed the best adapter that will work with every keyboard or not.
Oh I guess they decided the "blue cube" was.
« Last Edit: Tue, 24 November 2009, 15:40:18 by chimera15 »
Alps boards:
white real complicated: 1x modified siiig minitouch kb1903,  hhkb light2 english steampunk hack, wireless siig minitouch hack
white with rubber damper(cream)+clicky springs: 2x modified siig minitouch kb1903 1x modified siig minitouch kb1948
white fake simplified:   1x white smk-85, 1x Steampunk compact board hack
white real simplified: 1x unitek k-258
low profile: 1x mint m1242 in box
black: ultra mini wrist keyboard hack
blue: Japanese hhk2 lite hack, 1x siig minitouch pcb/doubleshot dc-2014 caps. kb1903, 1x modified kb1948 Siig minitouch
rainbow test boards:  mck-84sx
Offline Rajagra
AT keyboard to USB
« Reply #6 on: Tue, 24 November 2009, 15:58:33 »
My 1992 Model M works with that adapter, via a powered USB hub. Are you connecting to an unpowered hub? Try going straight to a motherboard USB connector.
Offline ocdonkb
AT keyboard to USB
« Reply #7 on: Tue, 24 November 2009, 16:16:14 »
I'm connecting it straight to the USB port on the computer.
Also, just placed an order at Cyberguys.com for the "Blue Cube" adapter. We'll see how this goes. geekhack hype wins again.
« Last Edit: Tue, 24 November 2009, 16:21:51 by ocdonkb »
Offline ricercar
  • mostly abides
AT keyboard to USB
« Reply #8 on: Tue, 24 November 2009, 16:22:16 »
Good idea. My blue cubes came today. 100% satisfied.
Offline keyb_gr
  • Cherrified user
    • My keyboard page (German)
AT keyboard to USB
« Reply #9 on: Wed, 25 November 2009, 04:06:36 »
Another "WFM" here - I have a whole bunch of DIN-equipped boards and DIN-PS/2 adapters and no issues with my Belkin (on an unpowered USB hub - i.e. powered with no PSU connected - no less).
Offline ocdonkb
AT keyboard to USB
« Reply #10 on: Wed, 25 November 2009, 11:48:09 »
Just to be sure, the Belkin adapter you guys mentioned, is it this one?
Offline 42.tar.gz
AT keyboard to USB
« Reply #11 on: Wed, 25 November 2009, 12:14:19 »
Quote from: ocdonkb;136231
[image]
No, it's from Hama. The Belkin adapter looks like this:
Works great with an old Cherry G80-3000 over an AT-to-PS/2-Adapter.
Currently using: some keyboard
Offline ak_nala
AT keyboard to USB
« Reply #12 on: Thu, 26 November 2009, 04:19:03 »
My Belkin works fine with Macs, but then mine (Belkin Model F5U119-E) says it's the same chip as the Blue Cube when I check it out on System Profiler.
No matter where you go, there you are...
Offline keyb_gr
  • Cherrified user
AT keyboard to USB
« Reply #13 on: Thu, 26 November 2009, 04:46:22 »
Quote from: ripster;136248
Just to make things MORE confusing there are TWO Belkin Adapters out there. Another.  $21.  Blue cube is $7, more in ROW.
This new model must be phasing out the old.  Don't know if it got better.
Could also be a duplicate listing, there are many on Amazon. The pic is the same in any case.
I just tried finding a category for these adapters at the Belkin website - unsuccessfully. What junk.
Offline ocdonkb
AT keyboard to USB
« Reply #14 on: Tue, 01 December 2009, 00:07:24 »
An update:
Today I received the Blue Cube from cyberguys. And yes, as if by magic, the Focus 2001 works now. Now I'll probably have to get another one for spare. :)
oh, just found that it works on my Mac-mini too!
« Last Edit: Tue, 01 December 2009, 00:36:48 by ocdonkb »
Offline microsoft windows
  • Blue Troll of Death
  • President of geekhack.org
    • Get Internet Explorer 6
AT keyboard to USB
« Reply #15 on: Wed, 02 December 2009, 19:11:43 »
I want to get a blue cube for my M5-2 so the trackball works better.
Offline mikeruth
AT keyboard to USB
« Reply #16 on: Wed, 03 March 2010, 13:48:18 »
ocdonkb,
I too have a FOCUS 2001 (actually more than one) and I tried to find the the "Blue Cube" on Cyberguys.com.  I did not see it.  What actually is a "blue cube"?
Mike R.
Offline pfink
AT keyboard to USB
« Reply #17 on: Wed, 03 March 2010, 14:09:36 »
Quote from: mikeruth;161677
ocdonkb,
http://www.cyberguys.com/product-details/?productid=4850
Offline ch_123
AT keyboard to USB
« Reply #18 on: Wed, 03 March 2010, 14:33:58 »
The SGI AT-101 (and presumably the original Dell AT-101 and others) cause the blue cube to **** themselves out. The Belkin ones support them a bit better, but still reset every once in a while.
Offline keyb_gr
  • Cherrified user
AT keyboard to USB
« Reply #19 on: Wed, 03 March 2010, 16:20:58 »
With problematic boards one should try squinting at the LEDs when typing. (Those obviously have to be illuminated, Num Lock alone should do.) If they flicker even slightly, chances are it's a power-related problem. Either the board is just a power hog or the electrolytic buffer capacitors are dead or insufficient to begin with. (We're dealing with electronic devices close to 20 years of age after all.) My KB-5182 seems to be such a case - I wouldn't mind if it didn't reset once in a while, dropping about 3 characters in a row, which is very annoying.
Offline HaaTa
  • Master Kiibohd Hunter
  • Kiibohds!
    • http://kiibohd.com
Re: AT keyboard to USB
« Reply #20 on: Wed, 03 March 2010, 19:37:59 »
I've noticed that when I've booted into X my scroll lock light will not turn on at all (not that
I really use it though). Without X it works fine.
Kiibohd
ALWAYS looking for cool and interesting switches
I take requests for making keyboard converters (i.e. *old keyboard* to USB).
Offline mrbill
    • http://weblog.mrbill.net
AT keyboard to USB
« Reply #21 on: Thu, 04 March 2010, 09:42:49 »
I've had good luck with this Sabrent USB-to-PS2 adapter.
http://www.amazon.com/gp/product/B0007UW0YM
$6
Keyboards:
IBM Model Ms: 51G8572 (\'94, \'96), 1391401 (\'90), 1369050 (\'95, Dell), 1394946 (\'89 Industrial)
Unicomp Model Ms:  Customizer 104, SpaceSaver 104
Chicony: KB-5181, KB-5191
Cherry:  MX11800 (x2), G86-6241 "Ricercar SPOS"
Filco: FKBN87M/EB x2, Cherry Browns
Sold: Matias Tactile Pro 1.0 (x2), Kensington Studioboard Mechanical, Scorpius M10, AEK II (x2), Compaq 11900 (x2), IBM Model F (AT), Filco FKB104MC/EB
Available Free for Cost of Shipping: ABS M1, Solidtek KB-6600ABU, KeyTronic KB101Plus
Offline cchan
AT keyboard to USB
« Reply #22 on: Thu, 04 March 2010, 11:28:02 »
Quote from: microsoft windows;138188
The Blue Cube is a keyboard only adapter.
As far as combo adapters I would recommend the Ziotek one available at cyberguys.com. It has worked well with my Cherry MX8100 and MX11900.
The only thing is that I had to set the keystroke sequence delay while executing programmable keystrokes on the 8100 - 20ms is slow enough for the adapter to handle, while whatever it was before, isn't slow enough, resulting in dropped keystrokes.
That has been no issue at all for me in normal typing, and I type ~75wpm.
HP Envy17: Core i7-2760QM, 8GB DDR3, 128GB Crucial m4 + 750GB Hitachi, Windows 7 Home Premium x64, Cherry ML4100, Logitech M500, HP zr22w
IBM Thinkpad X60: Core Duo T2400, 2GB DDR2, 128GB Samsung 830, Xubuntu 12.04 x86, Cherry ML4100, Logitech M205, HP zr22w
Raspberry Pi Model B: BCM2835, 0.25GB DDR2, 8GB Samsung SD card, Raspbian Wheezy, human interaction devices as above
Offline InSanCen
AT keyboard to USB
« Reply #23 on: Fri, 05 March 2010, 01:36:43 »
An a recommendation for EU based people wanting the dual Keyboard and Mouse adaptors would be the one that Bruce at The Keyboard Co sells. Works perfectly on my M13 (Using it now).
Currently Using :- IBM M13 1996, Black :
Currently Own :- 1391406 1989 & 1990 : AT Model F 1985 : Boscom 122 (Black) : G80-3000 : G80-1800 (x2) : Wang 724 : G81-8000LPBGB (Card Reader, MY) : Unitek : AT102W : TVS Gold :
Project's :- 122 key 1389620 Wireless ESP32 :
'Pooter :- Xeon E5-2680v4 : Machinist MR9A : 2x16GB DDR4 : Radeon RX6600 : NVME & Spinning rust :
