Author Topic: Ergo pro + clamp on camera mounts == win!  (Read 93047 times)
Offline Gerk
« on: Fri, 15 January 2016, 11:52:17 »
Just got the mounts in hand last night and played with them for a tiny bit.  Super configurable and they seem very sturdy.  Here's the mounts I used:
http://www.amazon.com/Arkon-Samsung-Olympus-Panasonic-Cameras/dp/B00P8A56PQ/ref=sr_1_fkmr0_1?ie=UTF8&qid=1452879899&sr=8-1-fkmr0
And here's what my setup currently looks like:
It's kind of hard to see from these pics, but I promise I will take better ones once the setup is more finalized ... and I will also clean up all the crap off my desk!  This setup is in my studio.  The mounts us a ball head type setup and give really good flexibility in terms of how you can position the keyboard halves.  In between the keyboards is a Slate Raven MTi2 audio touch screen controller (which is freakin' amazing, changes everything for me).  I wanted to get the touch screen much closer and full split out the keyboard halves.  Mission accomplished.  I did a fair bit of typing on them last night and they feel very stable.  I will probably adjust the angles a bit as time goes, but for now this will get the job done.
« Last Edit: Wed, 11 October 2017, 11:02:15 by Gerk »
Rosewill RK-9000RE (reds) | Das Keyboard Model S Professional Silent (browns) | Leopold TKL (browns) | F21-7D "Mechanical Keyboard" (Blue Alps) | Filco Majestouch TKL (blues) | Goldtouch V2 x 2 | Matias Ergo Pro x 2 | Kinesis Freestyle Pro (browns) | Kinesis Freestyle Edge (reds)
Re: Ergo pro + clamp on camera mounts == win!
« Reply #1 on: Fri, 15 January 2016, 12:00:18 »
That is an amazing setup!  The board itself is lovely, but that touchscreen :eek:
Offline Gerk
« Reply #2 on: Fri, 15 January 2016, 12:01:58 »
And the reason I decided to do the clamp on version instead of the desktop mount version is for a couple of reasons ...
The first reason is that initially the idea was that I would clamp these to my chair arms directly and have a "mad hacker" type chair, which I've always wanted.  Unfortunately it didn't work out well in my setup -- for fault of the gear, I just couldn't keep them attached to my chair and still get in close enough to the touch screen for my comfort level.
Secondly, and this was always the backup plan, is that I could clamp them to the fronts of my desk and have a full 360 range from there -- they could go out more forward than the front of the desk or go back -- they are currently in the back position.  I also wanted to make sure they were very stable and clamp ons don't move at all.  Also they don't take up any desk footprint.  You can (barely) see that on the right hand one I actually have my mouse under the keyboard.  it also keeps the desk top (the real one, not the virtual one) clean and usable underneath.
I couldn't be happier with the setup.
Offline Gerk
« Reply #3 on: Fri, 15 January 2016, 12:03:20 »
Here's a link to more info on that touchscreen setup for anyone who wants to know more about it:
http://www.slatemt.com/products/raven-mti/
I LOVE this thing.  No more RSI related mouse issues for me, now I use my whole arms and can use left and/or right hands (or both at the same time!)
Offline jacobolus
« Reply #4 on: Fri, 15 January 2016, 16:59:10 »
Gerk: have you tried tenting the two sides a bit? With the way you have them now, your wrists are still going to be pronated almost to their limit. Even a little bit of tenting relieves quite a bit of strain from several tendons, giving your fingers improved strength and flexibility and making it easier to find a neutral posture for your back/shoulders/upper arms while still typing comfortably.
My own preference is to have a tent angle of something like 35–50°, but lots of folks think that’s too “weird” and prefer about a 15° tent angle (usually the max for commercial products), while others go all the way to 80°.
A question: what’s the range of configuration of the ErgoPro halves on these particular mounts? Would you mind taking a few pictures of them tilted various directions? Thanks!
Offline Gerk
« Reply #5 on: Fri, 15 January 2016, 19:07:26 »
Yep I've tried a bunch of different angles and for a pure typing environment I would have it splayed more, but for this usage I spent more time doing hunt and peck or hotkey combos on it than I do in the way of touch typing.
Did a few pics, they have a pretty wide range.  The inner section can spin around to put the adjustor on either side (see last two pics) so they are pretty versatile.  Super happy with them for my needs!  Very solid too, I suspect they will last a long time if you take care of them (i.e don't overcrank the adjustors).
Offline showman
« Reply #6 on: Tue, 19 January 2016, 21:41:14 »
This is awesome! I love the idea of the clamps, and that touch-screen looks great. It is good for RSI you have found?
Offline Matias
  • * Moderator
    • http://matias.ca
« Reply #7 on: Sat, 23 January 2016, 11:17:02 »
This has gotta be the coolest thing I've ever seen...   :thumb:
Offline Kliwon
« Reply #8 on: Sun, 24 January 2016, 20:37:13 »
wow..   :thumb:
that nice work Gerk..
Offline BigDov
« Reply #9 on: Mon, 25 January 2016, 04:28:36 »
I might be missing something in the Amazon listing, or in your description - did you fab a little piece to actually attach to the back of the keyboard, then to the clamp, or was that included? I really like it, and am getting some inspiration to do something like that myself now... very, very cool
ergodox w/ MX Blues & Granite R4 + grifiti wrist rests || CM Storm QFR w/ Reds & black PBT laser-etched caps
Offline Gerk
« Reply #10 on: Sat, 06 February 2016, 10:52:08 »
No, the Matias ergo pro keyboards come with 1/4 20 style camera tripod/hot shoe mounts on them, so you only need to find clamps.stands that have that style of attachment and you're good to go.
Offline Gerk
« Reply #11 on: Sat, 06 February 2016, 10:53:04 »
Yes it has been great actually.  It's not good for everything I do but it's certainly awesome for music and video production work, and funny enough it's now my goto for casual web browsing (like right now, surfing forums).
Offline zefyr
  • Oddforge
« Reply #12 on: Sat, 06 February 2016, 22:23:29 »
OMG this is cool!!!
I'm gonna do this with mine, too!
Great work!
ZeFyr "Vermillion" J.
Vergo type.T / alpetit / alpetit II / VE.A with Vergo type.T-II
Offline showman
« Reply #13 on: Wed, 01 June 2016, 19:29:22 »
Gerk, which of these two Arkon Clamps would you recommend getting?
 This Kind: https://www.amazon.com/Camera-Mounting-Olympus-Panasonic-Cameras/dp/B00P8A56PQ?ie=UTF8&qid=1452879899&ref_=sr_1_fkmr0_1&sr=8-1-fkmr0
Or this one: https://www.amazon.com/Arkon-Samsung-Fujifilm-Panasonic-Olympus/dp/B00EKQC88C/ref=pd_bxgy_421_img_2?ie=UTF8&refRID=ZJWBBKYN5X9ZK18B9MNJ
Price is the same from the seller I'm dealing with. Any help would be greatly appreciated!
Offline Gerk
« Reply #14 on: Thu, 16 June 2016, 15:04:51 »
The first one for sure, the second gooseneck one won't get the job done IMHO.
Offline orchid88
« Reply #15 on: Wed, 05 September 2018, 03:22:00 »
Hello. Just found this posting on the keyboard setup. I’m thinking of getting the kinesis freestyle 2 keyboard and wanted to do a 90 degree setup. Wondering if these clamp would work for it as well? I don’t know if I could attach them? Thank you for your feedback on the stability.
