Author Topic: MX Greens: a couple questions  (Read 3626 times)
Offline macguy80
« on: Sat, 16 January 2016, 16:19:56 »
1. Are they even more fatiguing than mx clears if you bottom out? If so, does the click make the tactile point easier to hit without bottoming out?
2. In the switch tester I have, I notice that the green switch's click is (A) more pronounced and tactile (B) louder and (C) not *quite* as high-pitched, as the blue switch. Are these inherent differences between greens and blues, or is this just a good example of normal variation between switches?
Offline Steezus
  • Keeper of Facts
Re: MX Greens: a couple questions
« Reply #1 on: Sat, 16 January 2016, 16:41:04 »
Greens are just Blues with heavier springs. The actuation force is much higher than clears so if you're not use to the heavier springs than it can be quite fatiguing at first.
Offline macguy80
« Reply #2 on: Sat, 16 January 2016, 16:45:00 »
Ah, ok! I thought they might just be clicky clears, but if they're even stiffer, I'll cross them off my list and go back to my Model M, which, despite being heavy, I can type on for MUCH longer periods than my clears.
Offline Steezus
  • Keeper of Facts
« Reply #3 on: Sat, 16 January 2016, 16:47:25 »
Greens are the closest to buckling springs, they're ever so slightly lighter to actuate. Greens actuation is 80cN and BS is 90cN.
Offline falkentyne
« Reply #4 on: Sat, 16 January 2016, 16:55:45 »
MY PRECCCCCCCCCIOOOOOOUSSSSSSSSSSSSSSSS
My Ducky Shine fire 69 edition with MX GREENS for the letter and MX blues for the mods (and then clears, reds, greys, you name it, for other keys).
Until I got my Ducky Year of the Goat and Ducky Shine 5, I used the Fire 69 as a daily GAMING and typing driver for a year.  It's not fatiguing at ALL unless your hands get cold.
Fun fact: they're not much different than clears on the enemy of finger muscles scale.
The actuation point where you feel the tactile bump and the click slider, actually has higher CN force than the spring resistance right behind it!  So most of the resistance is from bypassing the tactile bump itself.  Then it 'buckles' in, in a way, to a lighter resistance, and only exceeds the tactile original force, at the bottom out point.  so the bump/click point itself requires 80cn to bypass, then drops off and gets lighter, then heavier again.  Blues function the same way.  So if you're into clears, greens should not be hard to adjust to.
The IBM selectric II seemed to function in a strangely similar way, just far more elegantly and more pleasant, as if your hand were being guided by a beautiful Asian woman with a nice butt and slim stomach.
Now, Tactile Greys, on the other hand...tactile greys are for those very few, rare special humanoids who think that MX clears are TOO LIGHT.
« Last Edit: Sat, 16 January 2016, 16:58:21 by falkentyne »
Offline chyros
  • a.k.a. Thomas
  • Hello and welcome.
« Reply #5 on: Sat, 16 January 2016, 17:12:32 »
To actuate? No. BS is 65-70 gf ~ cN.
Offline Steezus
  • Keeper of Facts
« Reply #6 on: Sat, 16 January 2016, 17:15:33 »
The Cherry MX Green is both a tactile and a clicky switch. You can both feel the tactile bump and hear the "click" that occurs when the activation point is hit. Due to the actuation force needed (80 cN), the switch feels similar to a buckling spring (which takes about 90 cN force to actuate)
http://deskthority.net/wiki/Cherry_MX_Green
Offline chyros
  • a.k.a. Thomas
« Reply #7 on: Sat, 16 January 2016, 17:34:00 »
Well, sorry, but that's not correct :p . You can check the official force chart (or the DT article on BS) if you don't believe me :p .
Apparently the user who added it, Comradekeys, is not registered at DT and it's his only edit. Worse, he didn't cite any proof for either claim.
Offline Steezus
  • Keeper of Facts
« Reply #8 on: Sat, 16 January 2016, 17:47:32 »
Deskthority has failed me, I know how trust issues.
« Last Edit: Sat, 16 January 2016, 18:11:12 by Steezus »
Offline macguy80
« Reply #9 on: Sat, 16 January 2016, 18:06:27 »
Deskthority as failed me, I know how trust issues.
I guess this proves that not everything at DT is "Deskthoritative" :)
Sorry guys, couldn't resist a bad pun! ;)
Offline Vittra
  • Airflow Optimizer
« Reply #10 on: Sat, 16 January 2016, 18:07:23 »
Filco MJ Linear R LE TKL
Offline chyros
  • a.k.a. Thomas
« Reply #11 on: Sat, 16 January 2016, 18:11:44 »
Well force amounts are a tricky business to begin with, we have nowhere near as many force curves as we'd all like to I'm sure. Some people including me have measured actuation/tactile forces, but of course you're always dependent on the switches' condition (and you need to do mass tests) so it's not always reliable. IBM BS is one of the few we do have the official chart of, though xD .
Offline Jokrik
« Reply #12 on: Sat, 16 January 2016, 18:12:02 »
Hahaha, I game a lot with MX greens in the past, but I sold the board
thinking to assemble one with greens, it's amazingly very clicky due to heavier springs
Offline klennkellon
  • I like bottoming out
« Reply #13 on: Sat, 16 January 2016, 18:33:27 »
I would actually like to argue and say that Complicated White ALPS are closest to buckling springs.
But if you were trying to say that MX Greens are the closest Cherry Switch to BS, you are correct.
Offline Connly33
« Reply #14 on: Sat, 16 January 2016, 18:43:43 »
Next board i do will be green's, I i love blues but they are too light for me, i'm loving clears, but i want a nice clicky board too.
Custom 60% with Cherry MX Clear
« Reply #15 on: Sat, 16 January 2016, 19:49:46 »
Jailhousing greens is the solution to all your requests: high actuation point, shorter throw, etc. Add O-rings for top performance.
- D Trump 2026-10-24
« Reply #16 on: Sat, 16 January 2016, 22:40:51 »
To me clears are heavier than greens.
I bottom out all the time on all keyboards I have, except clears.  Clears I only bottom out about 90% of the time (without making any special effort to bottom out or not).
