Author Topic: Removed a few 'centers' of pcb through holes on V60 MTS, help?  (Read 1602 times)
Offline Mattr567
« on: Sun, 17 January 2016, 21:59:36 »
I am swapping SKCL Green Alps switches into my V60 MTS and while de soldering a few centers/hole plating of the PCB holes came out with the old Matias switches.
Example:
I followed this thread http://deskthority.net/keyboards-f2/fixing-lifted-pads-kbp-v60-mts-t12179.html on deskthroity for lifted pads on a MTS, hand wiring to the SMT diode or to another switch leg that connected to the original, but I cant get the 3-4 switches to register. I cleaned the surface before doing so as well.
What can I do?
Thanks.
IBM P77, SKCC Green, 1984
Offline axtran
Re: Removed a few 'centers' of pcb through holes on V60 MTS, help?
« Reply #1 on: Sun, 17 January 2016, 23:17:07 »
You're going to have to show the PCB and where the traces go. Depending on the pin, it changes how and where you have to jump the wires.
MX Silent > MX Vintage Black > Everything Else
Offline Mattr567
« Reply #2 on: Sun, 17 January 2016, 23:55:42 »
Here is what the PCB looks like
I am following the traces, for example on the [ key, the right hole connects to the bottom of the corresponding diode. For the left hole of the [ key I am not sure, it looks like it doesn't connect to anything.
Other keys like the ] key, the left hole has a visible trace.
Offline Mattr567
« Reply #3 on: Mon, 18 January 2016, 00:42:30 »
Update
By looking at a picture of the front of the PCB I was able to wire the left leg and make a switch work!
This also means that my LED backlighting didnt work, since I fixed the key that turns on the backlight in the MX version at least. Likey using the wrong resistors.
