Author Topic: Apple Extended Switch Custom  (Read 1346 times)
Offline poopdecksweeper
« on: Mon, 18 January 2016, 13:21:22 »
Hi all, new user here.
I was wondering if there is any possibility of creating a custom 60%ish keyboard using my Apple Extended Alps switches. Any ideas at all would be helpful. Thanks!
Must haves on the board:
1. Arrows
2. Ability to change keys around (programmability...?)
3. Small form factor
Offline flabbergast
Re: Apple Extended Switch Custom
« Reply #1 on: Mon, 18 January 2016, 14:01:15 »
Apart from the arrows (which is always problematic on 60%, some compromise must be made), you've missed a GB that offered exactly that by a couple of months. Something similar will come up sooner or later I think, there is still demand for this.
Other than that, you can always have a custom plate cut and handwire the keyboard.
Offline bcredbottle
« Reply #2 on: Mon, 18 January 2016, 14:02:54 »
might want to send a PM to E3E, njbair, Badwrench, or CPTBadass. They are the experts in this area.
