Author Topic: Granite / sandy plastic casing customisation  (Read 3386 times)
Offline joneslee85
  • HHKB Scrub JP
  • Professional Rubyist programmer!
    • Ruby Journal
« on: Wed, 25 November 2009, 07:30:18 »
Hi all mod-experts
Do you guys know any where that could make the granite plastic like the SGI Onyx Granite keyboard? I am just in love this granite color, should it be grey, blue, black, they all look great. I want to make the casing for my Topre 87U as well as keycap.
TOO MANY KEYBOARDS THAT I COULD NOT COUNT! BUT I AM STILL USING MY MODEL F77
Offline joneslee85
  • HHKB Scrub JP
    • Ruby Journal
« Reply #1 on: Wed, 25 November 2009, 07:31:50 »
SGI granite keyboard
Offline Shawn Stanford
« Reply #2 on: Wed, 25 November 2009, 07:35:08 »
The Brat Prince of COBOL
Offline mp29k
« Reply #3 on: Wed, 25 November 2009, 07:48:20 »
Might be expensive, but make a case out of Corian countertop material.  Sometimes they have cheap scraps when they cut out the opening where the sink goes.
You would have to do some research on how to bond it and do it in layers, and then also how to polich and shape it, but you would come out with a beautiful board, and it would be STURDY!
"You thought keyboards were expensive. Try putting some rubber domes in your GF." -itlnstln
Offline joneslee85
  • HHKB Scrub JP
    • Ruby Journal
« Reply #4 on: Wed, 25 November 2009, 07:51:22 »
Quote from: Shawn Stanford;136165
Krylon 'Make It Stone' paints: http://www.krylon.com/products/make_it_stone_textured_paints/
Thanks, I will look for something similar in Australia. Are u experienced with painting on plastic? I don't have spare case or keycaps to experience on. So one shot must never miss the chance to blow.
« Last Edit: Wed, 25 November 2009, 07:56:07 by joneslee85 »
Offline joneslee85
  • HHKB Scrub JP
    • Ruby Journal
« Reply #5 on: Wed, 25 November 2009, 07:55:45 »
Quote from: mp29k;136172
Your one is a good solution too but that means I could not reuse the pretty housing of my Topre. But it is indeed a creative way for my IBM M mod project.
« Reply #6 on: Wed, 25 November 2009, 08:16:16 »
I painted a Model M case hot rod red with Krylon. The trick I learned from others' experience is to build the paint up in thin layers so that you don't get a buildup or runs. I think I did a half-dozen thin coats over the course of a week.
I did have a problem with the paint getting 'tacky' where I rest my fingers. That's dependent on the paint, but a solution might be to cure the paint in an oven for a few hours or to use a topcoat of some sort. Just a thought...
« Reply #7 on: Wed, 25 November 2009, 11:08:26 »
I found the tackiness to be increasing and distracting after a couple weeks as my work keyboard. So, in this case I don't think it's viable.
« Reply #8 on: Wed, 25 November 2009, 12:08:27 »
None.
Offline joneslee85
  • HHKB Scrub JP
    • Ruby Journal
« Reply #9 on: Wed, 25 November 2009, 16:25:45 »
Is there any plastic molder out there?
« Reply #10 on: Thu, 26 November 2009, 05:33:10 »
If you're looking for someone to make plastic components, there are a bunch of companies that will do rapid prototyping using your designs.
Offline ricercar
  • mostly abides
« Reply #11 on: Thu, 26 November 2009, 13:27:51 »
TOP Plastics here in silicon valley makes lots of one-offs for entrepreneurs. They should be googlable.
Offline didjamatic
