Author Topic: Help find my next keyboard (have a very specific list of requirements)  (Read 3287 times)
Offline Carthik
Hello Geekhack, I'm looking for a keyboard with the following:
-manufactured by Costar
-ten key less (not 60%)
-Cherry MX Switch
-brightness adjustable white back light
-wireless
Does anyone make such a keyboard?
Offline Melvang
  • Exquisite Lord of Bumfluff
  • Melvang's Desktop Customs
Re: Help find my next keyboard (have a very specific list of requirements)
« Reply #1 on: Mon, 18 January 2016, 19:32:59 »
-Cherry MX Switch
-wireless
I can't say I can vouch for all the requirements, but I would recommend a Ducky with an add on blue tooth adapter.  I think those are made.  The issue is backlighing will suck a ton of power from batteries in a keyboard.
Offline Steezus
  • Keeper of Facts
« Reply #2 on: Mon, 18 January 2016, 19:34:10 »
You're really only able to choose LEDs or wireless, like Melvang said the LEDs draw a lot of power.
Offline Carthik
« Reply #3 on: Tue, 19 January 2016, 21:59:51 »
That's logical, don't know why I didn't think of that. I'm okay with wired as long as the cable is easily detachable. I like to clear my desk sometimes for little projects and the corded keyboard gets annoying.
I guess here's an updated list, I know I have many options but want to make sure I covered them all. I'm really really liking the WASD Code TKL but it's really up there in  price.
-Cherry MX Switch
-detachable cable
Offline jerue
  • (Whenever that happens :P)
« Reply #4 on: Tue, 19 January 2016, 22:13:59 »
I think the CM Storm Quickfire Rapid-i meets these requirements, but not sure what "Made by Costar" means (unless referring to having costar stabilizers, which these do)
Offline arrowM
« Reply #5 on: Wed, 20 January 2016, 05:25:22 »
This one looks pretty good. Wireless, backlit, tenkeyless, Cherry switches. Not sure about Costar though.
https://www.massdrop.com/buy/varmilo-vb87m-bluetooth?mode=guest_open
Offline xondat
  • i'm not a star
« Reply #6 on: Wed, 20 January 2016, 13:35:22 »
The CODE 87 is backlight, has a removable cable, Costar stabilizers and is backlit.
http://www.wasdkeyboards.com/index.php/review/product/list/id/133/?limit=50
Offline Homenubbie
« Reply #7 on: Wed, 20 January 2016, 17:25:12 »
-Cherry MX Switch
-wireless
Is Varmillo a Costar board?
Offline Homenubbie
« Reply #8 on: Wed, 20 January 2016, 17:26:14 »
Not wireless.
Offline xondat
  • i'm not a star
« Reply #9 on: Wed, 20 January 2016, 17:27:22 »
Not wireless.
Offline Carthik
« Reply #10 on: Thu, 21 January 2016, 08:08:42 »
-Cherry MX Switch
-wireless
Would like to know this as well. Though the fact that the "white" LEDs are really a very light blue is a deal breaker for me.
Costar is the manufacturer that makes most the better "brand" keyboards (WASD, FILCO, etc.)
« Last Edit: Thu, 21 January 2016, 08:26:01 by Carthik »
« Reply #11 on: Thu, 21 January 2016, 08:26:05 »
-Cherry MX Switch
-wireless
I'm not sure that's as big of an issue as it was a few years ago.
