Author Topic: GMK Durability  (Read 10720 times)
Offline KaminKevCrew
GMK Durability
« on: Tue, 19 January 2016, 22:37:13 »
Hey there, I recently acquired a GMK Hyperfuse set. It's currently on my board. But I'd rather avoid seeing it shine. Should I be worried about that since they are abs caps, or is the GMK stuff durable enough?
Re: GMK Durability
« Reply #1 on: Tue, 19 January 2016, 22:43:48 »
All ABS shines.
Re: GMK Durability
« Reply #2 on: Tue, 19 January 2016, 22:48:49 »
Offline ImpendingxDoom
  • MF the SuperVillain
Re: GMK Durability
« Reply #3 on: Tue, 19 January 2016, 22:49:31 »
If you use it, it will shine. But don't let that stop you! This is one of the reasons why there is sometime a "spacebars" child buy, because that's usually the first cap to show the wear. Sometimes is nice to have a nice worn in set, but some folks don't care for shiny bits. But what's the point of getting a set of you don't wanna use it to your hearts content?
Re: GMK Durability
« Reply #4 on: Tue, 19 January 2016, 22:50:38 »
Y'know, I used to be hot and bothered by shining, but I saw one of Hoff's white-on-black sets (forgot which one), and the shine actually looked really, really good. I think because the entire cap was shiny, not just part of it.
Like, a worn and loved shine.
Edit:
Here it is: https://www.flickr.com/photos/99522542@N03/21725582734/in/dateposted/.
125040-0
« Last Edit: Tue, 19 January 2016, 22:53:05 by romevi »
Offline swimmingbird
  • keyset hoarder
Re: GMK Durability
« Reply #5 on: Tue, 19 January 2016, 22:58:51 »
I haven't actually seen any real shine on GMK caps - all the photos I have seen are old OG cherry doubleshots
I've got sort of oily fingers and after using Hyperfuse for 4 months saw no signs of shine whatsoever
Offline Bevo
Re: GMK Durability
« Reply #6 on: Wed, 20 January 2016, 03:50:37 »
Edit:
Hoff not using his j's enough. Jajajaja
Re: GMK Durability
« Reply #7 on: Wed, 20 January 2016, 03:55:56 »
I keep swapping my sets around, and haven't noticed any shine on GMK sets.
I usually get an extra space bar just in case.
And you can always put a strip of clear sticky tape along the space bar to protect the upper surface.
Offline bocahgundul
  • a seal
Re: GMK Durability
« Reply #8 on: Wed, 20 January 2016, 04:47:35 »
 shines in ABS is because of oil in our hands right? well I guess I'm lucky for not producing any oil when I type  :p
Offline pr0ximity
Re: GMK Durability
« Reply #9 on: Wed, 20 January 2016, 06:10:54 »
I've been hoping to cultivate a nice shiny patina on my GMK Red Alert, but no such luck yet. I think I need greasier hands.
  • keyset hoarder
Re: GMK Durability
« Reply #10 on: Wed, 20 January 2016, 06:12:34 »
get the acetone out
Offline pr0ximity
Re: GMK Durability
« Reply #11 on: Wed, 20 January 2016, 06:16:08 »
get the acetone out
Nah man, looking for that OG sweatshine, no repro crap.
Offline skcheng
    • Tenafly Dentistry
Re: GMK Durability
« Reply #12 on: Wed, 20 January 2016, 06:52:46 »
Embrace the shine!!   What a bunch of pansies   ;D ;D
Nice worn out GMK (and OG Cherry) caps are customized built for comfort keycaps!!
If you don't want/like shine, then leave the caps in the bag they came in LOL!!
Offline Geroximo
Re: GMK Durability
« Reply #13 on: Wed, 20 January 2016, 07:24:21 »
Evenly shined keys are nice.
The problem occurs when only the commonly used keys show shine while others don't.
I then have to take all the non shiny keys and rub them extensively against my sweaty greasy fingers (I do this after sport and eating fries) until every cap is shined evenly.
Offline luckyryan333
  • #There'sNoToolForTyping
Re: GMK Durability
« Reply #14 on: Wed, 20 January 2016, 07:49:21 »
Open your mind, caress your GMK babies and feel the wet-shiny-look.  ;D
No PaiN, No GaiN
How to order from Taobao from outside of China and WITHOUT an Agent
daily driver: C70 w/ Oblivion
on the way: d65_12/gmkblk_3
Offline Bevo
Re: GMK Durability
« Reply #15 on: Wed, 20 January 2016, 08:33:21 »
A patina haha. Thats a nice way of looking at it
Offline inanis
  • Truly Literally The Cloud
    • SEALWoodworking
Re: GMK Durability
« Reply #16 on: Wed, 20 January 2016, 08:38:13 »
Yeah, it'll shine eventually. I type a fair amount and my GMK, if used regularly, does shine, just like anything else in ABS. I think it looks nice. It certainly feels nice. I buy things to use them, so what some might look at as a deficiency, I think makes it look well loved.
LOVE YOUR GMK!
Offline DanielT
Re: GMK Durability
« Reply #17 on: Wed, 20 January 2016, 08:55:09 »
LOVE YOUR GMK!
You've put it so nice :) I've seen people obsessed that the caps(that goes also for artisans) or the board would lose resale value... For me the bast part is using, I also buy only to use, shine is part of the beauty of these. I love the spot of shine on my spacebar, the best clack I have ever seen was a OG Tri where the face/skull had a bonny look from using it.
Keyboards with everything that comes with them are supposed to be used and enjoyed and not worshiped.
So yes, in time there will be shine on GMK caps so what ?!  :cool:
