Author Topic: Realforce Silenced 104U + 4 PBT Spacebars on Massdrop  (Read 3391 times)
Offline 1391406
« on: Thu, 21 January 2016, 06:56:11 »
Unlocked at $280. I'm fairly certain I'm buying a white one.
« Last Edit: Thu, 21 January 2016, 10:33:01 by 1391406 »
Offline 1391406
Re: Realforce Silenced 104U + 4 PBT Spacebars on Massdrop
« Reply #1 on: Thu, 21 January 2016, 07:00:23 »
These also have the flat Windows key.
Offline Vittra
  • Airflow Optimizer
« Reply #2 on: Thu, 21 January 2016, 07:14:07 »
Hmm, variable. If it was 45G I'd bite.
Filco MJ Linear R LE TKL
Offline 1391406
« Reply #3 on: Thu, 21 January 2016, 07:21:53 »
I don't think they make white 45g uniform RF's. I plan on modding mine to 45g, though.
« Reply #4 on: Thu, 21 January 2016, 07:30:17 »
FWIW you can get a brand new 45g silenced JIS layout 108-key Realforce (108UH-S / SA010S) for about $160 from Japan.
Maybe not much use for those who want an ANSI board, but if anyone is looking at this just for the sliders, it's definitely smarter to buy from Japan.
« Last Edit: Thu, 21 January 2016, 07:33:10 by Photekq »
Offline jerue
  • (Whenever that happens :P)
« Reply #5 on: Thu, 21 January 2016, 18:20:23 »
I thought these were just a thing of the past (purple sliders). Kind of glad to see that's not the case, at least.  :thumb:
Offline ApocalypseMaow
  • Kitteh Overlord
  • Say WHAAT...
« Reply #6 on: Thu, 21 January 2016, 18:20:45 »
just the answer I was looking for, thx pho!
