Author Topic: What's a good keyboard for my requirements?  (Read 1998 times)
Offline Tekkkz
« on: Sat, 23 January 2016, 12:07:27 »
Hello!
I'm new and wanna buy my first mechkb.
After a lot of research I realized that they are very expensive.
So here are some specs which are important for me:
  • blackgroud led lightning
  • tacticle and clicky - so blue switches are what I want I think
  • 60% ANSI layout
Ofc I found a lot off good keyboards, like the KBParadise V60, Pok3r .... but there is one problem:
I'm living in Germany and can pay only max. 120€ ...
So can you recommend me a keyboard which fits to me?
Offline radio_killah
  • Chinchillin'
Re: What's a good keyboard for my requirements?
« Reply #1 on: Sat, 23 January 2016, 12:19:08 »
Personally I don't think you can go wrong with a back lit pok3r with mx blues.  ;)
Offline sitch
« Reply #2 on: Sat, 23 January 2016, 12:36:48 »
Maybe you can start off with poker 2 (IMHO almost the same with poker 3) and save the money for the next board (which you will... after couple of months.. maybe lesser)  ;D
Offline azhdar
  • Praise the AZERTY god
« Reply #3 on: Sat, 23 January 2016, 12:41:00 »
if you have not found this place yet : https://corus-kb.com/en/pok3r/19-vortex-pok3r-poker-3-pbt-black-version-alu-casing-ansi-us-international.html ye above your 120€ budget, you should just save up imo, or try to buy one second hand
Azerty Propagandiste
Offline Tekkkz
« Reply #4 on: Sat, 23 January 2016, 12:53:44 »
Okay I think I can pay the 30€ more for the Pok3r 3 ... but does this, what you have linked, backlight? There is written:
- Individual LED coding (Backlit version only)
But is this the backlit version?
Offline Homenubbie
« Reply #6 on: Sat, 23 January 2016, 18:04:29 »
It is not.
Offline Tekkkz
« Reply #7 on: Sun, 24 January 2016, 01:43:20 »
merlin64 your idea is great but it takes so much time to arrive at me (ca 20 days) ... i would get my board next week .. ;(
