Author Topic: Cases that a QFR TKL will fit in?  (Read 2762 times)
Offline Wulfre
« on: Sat, 23 January 2016, 15:50:46 »
I've read that a QFR PCB might fit inside a case made for a Filco or Phantom, but I want to know if anyone has actually tried it.
Offline merlin64
    • MechMerlin
Re: Cases that a QFR TKL will fit in?
« Reply #1 on: Sat, 23 January 2016, 16:36:56 »
I've actually heard the converse, in which a Phantom PCB would fit in a QFR or a Filco Majestouch.
Offline Wulfre
« Reply #2 on: Sat, 23 January 2016, 17:10:36 »
Would I be able to assume that if the Phantom can fit in a QFR / Filco then the QFR could fit in a Filco? Or does that not apply in this situation.
Offline bocahgundul
  • a seal
« Reply #3 on: Sun, 24 January 2016, 03:05:26 »
I think the ONI tkl from mechkeyboard can fit the qfr
They will restock it soon
Offline Jokrik
« Reply #4 on: Sun, 24 January 2016, 03:11:15 »
I doubt this
I haven't came across a qfr inside an ONI but I might be wrong
worst case, you've to mod the case to fit it in
modding plastic base case like filco to fit a QFR pcb/plate is easier than modding an aluminium case
Offline bocahgundul
  • a seal
« Reply #5 on: Sun, 24 January 2016, 03:17:30 »
I doubt this
Yep this  :thumb:
Offline Sped
« Reply #6 on: Sun, 24 January 2016, 03:35:26 »
I have a Quickfire Rapid that's inside a black Filco/ONI TKL aluminum case from Tex. It's a little tight, but it definitely fits.
« Last Edit: Sun, 24 January 2016, 03:37:22 by Sped »
Offline Jokrik
« Reply #7 on: Sun, 24 January 2016, 03:37:22 »
Now this confirms it
I owned an ONI case, but I can't handle the angle, not steep enough. Something you should watch if you wanna buy one
